Enable Cloud Management for Cisco Switches with Device Configuration
Click 日本語 for Japanese
This guide provides an overview and a step-by-step guide on how to connect Cisco Catalyst 9000 switches and Cisco C9000 Smart Switches to cloud management with configuration source: device.
Help us improve your experience. Complete this quick survey to share your feedback on Cloud Monitoring or Configuration Source: Device.
Before starting, verify that all prerequisites are fulfilled, such as supported hardware, the appropriate IOS XE version, and the necessary firewall rules. For more information, refer to Catalyst Cloud-Managed Switches Overview.
Organizations using Per‑Device Licensing (PDL) must add Catalyst switches through Network‑wide > Add devices. For more information, see Adding and Removing Devices from Dashboard Networks.
Cisco Catalyst Switch in 'Config Source: Cloud' Management Mode on Arrival
Cisco Catalyst switches might boot directly into 'Config Source: Cloud' management mode. In this mode, the CLI access via console is blocked.
To switch to 'Config Source: Device' mode, follow these steps:
- Add the switch to the Meraki Dashboard.
- In the Dashboard, set the switch's configuration source to 'Config Source: Cloud'.
- Bring the switch online in the Dashboard.
- Contact Cisco Meraki Support once the switch is online.
- Cisco Meraki Support will convert the switch from Cloud management mode to DNA mode, performing a factory reset during the process.
- Remove the switch from the Dashboard network.
- After the factory reset, the switch boots into traditional CLI mode.
- Access the switch via console and proceed with CLI-based configuration.
- Follow the steps in this documentation to enable cloud management with device configuration on Cisco switches.
Prerequisites
Supported Cisco Catalyst 9000 Switching Models
| Family | Models | Minimum Required Software Version |
All Catalyst 9200 (incl. C9200L and C9200CX) |
C9200: C9200-24T, C9200-24P, C9200-24PB, C9200-24PXG, C9200-48T, C9200-48P, C9200-48PL, C9200-48PB, C9200-48PXG C9200L: C9200L-24T-4G, C9200L-24P-4G, C9200L-48T-4G, C9200L-48P-4G, C9200L-48PL-4G, C9200L-24T-4X, C9200L-24P-4X, C9200L-48T-4X, C9200L-48P-4X, C9200L-48PL-4X, C9200L-24PXG-4X, C9200L-48PXG-4X, C9200L-24PXG-2Y, C9200L-48PXG-2Y C9200CX: C9200CX-12T-2X2G, C9200CX-12P-2X2G, C9200CX-8P-2X2G, C9200CX-8UXG-2X, C9200CX-12P-2XGH, C9200CX-8P-2XGH, C9200CX-8UXG-2XH |
IOS XE 17.15.3 |
| C9200CX-8PT-2G | IOS XE 26.1.1 | |
All Catalyst 9300 (incl. C9300L and C9300X) |
C9300X: C9300X-24HX, C9300X-12Y, C9300X-24Y, C9300X-48HX, C9300X-48HXN, C9300X-48TX C9300: C9300-24T, C9300-48T, C9300-24P, C9300-48P, C9300-24U, C9300-48U, C9300-24UX, C9300-48UXM, C9300-48UN, C9300-24UB, C9300-24UXB, C9300-48UB, C9300-24H, C9300-48H, C9300-24S, C9300-48S C9300LM: C9300LM-24U-4Y, C9300LM-48T-4Y, C9300LM-48U-4Y, C9300LM-48UX-4Y C9300L: C9300L-24T-4G, C9300L-24T-4X, C9300L-48T-4G, C9300L-48T-4X, C9300L-24P-4G, C9300L-24P-4X, C9300L-48P-4G, C9300L-48P-4X, C9300L-48PF-4G, C9300L-48PF-4X, C9300L-24UXG-4X, C9300L-24UXG-2Q, C9300L-48UXG-4X, C9300L-48UXG-2Q |
IOS XE 17.15.3 |
| Catalyst 95001 |
C9500-48Y4C, C9500-24Y4C, C9500-32C, C9500-32QC C9500-12Q, C9500-16X, C9500-24Q,C9500-40X |
IOS XE 17.15.3 |
| C9500X-28C8D, C9500X-60L4D |
IOS XE 26.1.2 | |
| Catalyst C94002 | C9404R, C9407R, C9410R C9400X-SUP-2, C9400X-SUP-2XL |
IOS XE 26.1.2 |
| Catalyst C96062 | C9606R C9600-SUP-1, C9600X-SUP-2 |
IOS XE 26.1.2 |
1 During onboarding of a C9500 to Device Configuration mode, device tracking will not be modified. Users can choose to modify it via CLI after onboarding.
2 StackWise Virtual is not supported on C9400 or C9606. SVL support will be added in a later IOS XE release.
Switches labeled with -M, such as the C9300-M, are fully cloud-managed (configuration source: cloud) and do not require onboarding in device config mode. Claim them like any Meraki device using the Cloud ID physically labeled on the device.
