SmartPorts
Click 日本語 for Japanese
Port Profiles are now a part of SmartPorts.
For MS switches and Catalyst switches (cloud management with IOS XE 17.18.2+), SmartPorts - Automations is currently available in Early Access. To use this feature, please enable SmartPorts from the Organization > Configure > Early Access page on your Meraki dashboard. To use APIs for Early Access features, also enable Early API Access via the same Early Access page.
What to expect when enabling SmartPorts:
When you opt into SmartPorts, you will notice the following changes related to how you access the feature:
  • The menu option for Switching > Configure > Port Profiles will change to Switching > Configure > SmartPorts for Network administrators.
  • The menu option for Switching > Configure > Port Profiles will move to Organization > Configure > SmartPorts for Organization administrators.
For switches running IOS-XE versions earlier than 26.1, you must limit SmartPort Profile names to 16 or fewer characters. This restriction is removed in IOS-XE 26.1.1 and later.
Overview
SmartPorts aim to solve the problem of highly-repetitive and error-prone port configurations. Whether you have the same or a variety of port settings and attributes at each of your sites, SmartPorts allow you to create a set of attributes once (the Profile). You can then bind the Profile to one or thousands of ports, making initial and ongoing configuration a breeze.
With SmartPorts, a Profile can be bound directly to a port from its configuration UI, or assigned to it dynamically, with the help of Automation. An Automation is a user-defined sequential logic that allows the switch to detect and identify the device connected on a port and modify the port’s configuration using profiles.
Requirements, Guidelines, and Limitations
HW and SW Requirements
Platform Software Requirement
MS Switches
MS120, MS125, MS130, MS130R, MS150, MS210, MS225, MS250, MS350, MS355, MS410, MS425 and MS450 series switches
While there are no minimum firmware requirements for Profiles, MS 15.21.1 or later is recommended.
Firmware MS 17 introduces support for Automations.
Catalyst Switches
All supported C9000 and MS390 switches in Cloud Management with Cloud Configuration running IOS XE 17.18.1+
SmartPort Profile: 17.18.1+
SmartPort Automations: 17.18.2+ (via Early Access)
All supported C9350 smart switches
SmartPort Profile: 26.1.1+
SmartPort Automations: Currently not supported
  1. Role-based access: SmartPorts allow Profiles and Automations to be created and managed at either the Organization-wide or Network-wide level. A user can access the feature either via the Organization menu or the Switching menu, depending on their administrator privileges.
  2. Automations are currently only supported in the Organization-wide scope. Only Organization-wide profiles can be applied using Automations.
  3. Automations and Organization-wide Profiles do not support Network-level configuration components such as Access policies.
  4. Multiple Automations can be applied on a single switch but only one automation assigned per port.
  5. SmartPorts are currently not supported in Configuration Templates or networks bound to them.
  6. SmartPorts are currently not supported in networks enabled for SecurePort (for details on SecurePort, please refer to our Secure-Port documentation).
Org-wide profiles cannot be modified to network-specific profiles, and vice versa. If you need to make this change you will have to delete the profile and re-add it with the correct settings.
How a SmartPorts Automation Works
A SmartPorts Automation inspects the incoming traffic on a switch port for user-defined match conditions and applies different configurations to the switch port, depending on which conditions are matched. The configurations to be applied upon a match are defined using SmartPorts Profiles.
A match condition is a combination of Match type and Match criteria. Match type is the kind of information a switch will look into in the traffic received on the port. Supported match types are LLDP system description and MAC address. Match criteria is one or more, comma-separated values to be matched for the selected match type.
Match criteria support the use of * (asterisk) as a wild card. The supported syntaxes for match criteria are:
  1. A case sensitive string for the LLDP system description value(s), such as Meraki MV32 Cloud Managed Security Camera or Meraki MV*.
  2. MAC address in any of the following formats: aabbccddeeff, aa:bb:cc:dd:ee:ff, aa-bb-cc-dd-ee-ff, aabb.ccdd.eeff. Wildcards can be used with any of the formats for a generic match such as aa:bb:cc*.
An Automation is a sequence of rules, each of which is a collection of one or more match conditions. Match conditions in a rule operate as a logical AND. That is, all conditions in a rule should match for the rule to be considered a match. For this reason, a match type can be used only once per rule. For example, multiple match conditions for LLDP system description cannot be added in a single rule. If there are multiple LLDP system description values, they should be entered as comma-separated values in the match criteria instead. Values provided in the match criteria operate as a logical OR, which means that any one of them being matched will be sufficient for the condition to be considered a match.
