Video Retention
Overview
Smart Retention
Enabling Smart Retention on eligible cameras is highly recommended. Refer to Smart Retention for more information.
MV84X cameras do not support standard retention and default to Smart Retention.
Video retention expectations
Higher resolution and quality settings, along with more motion in the camera's view, reduce video retention. Users can adjust resolution, quality, and the amount of motion to increase retention. Motion-based retention and Cloud Archive, explained later in the article, can also help extend retention.
Not all motion affects retention equally. Factors such as lighting, camera height and angle, distance to moving objects, the number and size of objects, and background motion can all influence video retention.
Typical amounts of motion for various deployments
Motion in a scene impacts video retention. When selecting a camera and video settings, consider the expected motion the camera will capture in its deployment. Below are general guidelines for typical motion levels in different deployment scenarios. For more information on motion detection, click here.
| Deployment type | Typical motion (hours per day) |
| Busy retail locations | 16-24 |
| Busy roads, intersections | 16-24 |
| Building entrances, lobby areas | 8-16 |
| Office spaces and hallways | 8-16 |
| Elementary school, high school, and college/university spaces | 0-8 |
| Parking lots | 0-8 |
| Warehouses, manufacturing spaces | 0-8 |
| IT closets, storage closets | 0-8 |
Smart Codec
Smart Codec was developed to significantly improves video retention by using efficient and dynamic encoding during recording. It is automatically enabled on cameras with firmware version MV4.15 or newer. Click here for more information.
Video retention estimates by camera model
The tables below show video retention statistics by camera model, video resolution, quality settings, and daily motion levels. The data comes from Meraki cameras running the latest firmware. Use this information to estimate expected retention based on selected settings and observed motion.
"Low" and "high" values represent the typical range of retention days. "Absolute minimum" values represent the lowest retention for cameras with constant high motion.
To improve video retention, follow recommended physical installation guidelines and ensure cameras are running the latest firmware. Retention estimates may vary as each deployment is unique.
On MV13 and MV33, 4MP 24 FPS and 4K 15 FPS are enabled on MV6.0.2+.
On MV63 and MV93, 4K resolutions are enabled on MV6.0.2+.
The results below include the improvements gained from Smart Codec. The results do not include improvements from Motion-Based Retention and Cloud Archive (discussed later in this article). Enabling Motion-Based Retention and/or Cloud Archive can further improve retention estimates if desired.
MV12WE
| MV12WE Retention Estimates (days) | ||||||||||
| Motion (hrs/day) | 0-8 | 8-16 | 16-24 | Max Motion | ||||||
