Low Power Mode and PoE negotiation
Click 日本語 for Japanese
Overview
When connecting a Cisco Meraki access point (AP) to different PoE switch models, sometimes you may run into an insufficient power scenario. This is called a Low Power Mode.
Some Meraki MR access points require PoE+ or PoE++ power levels to perform and offer all features and functionality. However, some switches and PoE injectors may not be able to supply or negotiate these energy levels. If the MR is receiving less power than PoE+ (802.3at), it will display "running in low power mode."  The same situation may happen with an MR that requires PoE++ (802.3bt) Power level but the switch or power injector is unable to provide or negotiate higher power levels.
MR45, MR46, MR46E, MR55, MR56, MR76, MR86, Catalyst CW916x access points require 802.3at (PoE+) to function properly and will not support 802.3af low power mode.
CW9178I, CW9176I, and CW9176D1 support different degraded modes when powered at 802.3at (30 W). In order to configure it, review Power Settings.
MR44 is the only WiFi-6 MR access point that supports low-power mode. For more details refer to the MR44 datasheet.
PoE Standards
Industry Standard IEEE Standard Description
PoE 802.3af This is the original PoE and provides up to 15.4 Watts. This now is also known as Legacy PoE.
PoE+ 802.3at
This standard provides up to 30W. It requires L2 negotiation (LLDP or CDP) to provide above 15.4W.
UPoE
Cisco proprietary (802.3bt based - Type 3)
Universal PoE. Cisco proprietary technology that extends the IEEE 802.3 PoE standard to provide the capability to source up to 60W of power over per port over CDP or LLDP.
PoE++ 802.bt At the moment, this is the latest standard and provides up to 100W. It requires LLDP working together with it when providing above 30W.
As a general best practice, you should do the following two actions when planing and implementing your AP and switch:
  1.  Check your AP and Switch datasheets and make sure they are compliant to the same or compatible standards.
  2. Enable both CDP and LLDP in the switch Ethernet ports connected to your AP; doing this will allow best compatibility and energy control
PoE Negotiation Details
Starting in MR32.1 firmware, you can see more information on how an AP is being powered. The additional information that will be shown in the AP details page will include:
  • Current power consumption - This may vary over time as the radios increase or decrease their Tx power.
  • Power Source - DC Power or PoE
  • PoE Protocol - CDP or LLDP, the AP will choose the protocol that provides the higher power
  • Power Requested - how much power was requested by the AP
  • Power Granted - how much power has been granted by the PSE (Power Sourcing Equipment)
Dashboard will only display data based on first negotiation at boot and does not dynamically update.
Note: Access points that are not operating on MR32.1+ firmware versions will continue to see previously available limited PoE information.old_poe_view.png
Requirements
  • PoE Negotiation details is supported on all AP models that support and are are running MR32.1+ firmware releases
  • PoE Negotiation details will be visible on the New Version of the AP Details page
  • Supported APs:
MR36 MR46 MR56 MR46E MR76 MR86
MR44 MR36H MR57 MR28 MR78 CW9162I
CW9164I CW9166I CW9166D1 CW9163E CW9172I CW9172H
CW9176I CW9176D1 CW9178
PoE via CDP/LLDP
PoE via CDP/LLDP (Dual Port)
PoE via Power injector
If PoE is provided by an injector there will be no PoE negotiation method or Power requested | granted, as no negotiation is done with an injector.
PoE via CDP/LLDP + Power Injector (Dual port)
Low Power Mode scenarios
  1. Cisco Meraki switch family (MS) have both CDP and LLDP enabled by default just like Cisco Meraki MR access points. There wouldn't be any issue requesting power when connecting MR and MS together, unless your MS doesn't have enough Power Budget to provide energy to your MR.
  2. When connected to other vendor switches (e.g.: HP ProCurve switches), your AP would use MDI detection during boot up and LLDP when negotiating any PoE Energy levels.
    • If your AP is PoE+ compliant and it is connected to a switch port that has LLDP disabled or the switch itself is Legacy PoE, then your AP would get in Low Power Mode scenario.
    • Likewise, if your AP is PoE++ compliant and it is connected to an Ethernet switch port that has LLDP disabled or the switch itself is PoE+ only, then your AP would fallback to PoE+ and display an alert in the dashboard saying “Access point is running in low power mode”.
  3. When connected to Cisco switches (e.g.: Catalyst), AP can use CDP or LLDP to request PoE Energy levels within PoE and PoE+. In this case, AP would use CDP primarily and LLDP additionally as per PoE+ requirement. There are some situations where CDP alone isn't enough to request PoE+ energy levels. In addition, MR APs must use both CDP and LLDP to request Energy levels within PoE++ levels.
Since MR24.5+ firmware, MR access points use CDP or LLDP to negotiate PoE+ Energy levels required during operation. However, AP must use both CDP and LLDP when requesting PoE++ energy levels.
Meraki switches supports CDP and LLDP while Most Catalyst switches only supports CDP by default. Therefore, your MR may get into a Low Power Mode scenario due to LLDP absence. Our documentation covers this configuration with other Cisco switches.
The Cisco Meraki Dashboard shows 802.3at for 802.3bt-capable APs when power is negotiated at 25.5W via LLDP or 30W via CDP. Dashboard displays 802.3bt (PoE++) only if the AP is connected to a switchport capable of delivering more than 30W, corresponding to 802.3bt Type 3/UPoE or Type 4/High Power PoE.
Impact of Low Power Mode
While in low power mode, the MR will disable its Air Marshal radio as well as some of its transmit streams on the 2.4 GHz band. Despite being in low power mode, the device can still supply full 802.11ac capabilities.
Refer to the installation guides for the low power mode behaviour as it can vary based on MR model.
Models with a dedicated scanning radio, such as the MR18/32/34/42/52/53/84, don't generate channel_scan events. They rely on the scanning radio to get the neighbor and channel utilization report on an ongoing basis.
In comparison, models without the dedicated scanning radio, such as the MR12/16/20/24/70, scan the whole spectrum every 2 hours when there are no clients associated. When low power mode is enabled the scanning radio function becomes disabled. Thus, not only are there no channel_scan events but AutoRF channel assignment can be negatively impacted.
For more information about MR hardware specifications such as which models include a dedicated scanning radio, see the MR Family Datasheets.
Troubleshooting
If the device is running in low power mode, ensure that the power source supports the appropiate power standard and that it is supplying full power to the device. To identify if the AP is running in low power mode, navigate to the AP details page on the Meraki dashboard, found under Wireless > Monitor > Access Points. Once there, under Status there will be a field that indicates the Power source and if the AP is in low power mode.
MR Access Point Power Source image found in the Meraki dashboard
If encountering issues with low power mode on Cisco switches or HP ProCurve switches, please refer to their respective articles for more information.