A rule, when matched, applies a single profile to the switch port. Each automation allows a default action to be used if no rules are matched. The default action can be used to apply a specific profile on the ports or leave their configuration unmodified.
When an automation is enabled on a switch port, the switch monitors the traffic coming in on the port for a short period of time after the port is enabled or a connection is detected on it. At the end of the monitoring period, the profile mapped to the rule that has been matched is applied to the port. If multiple rules are matched, the rule with the lowest sequence number in the automation is considered as the match.
Configuration
Creating a Profile
  1. Navigate to Switching > Configure > SmartPorts > Profiles or Organization > Configure > SmartPorts > Profiles, depending on your user privileges.
  2. Click Add profile to create a new SmartPorts Profile.
  3. Enter the required details and configuration, and click Save.
Application via RADIUS AV-pair (optional)
Available on MS Classis firmware version on and above MS 19 beta
Using this option, a SmartPorts profile can be dynamically assigned to a switch port based on the authorization  sent by a RADIUS server (like Cisco ISE) for a connected client. Following is recommended configuration and expected behavior:
  1. Enable the Application via RADIUS AV-pair > Enter a value that matches with the interface template name sent by the RADIUS server.
  2. RADIUS Configuration:
    On the RADIUS server, for example on Cisco ISE, configure the Authorization Profile to include Interface Template attribute, ensuring its value matches the name specified in the previous step.
    If you’re using a different RADIUS server, configure the attribute Cisco-AVpair="interface:template=name".
  3. Expected behavior:
    • A client connects to the switchport and authenticates against ISE.
    • ISE returns the matching authorization profile containing the RADIUS AV-pair: "Interface:Template = cameras-interface-template-ise".
    • The switch compares the received value with the values on the available SmartPort Profiles.
    • The matching SmartPort Profile, in this case "Cameras" is applied to the switch port.
    • When the RADIUS session ends, the SmartPort Profile is removed from the port.
  4. Verification:
    • To confirm that the switch has applied the correct SmartPort Profile, execute the following command on the switch CLI and compare its output with the configuration of the Profile created in the previous step.
Switch# show derived-config interface Gi1/0/10
Building configuration...
Derived configuration : 108 bytes
interface GigabitEthernet1/0/12
switchport mode trunk
end
Applying the Profile to Switch Ports
  1. Navigate to Switching > Monitor > Switch Ports.
  2. Select all the ports you want to apply the profile to, and click on Edit to bring up the port configuration UI.
  3. Toggle SmartPorts profile to Enabled to expose the SmartPorts profile name drop-down list.
  4. Select the profile you want to apply and click on the Update button.
Applying a port profile configuration to port(s) in the Meraki Dashboard.
To apply a profile on a single switch port, you could also use the following approach:
  1. Navigate to Switching > Monitor > Switches.
  2. Click on the switch, and then on the switch port you want to apply the profile to.
  3. Click on the pencil icon next to Configuration to bring up the port configuration UI.
  4. Toggle SmartPorts profile to Enabled to expose the SmartPorts profile name drop-down list.
  5. Select the profile you want to apply and click on the Update button.
Editing a Profile
  1. Navigate to Switching > Configure > SmartPorts > Profiles.
  2. Click on the pencil icon for the SmartPorts profile you want to edit.
  3. Modify the configuration, and click Save.
When you modify a profile, the configuration change is instantly propagated to all the ports bound to that profile.
Removing a Port Profile
There are two different ways you can remove a port profile that is attached to a switch port:
1. When accessing the individual switch in the dashboard, you can simply select the desired port and uncheck the port profile "Enabled" checkbox. This will remove any attached port profile on that particular switch port.
Disabling port profile from a single port in the Meraki Dashboard.
2. Another option is go under the "Switching > Monitor > Switch Ports" page on the dashboard and then select the desired ports. Then you can edit these ports and remove the attached port profile by clicking on "X" icon next to the SmartPorts profile name (as shown below).
Removing port profile from multiple ports in the Meraki Dashboard.
Creating an Automation
To be able to create automations, valid profiles should have been created in the Organization-wide scope. For more information on how to create SmartPorts profiles, refer to the Creating a Profile section above.