| Resolution | Video Quality | Frame Rate | Per Stream Bandwidth Usage (kbps) | Low (days) | High (days) | Low (days) | High (days) | Low (days) | High (days) | Absolute Min (days) |
| 720p | Standard | 8 fps | 500 | 53 | 70 | 48 | 66 | 40 | 65 | 21 |
| 720p | Enhanced | 15 fps | 765 | 34 | 44 | 31 | 41 | 29 | 38 | 14 |
| 1080p | Standard | 8 fps | 1024 | 21 | 33 | 19 | 28 | 17 | 26 | 10 |
| 1080p | Enhanced | 15 fps | 1562 | 15 | 21 | 13 | 19 | 13 | 17 | 7 |
| 1080p | High | 24 fps | 3138 | 7 | 11 | 7 | 9 | 5 | 8 | 3 |
MV12W/N
| MV12W/N Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 110 | 142 | 106 | 140 | 99 | 137 | 43 |
| 720p | Enhanced | 15 fps | 765 | 70 | 88 | 63 | 82 | 49 | 73 | 28 |
| 1080p | Standard | 8 fps | 1024 | 43 | 66 | 39 | 58 | 37 | 54 | 21 |
| 1080p | Enhanced | 15 fps | 1562 | 28 | 42 | 24 | 38 | 22 | 33 | 14 |
| 1080p | High | 24 fps | 3138 | 14 | 21 | 13 | 18 | 11 | 17 | 7 |
MV22
| MV22 Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 102 | 142 | 92 | 135 | 86 | 135 | 44 |
| 720p | Enhanced | 15 fps | 765 | 68 | 86 | 63 | 82 | 51 | 75 | 29 |
| 1080p | Standard | 8 fps | 1024 | 42 | 65 | 39 | 57 | 34 | 52 | 21 |
| 1080p | Enhanced | 15 fps | 1562 | 27 | 42 | 26 | 37 | 22 | 35 | 14 |
| 1080p | High | 24 fps | 3138 | 13 | 21 | 12 | 18 | 11 | 16 | 7 |
MV22X
| MV22X Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 217 | 285 | 189 | 278 | 149 | 265 | 91 |
| 720p | Enhanced | 15 fps | 765 | 133 | 181 | 131 | 163 | 124 | 149 | 59 |
| 1080p | Standard | 8 fps | 1024 | 80 | 123 | 79 | 121 | 72 | 115 | 44 |
| 1080p | Enhanced | 15 fps | 1562 | 56 | 86 | 54 | 80 | 53 | 75 | 30 |
| 1080p | High | 24 fps | 3138 | 28 | 43 | 25 | 36 | 21 | 32 | 14 |
| 4MP | Standard | 8 fps | 3096 | 21 | 32 | 20 | 28 | 19 | 25 | 15 |
| 4MP | Enhanced | 15 fps | 8192 | 8 | 13 | 8 | 11 | 7 | 10 | 6 |
MV72
| MV72 Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 104 | 142 | 93 | 140 | 91 | 139 | 44 |
| 720p | Enhanced | 15 fps | 765 | 59 | 86 | 58 | 84 | 53 | 78 | 29 |
| 1080p | Standard | 8 fps | 1024 | 39 | 61 | 38 | 58 | 35 | 54 | 21 |
| 1080p | Enhanced | 15 fps | 1562 | 26 | 41 | 25 | 37 | 23 | 35 | 14 |
| 1080p | High | 24 fps | 3138 | 13 | 20 | 13 | 18 | 12 | 17 | 7 |
MV72X
| MV72X Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 220 | 291 | 202 | 289 | 189 | 282 | 91 |
| 720p | Enhanced | 15 fps | 765 | 130 | 176 | 123 | 174 | 122 | 172 | 59 |
| 1080p | Standard | 8 fps | 1024 | 79 | 119 | 75 | 112 | 72 | 111 | 44 |
| 1080p | Enhanced | 15 fps | 1562 | 57 | 83 | 52 | 77 | 47 | 71 | 30 |
| 1080p | High | 24 fps | 3138 | 25 | 39 | 24 | 36 | 23 | 34 | 14 |
| 4MP | Standard | 8 fps | 3096 | 20 | 31 | 20 | 28 | 18 | 27 | 15 |
| 4MP | Enhanced | 15 fps | 8192 | 7 | 11 | 7 | 11 | 7 | 11 | 6 |
MV52
| MV52 Retention Estimates (days) | ||||||||||
| 720p | Standard | 8 fps | 500 | 563 | 585 | 524 | 577 | 523 | 570 | 181 |
| 720p | Enhanced | 15 fps | 765 | 338 | 369 | 326 | 367 | 269 | 366 | 119 |
| 1080p | Standard | 8 fps | 1024 | 183 | 274 | 182 | 267 | 160 | 251 | 89 |
