AWS vMX-XL Deployment Guide
Overview
More and more customers are moving workloads to the cloud, requiring higher throughputs and greater scale. The new vMX-XL provides:
A highly scalable new MX control and data plane architecture
Starting with vMX for new next-gen firmware
Increased performance to 10Gbps+ and up to 10,000 tunnels on a single instance
Highly cost-effective by using C6in.2xlarge instance type for compute
This document is a walkthrough for setting up a virtual MX (vMX) appliance in the Amazon Web Services (AWS) Marketplace using the latest next-gen firmware. After completing the steps outlined in this document, you will have a virtual MX appliance running in the AWS Cloud that serves as an Auto VPN termination point for your physical MX devices.
Key Concepts
Before deploying a vMX, it is important to understand several key concepts:
- Concentrator Mode
- All MXs can be configured in either NAT or VPN concentrator mode. There are important considerations for both modes. For more detailed information, see the article on Passthrough or VPN Concentrator Mode.
- One-Armed Concentrator
- In this mode, the MX is configured with a single Ethernet connection to the upstream network. All traffic will be sent and received on this interface. This is the only supported configuration for MX appliances serving as VPN termination points into the AWS Cloud.
- NAT Mode Concentrator
- In this mode, any traffic coming over auto-VPN or client VPN to the vMX will be NATed to the vMX's IP as it egresses the vMX. Other capabilities of the NAT mode including DHCP, high availability (HA), or multiple ports (LAN and WAN) are not supported. The vMX is still a one-armed appliance with one network interface in each mode.
Currently, NAT mode is not supported on the vMX-XL
VPN Topology- There are several options available for the structure of the VPN deployment.
- Split Tunnel
- In this configuration, branches will only send traffic across the VPN if it is destined for a specific subnet that is being advertised by another MX in the same dashboard organization. The remaining traffic will be checked against other available routes. These include static LAN routes and third-party VPN routes. If the traffic does not match any of these routes, it will be NATed. Afterward, it will be sent out through the branch MX unencrypted.
- Full Tunnel
- In full-tunnel mode, all traffic that the branch or remote office does not have another route to is sent to a VPN hub.
- Split Tunnel
- AWS Cloud Terminology
- This document will make reference to several key AWS-specific terms and concepts.
- Amazon Web Services (AWS)
- Amazon Web Services is a hosting platform that allows organizations to host infrastructures and services in the cloud.
- Virtual Private Cloud (VPC)
- A virtual private cloud is a virtual and private network within the AWS infrastructure. A VPC has a block of associated IP addresses, which can be subdivided into multiple smaller subnets.
- Elastic Compute Cloud (EC2)
- Elastic compute cloud is Amazon's virtual and cloud-based computing infrastructure. EC2 allows you to run virtual machines within your VPC. A virtual machine running on the EC2 platform is commonly referred to as an EC2 instance.
Additional Information
Please refer to the AWS glossary for a dictionary of cloud terminology on the AWS Cloud platform.
Meraki Dashboard Configuration
Begin by creating a new Security Appliance network in your organization. If needed, please refer to the guide on Creating and Deleting Dashboard Networks.
1. Add license(s) to the Meraki dashboard
To complete the vMX Meraki dashboard configuration, a vMX license must be available for use in your organization.
If your organization has already reached its vMX license limit, you cannot create new vMX networks until a vMX network is deleted or additional vMX licensing is added. If needed, please refer to our guide, Add Licenses to the Dashboard
If you do not have access to a vMX license or require additional vMX licenses, please reach out to your Meraki reseller or sales representative.
2. Create a "Security appliance" network type:
3. Assign vMX type to network
Once you have created the "Security appliance" network and added the appropriate license you will be able to deploy a new vMX to your network by clicking on the 'Add vMX-XL' button.
4. Generate the authentication token
Before generating the token, please verify the firmware is configured for TBD. If the vMX network firmware is set to anything below that, the upgrade will not occur.
After you add the new vMX to your network, navigate to Security & SD-WAN > Monitor > Appliance status and select “Generate authentication token” to generate the token for the AWS user-data field.
5. Copy the newly generated token and save it.
The newly generated token will be used in the "System Configurations" section when creating a new AWS Cloud instance.
The authentication token must be entered into the AWS Cloud instance within one hour of generating it, otherwise a new token must be generated.
AWS Setup
This section walks you through configuring the necessary requirements within AWS and adding a vMX instance to your virtual private cloud (VPC). For more details on setting up a VPC and other components, refer to Amazon's AWS Documentation.
