Z4C Datasheet
Overview
The Cisco Meraki Z4C teleworker gateway is an enterprise class firewall, VPN gateway and router. This device offers wireless connectivity with WiFi 6, five gigabit ethernet ports, including a built-in PoE-enabled port for VoIP phones and other PoE powered devices. The Z4C is designed to securely extend the power of Meraki cloud managed networking to almost any location. With a built-in LTE modem, the Z4C simplifies any deployment that requires a backup cellular uplink, or is positioned in a remote location.
Top down photo of the Z4 with antennas attached to the back.
Features
Software Features
  • Managed via Cisco Meraki Dashboard
  • Automatic Firmware upgrades
  • L3/L7 Stateful Firewall
  • 1:1 and 1:Many NAT
  • Configurable VLANs / DHCP support
  • Static Routing
  • Client VPN endpoint
  • Meraki AutoVPN and IPSec VPN endpoint
  • Custom Traffic Shaping
  • Historical Client Usage statistics
  • Netflow support
  • Syslog integration
  • Remote Packet Capture tools
  • IPv6 Support
  • 802.1X wired and wireless support
Hardware Features
  • Built-in WiFi 6 Wireless Capabilities
  • Built-in PoE+ capabilities
  • Built-in LTE Cellular capabilities
Context and Comparisons
Z4C
Single Wired WAN Uplink
Yes
Cellular Uplink
Yes
Stateful Firewall Throughput
500 Mbps
Maximum VPN Throughput
250 Mbps
Security Throughput
300 Mbps
PoE Capabilities
Yes, 1x GbE RJ45 LAN Ports (802.3at)
WiFi
Dual-band 2x2 WiFi 6
Backup Cellular Uplink
Built-in CAT12 LTE Modem with 2x External LTE Antennas
Recommended use case
Up to 15 devices
Technical Breakdown
WAN Interfaces
Z4C
1x Dedicated GbE RJ45
1x Built-in CAT12 LTE Modem
LAN Interface
Z4C
4x Dedicated GbE RJ45
802.11 Wireless Interface
Z4C
Radio Information
802.11a/b/g/n/ac/ax (2.4 or 5Ghz) 2x2 MU-MIMO
Antennas
2 x 2 MU-MIMO with two spatial streams
Maximum Data Rate
1.5 Gbps*
* Refers to maximum over-the-air data frame rate capability of the radio chipset, and may exceed data rates allowed by IEEE 802.11ax operation.
Signal Coverage Patterns
5GHz WiFi
5GHz signal coverage patterns on the X-Y plane.
5GHz signal coverage patterns on the X-Z plane.
5GHz signal coverage patterns on the Y-Z plane.
2.4 GHz WiFi
 2.4GHz signal coverage patterns on the X-Y plane.
2.4GHz signal coverage patterns on the X-Z plane.
2.4GHz signal coverage patterns on the Y-Z plane.
Throughput and Capabilities
Z4C
Recommended Use Case
Up to 15 devices
Max Stateful Firewall Throughput in NAT mode
500 Mbps
Max VPN Throughput
250 Mbps
Physical
Z4C
Mount Type
Desktop / Wall Mount
Dimensions
(h x d x w)
7.9 x 4.41 x 1.04 in /
200 x 112 x 26 mm
Weight
1.1 lbs / 0.487 kg
Power Supply
50W DC
Power Load (idle/max)
15W / 46W
Operating Temperature
32°F - 113°F
0°C - 45°C
Storage and Transportation Temperature
-4°F - 158°F
-20°C - 70° C
Humidity
5% to 95%
Ordering Guide
Model SKU Description
Z4C-HW Meraki Z4C Cloud Managed Teleworker Gateway
Accessories
Accessory
Description
MA-PWR-50WAC
Meraki MX Replacement Power Adapter (Z4/C) (50 Watts AC)
MA-PWR-CORD-US
1x AC Power Cable, US plug
MA-PWR-CORD-EU
1x AC Power Cable, EU plug
MA-PWR-CORD-UK
1x AC Power Cable, UK plug
MA-PWR-CORD-AU
1x AC Power Cable, AU plug
Configure your Dashboard Network
The following is a brief overview only of the steps required to add an Z4C to your network. For detailed instructions about creating, configuring and managing Meraki networks, refer to our Managing Dashboard Networks document. Additional resources can also be found via: documentation.meraki.com.
  1. Login to http://dashboard.meraki.com. If this is your first time, create a new account.
  2. Find the network to which you plan to add your Z4C or create a new network.
  3. Add your Z4C to your network. You will need your Meraki order number (found on your invoice) or the serial number of each Z4C, which looks like Qxxx-xxxx-xxxx, and is found on the bottom of the unit. If a license key was purchased at the same time then you should have received it via email.
  4. Go to the map / floor plan view and place each Z4C on the map by clicking and dragging it to the location where you plan to mount it.
Z-Series Warranty coverage periods are as follows:
Product
Warranty Period
Warranty Information
Z4C
Lifetime
Z4C Accessories
1 Year
The following are considered accessories:
SFP Modules, all mounting kits and stands, interface modules, additional power cords
Additional warranty information can be found on the Return Policy and Requesting a RMA page of the Cisco Meraki website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Meraki Z4C devices have been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
Troubleshooting
Common Event Log Messages
Common event logs exist for wired, WiFi, and cellular events. As such, no specific Z4C event log entries are required at this time.
For more general information about navigating the Event Log and the types of Events that could be expected please check out our Event Log documentation.
  • Was this article helpful?