| 1080p | Enhanced | 15 fps | 1562 | 123 | 180 | 121 | 169 | 117 | 161 | 58 |
| 1080p | High | 20 fps | 3138 | 64 | 83 | 61 | 82 | 55 | 75 | 29 |
| 4MP | Standard | 8 fps | 3096 | 49 | 85 | 45 | 84 | 43 | 71 | 29 |
| 4MP | Enhanced | 15 fps | 8192 | 18 | 28 | 18 | 27 | 17 | 26 | 11 |
| 4K (8MP) | Standard | 8 fps | 5000 | 28 | 47 | 27 | 45 | 27 | 39 | 18 |
| 4K (8MP) | Enhanced | 15 fps | 8000 | 19 | 28 | 17 | 27 | 16 | 24 | 11 |
MV32
| MV32 Retention Estimates (days) | ||||||||||
| 1080 x 1080 | Standard | 8 fps | 1024 | 41 | 61 | 40 | 59 | 36 | 53 | 21 |
| 1080 x 1080 | Enhanced | 8 fps | 2048 | 20 | 31 | 19 | 30 | 19 | 28 | 11 |
| 2112 x 2112 | Standard | 8 fps | 1024 | 29 | 42 | 27 | 40 | 26 | 36 | 21 |
| 2112 x 2112 | Enhanced | 8 fps | 3096 | 9 | 14 | 9 | 13 | 9 | 12 | 7 |
| 2112 x 2112 | High | 15 fps | 5120 | 5 | 8 | 5 | 8 | 5 | 7 | 4 |
MV63
| MV63 Retention Estimates (days) | ||||||||||
| 1080p | Standard | 8 fps | 950 | 60 | 81 | 58 | 77 | 57 | 71 | 23 |
| 1080p | Enhanced | 15 fps | 1400 | 31 | 41 | 30 | 40 | 29 | 39 | 15 |
| 1080p | High | 24 fps | 2800 | 15 | 20 | 15 | 19 | 15 | 18 | 8 |
| 4MP | Standard | 8 fps | 2800 | 20 | 25 | 15 | 23 | 15 | 21 | 8 |
| 4MP | Enhanced | 15 fps | 6000 | 6 | 9 | 5 | 8 | 5 | 7 | 4 |
| 4MP | High | 24 fps | 9000 | 4 | 7 | 4 | 6 | 3 | 5 | 2 |
| 4K (8MP) | Standard | 8 fps | 4500 | 8 | 11 | 7 | 10 | 6 | 9 | 5 |
| 4K (8MP) | Enhanced | 15 fps | 8000 | 3 | 6 | 3 | 5 | 3 | 5 | 2 |
MV23M/MV63M/MV73M
| MV23M/MV63M/MV73M Retention Estimates (days) | ||||||||||
| 1080p | Standard | 8 fps | 950 | 120 | 161 | 116 | 154 | 114 | 142 | 46 |
| 1080p | Enhanced | 15 fps | 1400 | 62 | 82 | 60 | 80 | 58 | 78 | 30 |
| 1080p | High | 24 fps | 2800 | 30 | 40 | 30 | 38 | 30 | 36 | 16 |
| 4MP | Standard | 8 fps | 2800 | 40 | 50 | 30 | 46 | 30 | 42 | 16 |
| 4MP | Enhanced | 15 fps | 6000 | 12 | 18 | 10 | 16 | 10 | 14 | 8 |
| 4MP | High | 24 fps | 9000 | 8 | 14 | 8 | 12 | 6 | 10 | 4 |
| 4K (8MP) | Standard | 8 fps | 4500 | 16 | 22 | 14 | 20 | 12 | 18 | 10 |
| 4K (8MP) | Enhanced | 15 fps | 8000 | 6 | 12 | 6 | 10 | 6 | 10 | 4 |
MV23X/MV53X/MV63X/MV73X
| MV23X/MV53X/MV63X/MV73X Retention Estimates (days) | ||||||||||
| 1080p | Standard | 8 fps | 950 | 245 | 313 | 239 | 305 | 234 | 291 | 94 |
| 1080p | Enhanced | 15 fps | 1400 | 148 | 171 | 136 | 171 | 117 | 145 | 64 |
| 1080p | High | 24 fps | 2800 | 62 | 75 | 59 | 79 | 52 | 73 | 32 |
| 4MP | Standard | 8 fps | 2800 | 65 | 92 | 52 | 85 | 48 | 81 | 32 |
| 4MP | Enhanced | 15 fps | 6000 | 27 | 43 | 25 | 36 | 23 | 33 | 15 |
| 4MP | High | 24 fps | 9000 | 16 | 22 | 14 | 21 | 14 | 20 | 10 |
| 4K (8MP) | Standard | 8 fps | 4500 | 34 | 44 | 31 | 41 | 27 | 39 | 20 |
| 4K (8MP) | Enhanced | 15 fps | 8000 | 15 | 25 | 14 | 21 | 14 | 20 | 11 |
MV93
| MV93 Retention Estimates (days) | ||||||
| Resolution | Video Quality | Frame Rate | Per Stream Bandwidth Usage (kbps) | Absolute Min (days) | Low (days) | High (days) |
| 1080 x 1080 | Standard | 8 fps | 950 | 23 | 59 | 70 |
| 1080 x 1080 | Enhanced | 15 fps | 1400 | 16 | 30 | 43 |