Supported Cisco C9000 Smart Switching Models
| Cisco C9610 Series1 | C9610 | IOS XE 17.18.2 |
| Cisco C9350 Series |
C9350-24T, C9350-48T, C9350-48TX, C9350-48HX, C9350-24P, C9350-48P, C9350-24U, C9350-48U |
IOS XE 17.18.2 |
| C9350-24HX, C9350-48HXN | IOS XE 26.1.1 | |
| C9350-24S, C9350-48S | IOS XE 26.1.2 | |
| C9350-12Y, C9350-24Y, C9350-48HM, C9350-48HXG | IOS XE 26.2.1 | |
| Cisco C9550 Series |
C9550-48L4CD, C9550-24L4CD, C9550-96L4D, C9550-32C, C9550-64C-XL |
IOS XE 26.2.1 |
1 StackWise Virtual is not supported on C9610.
Please note that for Cisco C9000 Smart Switches, the command lines are different from those of Catalyst 9000 switches:
- show cloud-mgmt: to retrieve Cloud ID or confirm cloud tunnel connection status
- service cloud-mgmt connect: to initiate communication with cloud
Prerequisites for Onboarding a Cisco Catalyst or Smart Switch in Device Configuration Mode:
- Uplink connectivity (from the switch to the cloud and not connectivity to the computer being used) must be via a front-panel port (not the management interface).
- Only the default VRF is supported.
- Ensure routes are in place to reach external addresses including a default route (use of ip default-gateway is not supported).
- Example: ip route 0.0.0.0 0.0.0.0 <next-hop-IP>
- IP routing (ip routing) must be enabled on the switch.
- AAA on the switch must be configured using aaa new-model.
- AAA authentication must permit local login and authorization must allow exec for local accounts. This permits the automatically provisioned service account to access the switch from Dashboard following initial onboarding.
- The user account for onboarding must have privilege-15 level access on the switch.
If TACACS or RADIUS authentication/authorization is used, local must be first in the authentication/authorization list prior to TACACS or RADIUS servers.
Multi-Factor Authentication (MFA) is not supported.
Before onboarding Catalyst switches, verify that the network runs a firmware version that supports the intended configuration source mode. Networks running older firmware versions may not display the option to select between available configuration source modes during onboarding.
If the switches do not meet the minimum required software version, download the appropriate image from the Software Download Page.
Verify Meraki Tunnel Prerequisites on the switch.
The Meraki Tunnel only supports the Global VRF.
Domain Name Lookup is required for hostname resolution to the Dashboard Registration and Meraki Tunnel services.
- ip name-server {Domain server IP address}
- ip domain lookup
The switch clock must reflect the correct current time in order to establish a mutual TLS tunnel with the Registration and Meraki Tunnel services. Enabling NTP is recommended to accomplish this.
- ntp server {ntp server IP address}
Prior to adding a switch in device configuration mode, ensure it is disconnected from its current cloud connection, such as Cloud Monitoring. Switches that are currently connected to the Dashboard via Cloud Monitoring have to be removed from their Dashboard network before they can be enabled for cloud management with device configuration. For detailed instructions, refer to Upgrading Cloud-Monitored Switches to Cloud Management with Device Configuration.
The Meraki tunnel for modular switches will form only when the chassis and supervisor(s) have been added to a dashboard network.
Known Issues and Limitations
- Running
show ip http server allMay Cause SSH Session Disruption (IOS XE 17.15.3, 17.15.4, and 17.15.4b):- Running the show ip http server all command on Cisco Catalyst 9200, 9300, and 9500 Series switches running IOS XE 17.15.3, 17.15.4, and 17.15.4b versions may cause all SSH sessions to hang or drop and prevent new SSH connections. All vty lines may become occupied and cannot be cleared without rebooting the switch. This can result in reporting the switch as offline. Avoid running this command in production environments.
- Fix: This issue is resolved in IOS XE 17.15.5 and will be included in the future IOS XE 17.18.3 and subsequent versions.
- Onboarding Limit for Catalyst Devices in Configuration Source: Device
- When onboarding Catalyst devices in configuration source: device, onboarding more than 10 switches may fail with an 'Internal Server Error'. To resolve this, onboard switches in batches of 10 or fewer.
- Port Channel Subinterfaces are Not Supported as Routed Uplinks in Configuration Source: Device
- When a Catalyst switch uses a port-channel subinterface (e.g. Port-channel 14.1460), Dashboard cannot resolve a valid uplink for the switch. As a result, the uplink arrow does not appear in Dashboard and uplink telemetry is not populated.
Conversion Steps from DNA Management Mode to Cloud Management with Device Configuration
Step 1: Initiate Registration with the Cloud
To begin, the switch-side service in IOS XE must be enabled to initiate communication with the cloud.
While in configuration mode on the switch, enter either command:
- For Catalyst 9000 switches: service meraki connect
- or For Cisco 9000 smart switches: service cloud-mgmt connect
Example:
C9300-switch#conf t Enter configuration commands, one per line. End with CNTL/Z. C9300-switch(config)#service meraki connect C9300-switch(config)#end
- After enabling the service for the first time, the tunnel may take few minutes to connect.
- To confirm the Catalyst 9000 switch has successfully registered and the Meraki Tunnel is connected, use:
- For Catalyst 9000 switches: show meraki connect command;
- Or for Cisco 9000 smart switches: show cloud-mgmt
- The tunnel state should be Up.
