Home > Smart Cameras > Installation Guides > MV Wireless Configuration Guide
Overview
MV cameras (MV12 [2018] and later) feature a wireless chip that allows them to function as wireless clients. Coupled with the Meraki MV low voltage power injector, MV provides a more affordable alternative to deployments requiring re-cabling that might otherwise be cost-prohibitive. Simply configure wireless settings in the Meraki dashboard, connect the cameras to the LAN for configuration download, and then mount cameras, connected to power, within range of an access point. The wireless functionality on MV works with any brand of wireless access point. The following documentation will outline how to configure wireless profiles for the MV.
Note: Wireless functionality is supported on firmware MV 3.16 and newer.
Creating Wireless Profiles
Follow the steps below to create wireless profiles for Meraki MV cameras.
  1. From the Meraki Dashboard, navigate to Cameras > Monitor > Cameras
  2. Select one or more cameras from the list page via its checkbox
  3. Select Edit > Edit wireless settings...
  4. From the wireless profile window, select Add or Edit a wireless profilemv_wifi_profile_selection_highlight_edit.jpg
  5. Listed will be all SSID profiles created for the Dashboard network and the ability to create new profiles. It is also possible to DUPLICATE, EDIT, and DELETE profiles.mv_wifi_profiles_edit.jpg
  6. Select New Profile. Configure the new profile by choosing the security protocol and filling out the required credentials.
    Note: Currently, the only supported WPA2-Enterprise EAP type is TTLS. Certificate based authentication is not supported. Also, the OuterIdentity is automatically set as the cameras wireless MAC address.
  7. Select Submit to save the new wireless profile. The profile will now be available for all Meraki MV within the Dashboard Network.
Note: Under the Wireless section of a specific camera, wireless profiles can be added and edited as well.
Applying Wireless Profiles
Note: During prestaging of a camera for wireless deployment, it is recommended that the camera stays connected for 30 minutes after applying the wireless profile
Follow the steps below to apply wireless profiles to Meraki MV cameras.
  4. From the wireless profile window, select a Primary and Secondary SSID. A third Backup SSID is optional.
    Note: Two SSID profiles must be selected here. It is not possible to apply only a primary profile. Multiple SSID profiles allows for potential failover scenarios. The Meraki MV will prefer the Primary SSID and automatically failover to the Secondary followed by the Backup SSID.
  5. Once the two SSID profiles are chosen, select Review Changes. Verify that all cameras are getting the correct SSID profiles and hit Submit.mv_wifI_review.jpg
  6. After changes are saved, the selected cameras will automatically update their configuration. To verify a cameras configuration is up to date, check the specific cameras Network details tab.
Note: Under the Wireless section of a specific camera, wireless settings can be altered on a per device basis.
 Remove Wireless Profile from a camera
Follow the steps below to remove wireless profile from a specific camera.
  2. Select a camera from the list page.
  3. Select Settings > Wireless
  4. Select Remove Profiles
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
