Creating and Deleting Dashboard Networks
本語版はこちら
Dashboard networks (also known as sites) provide a way to logically group and configure Cisco Meraki access points, security appliances, switches, and Systems Manager within an organization. Devices in the same network can be configured and monitored in the same way. Dashboard networks are also a useful way to separate physically distinct sites within an organization. This Knowledge Base article describes how to create and delete networks.
Note: Creating and deleting networks requires full organization permissions.
Creating a Network
Network Scope General Recommendation
A network holds devices and information related to those devices. Generally, networks will represent physical locations or actual LANs at different sites. A network can contain any number of access points or switches, but only a single security appliance, VM concentrator, or instance of Systems Manager.
As an organization administrator, hover over the Organization tab, then select Create network.
Enter a Name for the network. Make sure this clearly identifies the purpose of this network. Such as 'HQ - Appliance'.
- Select the Network type.
- Combined hardware - Can contain a combination of different device types. Useful for locations with each type of device.
Note: A combined network consists of multiple network types combined into one. If only one type of device is added to a combined network at the time of creation, the network will be of that device type. Please refer to our documentation for more information about combined networks. - Security appliance - Contains a single security appliance or teleworker gateway (ex. MX series or Z1). Can also contain an HA pair of MX appliances.
- Switch - Contains only switches (ex. MS series).
- Wireless - Can only contain wireless Access points. Dashboard managed MR and CW ( in Monitor mode) CANNOT be added to the same Network and Cloud Monitored Catalyst Access Points must be claimed to separate Networks.
- Camera - Contains only cameras (ex. MV series).
- EMM - Systems Manager enterprise mobility management network.
- Cellular gateway - Contains only cellular gateway (ex. MG series)
- Wireless LAN Controller - Can only contain Monitored Catalyst 9800 wireless controllers.
- Select the Configuration .
- Use default - Creates the network with all default settings.
- Clone from network - If another network of this Type is available, most network and configuration settings can be copied with the exception of local device configurations (ie. static IP assignments of the devices), and NetFlow configurations. If the source network type is different, it will override the selection above.
- Bind to template - This network will have minimal local settings, with most configuration determined by the selected template. Learn more in the article on templates.
Note: To enhance the security of customer networks, the encryption settings for the default SSID (enabled by default) have been updated starting Jun 10, 2025. When a Meraki administrator creates a new combined or wireless-only network, the default SSID's encryption setting will now use Password (WPA2 only) instead of Open (no encryption).
After creating a combined or wireless-only network using the Default Meraki configuration, the first SSID defaults to the settings below, with all other SSIDs disabled:
SSID (name):
Combined network: “{network_name} - wireless WiFi”
Wireless-only network: “{network_name} WiFi”
SSID status: enabled
Security: Password (randomly generated 30-character PSK). WPA Encryption: WPA2 only. 802.11w: Disabled (never use).
Splash: None
Client IP and VLAN: Meraki AP assigned (NAT mode)
These settings should be altered before adding and deploying access points if network access requires further restriction. We recommend changing the default random alphanumeric password to a user-friendly one. Additional information on per-SSID Access Control settings can be found in our Access Control documentation.
(Optional) In the Devices section, check the box for any devices that should be added to the network. If no devices exist in the inventory, click Claim devices and enter the serial or order numbers to add them.
Note: Unless the Type of "Combined" was selected, only devices matching the network Type selected above will be added.
Click Create network.
We highly recommend having the total switch count in any dashboard network to be less than or equal to 400 switches. If switch count exceeds 400 switches, it is likely to slow down the loading of the network topology/ switch ports page or result in display of inconsistent output.
Deleting a Network
Networks can be deleted when they are no longer needed. The devices from the network will remain in the organization's inventory and can later be added to new networks. Follow the steps below to delete a network.
Notes:
- If billing has been enabled on a network, the network cannot be deleted.
- If the AutoVPN feature is enabled, the network cannot be deleted until it's disabled.
Navigate to Organization > Overview.
Along the right side, click on the arrow button to view the full list of networks within the organization.
Click the checkbox next to any networks that should be deleted.
Click the Delete button along the top of the list.
On the following page, click the checkbox to confirm that these networks should be permanently deleted. Then click the Delete networks button.
Note: Deleting networks is permanent and irreversible. It cannot be undone by organization administrators or Cisco Meraki support.
Additional Resources
For additional information, please refer to articles on organization inventory, adding & removing devices from networks, and licensing guidelines.
For information on creating, deleting, and managing configuration templates, refer to the article on Managing Identical Networks with Configuration Templates.