  1. Depending on your administrator privileges, navigate to Switching > Configure > SmartPorts > Automations or Organization > Configure > SmartPorts > Automations, and click on Add automation.
    Automations tab of the SmartPorts page showing the "Add automation" blue button in the Meraki Dashboard.
  2. Click Add trigger to bring up the Automation sequence drawer where the trigger logic can be defined.
    Creating a new automation configuration details in the Meraki Dashboard.
  3. Specify one or more conditions to be matched, and choose the profile to be applied if the rule is matched. Click Add to save the rule.
    If an Automation sequence has multiple conditions, all of them should match for the Automation rule to be considered a match.
    A condition is matched if the value provided in the match criteria is found in the traffic received on the port for the specified match type. If the match criteria is a comma-separated list of values, only one of them needs to be found for the condition to be matched.
    To learn more about match type, match criteria, automation sequences and the relationship between them, please refer to the How a SmartPorts automation works section.
  4. Add additional rules as necessary.
  5. Choose a default action to be performed if no rules are matched. Here you can choose to retain the existing port configuration, i.e., leave the port configuration unmodified, or apply a specific profile.
  6. Optional: Click on the pencil icon for Target port range to apply the automation to multiple switch ports. Refer to the Applying an automation to switch ports : from the SmartPorts UI section for details.
  7. Click Save.
Applying an Automation to Switch Ports
From the SmartPorts UI
  1. Depending on your administrator privileges, navigate to the Automations tab on Switching > Configure > SmartPorts > Automations or Organization > Configure > SmartPorts > Automations, and select the automation to be applied.
  2. Click on the pencil icon for Target port range.
                                 Target port range configuration in the Meraki Dashboard.
  3. Use the search and network filters to find and select the switches. Selecting a switch will automatically populate all of its ports in the Port Range field. Please modify the range as needed.
    Applying an automation to all ports of a switch or to its uplink port can affect the switch’s connectivity to the Meraki dashboard. Please ensure that the automation does not conflict with the required uplink port configuration before applying it to an uplink port.
    The auto-populated port-range excludes the current uplink port for each switch.
  4. Click Update to apply to go back to the Update automation page.
  5. Click Update to apply the automation on the switch ports.
From the Switch Ports Page
  2. Select all the ports you want to apply the automation to, and click on Edit to bring up the port configuration UI.
  3. Select the automation you want to apply from the Port automation drop-down list, and click on the Update button.
                      Port automation drop-down list from the switch ports page in the Meraki Dashboard.
From the Switch Details Page
To apply an Automation on a single switch port, you could also use the following approach:
  4. Select the automation you want to apply from the Port automation drop-down list, and click on the Update button.
Editing an Automation
  1. Depending on your administrator privileges, navigate to the Automations tab on  Switching > Configure > SmartPorts > Automations or Organization > Configure > SmartPorts > Automations.
  2. Click on the automation name or the … icon > Edit on the right end of the row.
    When you modify an automation, the configuration change is instantly propagated to all the ports bound to that automation.
The port details UI of a port configured to use a SmartPorts profile displays a banner highlighting that the feature is overriding its original configuration. The port settings on this screen are updated to reflect the configuration implemented by the SmartPorts profile.
                            "Port configured using port profile" banner verifying the configuration's implementation.
Clicking on See configuration comparisons brings up the configuration comparison table, which shows the settings that have been modified by the profile.
                               Configuration comparison table.
The configurations from SmartPorts profiles are not currently reflected in the ports tables on the Switch > Monitor > Switch ports page and the Ports tab on the switch details page.
Note: We are aware of an issue where the banner and configuration comparison UI might not show up on some ports where an Automation has applied a Profile. We expect this issue to be resolved soon.
The application of a profile as a result of an automation can be verified from the switch's Event logs.
To monitor the usage of SmartPorts, navigate back to the Profiles tab on the Switching > Configure > SmartPorts or Organization > Configure > SmartPorts  page. Each profile shows the number of ports, devices and networks it is currently active on. Clicking on a profile's port link redirects you to the Switch Ports page, filtered for the ports using the profile.
Profiles tab of the SmartPorts page listing the profiles in the Meraki Dashboard.
Similarly, for Automations, the number of ports, devices and networks where it is active is listed against each automation.
Automations tab of the SmartPorts page listing details of each automation in the Meraki Dashboard.