- If the tunnel is not up, make sure to verify the correct firewall rules are in place. Additional details on connection attempts are available in the syslog (show logging).
- The output will provide the required Cloud ID to claim the switch to a Dashboard network.
For example, the output of a successful connection may appear similar to:
The Cloud ID in the last section for Meraki Device Registration will be used to claim and register the switch in Dashboard.
Please note, for Cisco 9350 smart switches, your switch comes with CloudID labels on the box and order confirmation email. The Cloud ID from your device command and the label will match, so you can use either for the next step.
For C9610, please follow step 1 above to retrieve Cloud ID from command before claiming to the inventory.
- When adding stacked switches, all members of the stack should be selected to add to network.
- Organizations using Per‑Device Licensing (PDL) must add Catalyst switches through Network‑wide > Add devices. For more information, see Adding and Removing Devices from Dashboard Networks.
Step 2: Onboard the Switch to Meraki Dashboard Using Cloud ID
To continue, log in to Dashboard and navigate to Organization > Inventory.
Click Claim Devices.
- Click Claim Individual Devices.
Note: You can enter one or more Cloud IDs from your Catalyst switches.
- After claiming the devices, on the Inventory page, select the checkbox next to the switches you would like to enable for cloud management.
* You can now select up to 100 Catalyst switches to onboard in device configuration mode at a time. Please see below bulk onboarding section for details.
Modular switch chassis and supervisors have separate unique cloud IDs. All modular switch cloud IDs must be added to the same network.
When adding Catalyst switch stacks to a network, make sure to include all stack members.
- In the Add devices to network window, choose the Dashboard Network for your switch and click Next.
- Select Device configuration and enter level-15 privilege credentials for the switch(es).
Note: Credentials are used to connect to your switch and update the configuration for use with device configuration.
The configuration lines will be automatically applied to your switch are available here: Cloud Management with Device Configuration Required Modification.
After confirming the details and completing the process, the configuration will be automatically applied to your switch.
You can view your switch(es) in the Dashboard by navigating to Switching > Switches. If you have added your switches, an alert will appear for a few minutes while the setup finalizes. Allow up to 15 minutes for the process to complete and for the data to update in the Dashboard.
Bulk Onboarding in Device Configuration Mode
You can now select up to 100 Catalyst switches to onboard in device configuration mode at a time. Things to know:
When adding Catalyst switch stacks or a modular switch to a network, ensure all stack members/chassis and supervisors are included.
Please select only supported Catalyst switches when proceeding bulk onboarding of >50 devices.
Do not refresh the page or navigate away while the "Add Devices to Network" pop-up window (see the screenshot below) is open. This step will take approximately 5 minutes for 100 devices.
- Onboarding 100 devices and syncing their data will take approximately one hour.
Once the switches have been added to the network, navigate to Switching > Switches to view the switch list page. You will see the device onboarding status in the column next to the switch name.
Status and definition
| Status | Definition |
| Onboarding | Onboarding in progress |
| Removing | Device is being removed |
Known Issues and limitations:
- 'Onboarding label' may clear as soon onboarding is completed. Data sync will be triggered post onboarding completion.
- 'Never connected to cloud' alert may temporarily appear for stack members; onboarding completes once the stack is detected
- Stack members may display a console connection alert if the Active and Standby units have not yet been onboarded. These alerts will resolve automatically once the Active and Standby units are successfully onboarded. (When adding Catalyst switch stacks to a network, make sure to include all stack members.)
- No 4 consecutive VTY on the device alert remains active and blocks onboarding even after CLI correction ; the system retries validation three times at five-minute intervals, resolving automatically within 15–20 minutes if lines are available, or resolution may take up to 24 hours.
Managing Local CLI Changes Post-Reload
Following a device reload or tunnel re-establishment, the Dashboard may apply any missing Dashboard-managed configurations and execute a write memory operation. This action saves the entire running configuration to the startup configuration; consequently, any unrelated, unsaved local CLI changes present at that time may also be persisted. We recommend verifying device configurations after a reload to ensure that all local CLI changes remain as intended.
Use below commands to verify:
show running-config | include show tech-support|show memory show startup-config | include show tech-support|show memory
Example output if all local CLI changes remain as intended:
show running-config | section parser view MERAKI-CONFIG show startup-config | section parser view MERAKI-CONFIG
If re-apply is needed, use below commands to re-apply and re-verify
conf t parser view MERAKI-CONFIG inclusive commands exec exclude all show tech-support commands exec exclude all show memory end
Removing a Switch from Dashboard (Device Configuration Mode)
When a Cisco Catalyst or Cisco Smart Switch operating in cloud management with device configuration mode is removed from the Meraki Dashboard, the onboarding and telemetry configuration is removed.
If the switch is removed while the Meraki management tunnel is active, an Embedded Event Manager (EEM) cleanup script runs on the device. The script completes within approximately 15 minutes. After the cleanup completes, the no service meraki connect command can be issued on the switch to complete offboarding.
See Cloud Management with Device Configuration Required Modifications for additional details.