Accessing the AMI
When accessing the offer from the Amazon Marketplace be sure to select 'Launch Through EC2' instead of 'Launch from Website' This is due to the launch from website function not allowing token input and requiring a keypair.
Access the Amazon Marketplace to subscribe to the Amazon Machine Image (AMI) for the Cisco vMX. A screenshot of the AWS Marketplace listing is included below, please note that the vMX-XL offer is different from the marketplace offer used to deploy vMX-S/M/L.
Select the EC2 instance type and the region to launch the EC2 instance in. This should match the availability zone your VPC resides in.
The recommended instance type for best performance is `c6in.2xlarge`
Click the "Continue to Subscribe" button to configure and finalize the vMX deployment.
Configuring the EC2 Image
After continuing, you will be prompted to configure the EC2 instance settings.
For "Choose action" option select the "Launch through EC2" and click "Launch."
Choose the EC2 instance type
C6in.2xlarge is the recomended instance type for optimal performance.
Scroll down to the network settings.
Select the VPC and the subnet the instance will be a part of and make sure the "auto-assign public IP" is enabled.
Scroll down to "Advanced Details" enter the vMX authentication token from the dashboard in the user data field.
Steps that need to be taken to generate the vMX authentication can be found in the Dashboard Configuration section
Metadata version 2 is not supported at this time. Using Metadata V2 can result in 'Invalid Token' error message.
Note: the carrot "<>" brackets are to be omitted from your vMX auth token
Click "Review and Launch" to finish creating the instance.
It may take several minutes before the software subscription completes and the instance launches.
Additional VPC Configuration
The virtual MX appliance will allow for site-to-site VPN connectivity using Auto VPN between AWS and other remote MXs. In order to have proper bidirectional communication between remote subnets that are terminating into AWS via the vMX and hosts within AWS, the VPC routing table must be updated for the remote Auto VPN-connected subnets.
To do this, navigate to the "VPC" dashboard in AWS, and follow the steps below:
- Click on "Route Tables" on the left-hand side.
- Find the route table associated with the VPC or subnet the vMX is hosted in (you can quickly filter the list by typing in your VPC ID or name in the search box).
- Click on the route table in the list to select it, then click on the "Routes" tab in the details pane below the list of routing tables.
- Click the "Edit" button.
- Click the "Add another route" button at the bottom of the route table.
- In the "Destination" column, add the routes available via Auto VPN.
- In the "Target" column, select the vMX instance or interface ID.
- Repeat steps 5-7 for each network available via Auto VPN and Client VPN if applicable. You may want to use a summary address. Below is an example of one network available via Auto VPN.
Troubleshooting
The most common problem people face when deploying a vMX is getting it provisioned and online in their Meraki dashboard in the first place. New troubleshooting/diagnosis messages have been added to the vMX console screen now so you can identify what went wrong during the provisioning process.
When the vMX boots it will execute the following steps during its initial provisioning process:
- Obtain user-data (vMX auth token)
- Authenticate with the dashboard (using auth token)
- Connect to dashboard
Obtain User Data and Authenticate to Dashboard
Once a vMX has successfully connected to a network, it will then attempt to obtain its user data (vMX auth token). There are different user-data mechanisms in each platform that the vMX currently runs on to provide the token to the vMX. In AWS, Azure, GCP, and Alicloud there are user-data fields in the VM configuration where this can be provided.
Token Expired
vMX auth tokens have a lifetime of only one hour for security purposes. If you see the following message on your vMX console it means the token you provided is no longer valid.
Invalid Token
If the token provided is incorrect in any way the "invalid token" message is displayed on the console.
Unable to Reach Meraki Dashboard
If the vMX is unable to reach the dashboard on TCP port 7734 then the initial provisioning phase will fail and an "Unable to reach Meraki Dashboard" message will be displayed on the console (check the firewall information page for a list of all the firewall rules needed for the Cisco Meraki cloud communication). Please refer to the document on correct ports/IPs that need to be opened for Meraki dashboard communication.
Note: Please ensure that the VPC route table is able to get out to the internet.
Note: For any of the following above (Token Expired, Invalid Token, Unable to reach Meraki Dashboard), you may also look to view the instance screenshot, right-click on EC2 instance > Monitor and troubleshoot > Get instance screenshot to view the status. Other resources from AWS:
No "Add vMX" Button
When navigating to Security & SD-WAN > Monitor > Appliance Status, if there is no "Add vMX" button, please ensure the following two conditions are met:
- You have available vMX licenses in your license pool.
- You have created a "Security appliance" network type.
Please note that Meraki support does not troubleshoot AWS Cloud-specific firewall rules and deployments.