| 1080 x 1080 | High | 24 fps | 2800 | 8 | 13 | 22 |
| 2112 x 2112 | Standard | 8 fps | 2800 | 8 | 16 | 23 |
| 2112 x 2112 | Enhanced | 15 fps | 6000 | 3 | 6 | 9 |
| 2112 x 2112 | High | 24 fps | 9000 | 2 | 4 | 6 |
| 2880 x 2880 | Standard | 8 fps | 4500 | 5 | 9 | 12 |
| 2880 x 2880 | Enhanced | 15 fps | 8000 | 2 | 4 | 7 |
MV93M
| MV93M Retention Estimates (days) | ||||||
| 1080 x 1080 | Standard | 8 fps | 950 | 47 | 118 | 140 |
| 1080 x 1080 | Enhanced | 15 fps | 1400 | 32 | 61 | 86 |
| 1080 x 1080 | High | 24 fps | 2800 | 16 | 27 | 44 |
| 2112 x 2112 | Standard | 8 fps | 2800 | 16 | 33 | 46 |
| 2112 x 2112 | Enhanced | 15 fps | 6000 | 7 | 13 | 19 |
| 2112 x 2112 | High | 24 fps | 9000 | 5 | 9 | 13 |
| 2880 x 2880 | Standard | 8 fps | 4500 | 10 | 18 | 25 |
| 2880 x 2880 | Enhanced | 15 fps | 8000 | 5 | 8 | 14 |
MV93X
| MV93X Retention Estimates (days) | ||||||
| 1080 x 1080 | Standard | 8 fps | 950 | 94 | 237 | 281 |
| 1080 x 1080 | Enhanced | 15 fps | 1400 | 64 | 122 | 173 |
| 1080 x 1080 | High | 24 fps | 2800 | 32 | 55 | 88 |
| 2112 x 2112 | Standard | 8 fps | 2800 | 32 | 67 | 93 |
| 2112 x 2112 | Enhanced | 15 fps | 6000 | 15 | 26 | 39 |
| 2112 x 2112 | High | 24 fps | 9000 | 10 | 18 | 27 |
| 2880 x 2880 | Standard | 8 fps | 4500 | 20 | 36 | 51 |
| 2880 x 2880 | Enhanced | 15 fps | 8000 | 11 | 17 | 28 |
MV13
| MV13 Retention Estimates (days) | ||||||
| 1080p | Standard | 8 fps | 950 | 23 | 36 | 60 |
| 1080p | Enhanced | 15 fps | 1400 | 15 | 19 | 39 |
| 1080p | High | 24 fps | 2800 | 8 | 14 | 19 |
| 4MP | Standard | 8 fps | 2800 | 8 | 15 | 18 |
| 4MP | Enhanced | 15 fps | 6000 | 4 | 6 | 9 |
| 4MP | Enhanced | 24 fps | 9000 | 2 | 4 | 6 |
| 4K (8MP) | Standard | 8 fps | 4500 | 5 | 7 | 10 |
| 4K (8MP) | Standard | 15 fps | 8000 | 2 | 4 | 7 |
MV13M
| MV13M Retention Estimates (days) | ||||||
| 1080p | Standard | 8 fps | 950 | 46 | 72 | 120 |
| 1080p | Enhanced | 15 fps | 1400 | 30 | 38 | 78 |
| 1080p | High | 24 fps | 2800 | 16 | 28 | 38 |
| 4MP | Standard | 8 fps | 2800 | 16 | 30 | 36 |
| 4MP | Enhanced | 15 fps | 6000 | 8 | 12 | 18 |
| 4MP | Enhanced | 24 fps | 9000 | 4 | 8 | 12 |
| 4K (8MP) | Standard | 8 fps | 4500 | 10 | 14 | 20 |
| 4K (8MP) | Standard | 15 fps | 8000 | 4 | 8 | 14 |
MV33
| MV33 Retention Estimates (days) | ||||||
| 1080 x 1080 | Standard | 8 fps | 950 | 23 | 40 | 76 |
| 1080 x 1080 | Enhanced | 15 fps | 1400 | 15 | 33 | 40 |
| 1080 x 1080 | High | 24 fps | 2800 | 8 | 14 | 17 |
| 2112 x 2112 | Standard | 8 fps | 2800 | 8 | 18 | 23 |
| 2112 x 2112 | Enhanced | 15 fps | 6000 | 4 | 7 | 10 |
| 2112 x 2112 | Enhanced | 15 fps | 9000 | 2 | 4 | 6 |
| 2880 x 2880 | Standard | 8 fps | 4500 | 5 | 10 | 13 |
| 2880 x 2880 | Standard | 8 fps | 8000 | 2 | 4 | 7 |
MV33M
| MV33M Retention Estimates (days) | ||||||
| 1080 x 1080 | Standard | 8 fps | 950 | 46 | 80 | 152 |
| 1080 x 1080 | Enhanced | 15 fps | 1400 | 30 | 66 | 80 |
| 1080 x 1080 | High | 24 fps | 2800 | 16 | 28 | 34 |
| 2112 x 2112 | Standard | 8 fps | 2800 | 16 | 36 | 46 |
| 2112 x 2112 | Enhanced | 15 fps | 6000 | 8 | 14 | 20 |
