vMX Cloud Integrations
Overview
Customers are moving to one or more clouds, but managing multiple environments is complex, requiring:
  • Nuanced processes
  • Differing user experiences
  • Varying configurations
With vMX Cloud Integrations customers can deploy and manage their vMX via the Meraki dashboard, giving them;
  • Unified and automated cloud management
  • Expand network connectivity
  • Consistent user experience
Note: As of April 2024, deleting an integration is not supported.
Deployment Steps
1. Add license(s) to the Meraki dashboard
To complete the vMX Meraki dashboard configuration, a vMX license must be available for use in your organization.
If your organization has already reached its vMX license limit, you will be unable to create new vMX networks until a vMX network is deleted or additional vMX licensing added.
If you do not have access to a vMX license or require additional vMX licenses, please reach out to your Meraki reseller or sales representative.
2. Navigate to Organization > Configuration > Cloud Integrations
 Cloud Integration page in the Dashboard UI
3. [Adding Cloud Accounts] Select Cloud accounts > + Add Account
Dashboard UI Cloud integration navigation to Add account
4. [Adding Cloud Accounts] Add Cloud Account Details
Select a provider (AWS for now)
 Dashboard UI Cloud integration Add account page showing available providers to select from (AWS)
Go to your AWS account and generate an AWS access and secret key and enter the credentials to link your AWS account.
Dashboard UI Cloud integration Add account page step 2: Enable access page Requiring an AWS access key ID and a secret access key                     Dashboard UI Cloud integration Add account page step 3: Enter credential page with example AWS access key ID and a secret access key provided
 For cloud integration to function properly you would need the access key to have the following permissions
    "Statement": [
            "Action": [
                "ec2:RunInstances",
                "ec2:CreateTags",
                "ec2:ModifyInstanceAttribute",
                "ec2:DescribeAvailabilityZones",
                "ec2:DescribeVpcs",
                "ec2:DescribeSubnets",
                "ec2:DescribeSecurityGroups"
            "Effect": "Allow",
            "Resource": "*"
    "Version": "2012-10-17"
5. Once the account has been linked, it will show up under the “Select cloud account” list. Select the account that was linked in the previous steps and move on to the general settings section.
Dashboard UI Cloud integration page showing the account is now linked as it is visible in “Select cloud account” list and is selectable
6. General Settings
Dashboard UI Cloud integration - Deploy virtual appliance page at stage 2: General settings with an example instance name "vmx-dev-test" and Append provider name and region option checkboxed
  • Instance name: Name of the vMX network on the dashboard
  • Append provider name and region: Toggle on, if you want to append the provider name (AWS, GCP, ..) and region to the vMX network name on the dashboard.
  • License: Choose vMX license type; vMX-S/M/L
7. Provider Settings
Dashboard UI Cloud integration - Provider settings input AWS Region US East (N. Virginia) , VPC vpc-0f17f946a3cb29f43, Subnet-07c45767582cffd51
  • Region: Select the cloud provider region you want to deploy the vMX in
  • VPC: Select the VPC within the region you want to deploy the vMX in. If not selected the “Default” VPC for that region would be selected.
  • Subnet: VPC subnet to deploy the vMX in
  • Security groups (optional): Select a predefined security group, if left blank the default security group (allow inbound 22) created as part of the vMX offer would be used.
  • Tags:  Create any tags(key/value pair) that would be associated with the instance on AWS.
Dashboard UI Cloud Integration Add tags pop up with example Key "evn" and optional Value "staging"
8. Summary
Verify that the configuration for the vMX looks good and hit deploy.
Dashboard UI Cloud integration Summary of the Deployment settings configured in all steps above
It might take a few minutes for the deployment to complete and once the deployment is complete, it can be seen under the deployments tab
Dashboard UI Cloud integration main page showing the newly deployed vMX in the Deployments tab
Furthermore, the vMX status can be seen by going to the Security & SD-WAN > Monitor > Appliance status tab.
  • Was this article helpful?
