Combined Power on MS Devices
Overview
Combined Power allows switches with two power supply modules draw power from both modules at the same time.
Switches with two power supply modules are designed to use them in redundant mode. In this setup, only one module powers the switch at a time, while the other stays on standby to take over if the first module fails.
The second power supply module, called Combined Power, provides PoE power up to its maximum rated limit while acting as a standby power supply for the switch control system. If the primary power supply module fails, the secondary module maintains uninterrupted power to the switch and adjusts PoE power provisioning as explained in the "Power Budgeting with Combined Power" section.
Combined Power Supported Models: MS350, MS355 and MS390 Series. MS390, C9300 and Catalyst-based Meraki-managed switches always operate in Combined Power mode.
Configuring Combined Power
To configure the power mode, go to Switch > Configure > Switch Settings. Select either Redundant power or Combined power as the default power supply setting for the switches in your network. If some switches should not use the default setting, assign them to a power mode using custom lists in the power supply settings exceptions section.
A snapshot of switch power supply settings in the Meraki Dashboard, allowing users to choose between redundant or combined power modes and set specific power supply exceptions.
This option is available only when the switch has two power supply modules installed and powered. It applies to switches running firmware MS 11.0 or later.
Switch Family
Switch Model
Combined Power Budget
MS350
MS350-24P 720W
MS350-48LP 740W
MS350-48FP 1440W
MS350-24X 1440W
MS355
MS355-24X 1440W
MS355-24X2 1440W
MS355-48X 1480W
MS355-48X2 1480W
MS390
MS390-24P 720W
MS390-24U 1440W
MS390-24UX 1440W
MS390-48P 1152W
MS390-48U 1800W
MS390-48UX 1590W
MS390-48UX2-HW 1745W
The switches budget power based on the PoE device classification. The budget can exceed the available power to estimate the total power that might be used. Devices will keep receiving power until consumption exceeds the available power or a power supply module fails. If a failure occurs, lower port numbers have priority, and power will be cut from higher port numbers, denying them power.