| 2112 x 2112 | Enhanced | 15 fps | 9000 | 4 | 8 | 12 |
| 2880 x 2880 | Standard | 8 fps | 4500 | 10 | 20 | 26 |
| 2880 x 2880 | Standard | 8 fps | 8000 | 4 | 8 | 14 |
Video retention can be further extended by enabling motion-based retention. By default, Meraki MV cameras record footage continuously, however in some situations it may be required to only record and store events triggered by motion. Motion-based retention addresses this requirement and can be used to increase video retention of the camera. Click here for more information.
Cloud Archive
Cloud Archive allows extension of video retention by backing up footage to the cloud in addition to storing footage on-camera. Click here for more information.
Checking estimated retention time
To check the estimated retention time of a specific camera, follow these steps:
In the Meraki Dashboard, navigate to Cameras > Monitor > Cameras. Select a camera.
Go to the Settings tab and navigate to Quality and Retention.
- Scroll down to the bottom of the page to see the estimated retention time.
Suggestions for improving footage retention time are provided alongside the estimated retention time.
Setting a maximum retention time
Some users may want to limit how much footage their cameras can retain (for example, to meet regulatory requirements). To address this, maximum retention limits can be enabled. Follow these steps:
Go to Camera > Monitor > Cameras. Select a camera.
Go to the Settings tab and select the Quality and Retention tab.
Select the dropdown menu under Maximum Retention Limit > When the footage is older than <option>
Footage is recorded and deleted on a first-in, first-out basis until the maximum retention time is reached.
Note that for situations where current historical footage is greater than the desired retention day value, lowering the retention limit causes the footage that falls outside of the updated window to be purged from local storage and will no longer be accessible/exportable. This takes effect immediately after the limit is changed.
Disabling video retention with recording schedules (live video only)
To disable video retention, such as for regulatory compliance, set a recording schedule that disables recording 24/7 to enable "live video only" mode. Click here for more information.
This disables the creation of motion metadata, and motion heatmaps will not be generated for live video-only cameras.
Editing setting for many cameras using profiles
In a large scale camera deployment, consider using quality and retention profiles and APIs to configure camera settings in bulk.
Deleting video from a camera
When a camera's internal storage is nearly full, it automatically deletes the oldest video. To delete all footage, remove the camera from its network by selecting the camera checkbox under Camera > Monitor > Cameras and clicking the move or remove option.
Changing quality and retention settings briefly interrupts video recording as the camera's internal recording services apply the new settings.
