Introduction to IOS XE Based Secure Routers Managed by Dashboard
Functionality Overview
Dashboard Management for IOS XE Based Routers enables onboarding for IOS XE based Generation-2 Secure routers into Dashboard. For detailed onboarding instructions, please visit the onboarding documentation page.
When operating in Configuration Source: Cloud, management of the device must be performed by API.
Beta API Access must be enabled within the Early Access page in order to begin use.
At this time, an organization may only have AutoVPN enabled for MX or IOS XE Secure Routers. A new organization is required for IOS XE Based Secure Routers if MX Secure Routers presently have AutoVPN enabled.
Supplemental Documentation
Supported Features
Current firmware version: 26.2.1
For firmware version / management, please see the following API: https://developer.cisco.com/meraki/a...ware-upgrades/
Features not explicitly listed here should be considered to be not supported.
Onboarding
- Zero Touch Provisioning (Configuration Source: Cloud)
Live Tools & Monitoring
- Port Status
- Historical Device Connectivity
- Cloud CLI
- Uplink Telemetry
- WAN Status
- Device Health
- CPU
- Memory
- Power Consumption
- Uptime
- Ping
- Traceroute
- MAC Table
- ARP Table
- Route Table
- Firmware Status
- Reboot Device
- Dashboard Throughput
- Traffic Analysis & Client Details with Application Awareness
- Event Logging
- Syslog
- SNMP
- Netfow
- CDP / LLDP
- Auto VPN Performance Monitoring
- Packet Capture
The following live tools are available via API and require a job to be enqueued prior to operation:
- ARP Table
- Port Status
- Power Consumption
- Route Table Lookup & Route Table Summary
Configuration
- Local Status Page
- Alternate Management Interface - Coming soon
- WAN Uplink Settings
- Layer 2 Interfaces
- Layer 3 Interfaces
- VLANs & DHCP
- NAT with ECMP / UCMP
- Static Routing
- AutoVPN with ECMP / UCMP
- eBGP on LAN
- Core Allocation (UI) Service Plane / Data Plane Heavy
- Layer 3 Firewall
- Layer 7 Firewall
- L3/L7 DIA Breakout
- Quality of Service and DSCP Tagging / Honoring
- VRRP Based High Availability
- LACP
- VRF / Mutli-VRF
- WAN <-> LAN Interface Conversion
- Firmware Upgrade
Monitoring & Troubleshooting
Port Status
Port Status is available under 'Security & SD-WAN' -> 'Appliance Status' -> 'Summary'
The interface describes:
- Port physical status
- Speed
- Duplex
Historical Device Connectivity graph is available under 'Security & SD-WAN' -> 'Appliance Status' -> 'Summary'
The interface describes historical connectivity of the device to Dashboard. This is built based on the control session (TLS Tunnel) historical connectivity reports from the device.
Cloud CLI (read)
Cloud CLI enables read access for devices operating in Configuration Source: Cloud mode.
See Cloud CLI Specific documentation for additional details.
Cloud CLI (write)
Cloud CLI with write access is available for devices operating in Configuration Source: Device mode. This terminal provides read/write access based on user permissions.
Session logging & auditing is also provided within the Cloud CLI page. This page can be accessed via 'Security & SD-WAN' -> 'Appliance Status' -> 'Cloud CLI'
Client Details & WAN Consumption
Client Details & WAN Consumption graph provides historical consumption / usage of individual WAN Interfaces. This is available from the 'Security & SD-WAN' -> 'Appliance Status' -> 'Summary' page
The information provided is a historical presentation of bytes in/bytes out for the defined WAN interfaces.
Device Health
The ‘Device Health’ tab provides key insights into operational functionality of the device. This page is available from 'Security & SD-WAN' -> 'Appliance Status' -> 'Device Health'
This tab provides a realtime view of:
- Uptime
- CPU Load
- Memory consumption
- PoE Consumption
- Power Supply Unit status
Live Tools
Ping
For an overview of Ping functionality, please visit the broader Live Tools page.
Traceroute
For an overview of traceroute functionality please visit the broader live tools page.
MAC Table
The MAC table provides a readout of L2 entries entered into the table, as detected across all interfaces. The MAC Table is available from within 'Security & SD-WAN' -> 'Appliance Status' -> 'Tools'
ARP Table
The ARP table provides a readout of L3 entries entered into the table, as detected across all interfaces. The ARP Table is available from within 'Security & SD-WAN' -> 'Appliance Status' -> 'Tools'
Route table
The Route table provides real-time output of the current forwarding information base for multiple routing protocols. The Route Table is available from within 'Security & SD-WAN' -> 'Route Table'
The route table maximum display capacity is 300. Filters should be leveraged in order to reduce the overall amount of output.
Available route sources & protocols available are:
- (e/i)BGP
- Static
- Directly Connected
- Auto-Installed WAN Default Routes
Available filters are:
- Subnet
- Next Hop
- Routes/Route Protocols
Appliance Details
The Appliance Details are provided on the left nav pane when navigating to 'Security & SD-WAN' -> 'Appliance Status'
Information available includes:
- Model
- Serial Number
- Cloud ID
- MAC Address
- WAN Uplink Information
- Firmware Version
- Regulatory Information
- Device Uptime
Configuration
When removing a device from a network L3 & L2 Configurations are disabled and will need to be reapplied manually.
Interface List
A list of interfaces and their current configuration(s) may be obtained by API only. The response shall indicate:
- Port configuration & available configuration modes
- Flex, L2, L3
- Mode
- WAN/LAN
- Trunk/Access/L3 Transport configuration
Layer-2 Interface: Trunk or Access
Layer 2 port settings can be obtained (GET) and modified (PUT) for all or individual ports via the endpoints (Partial updates are permitted). For additional information, please see the developer API.
NOTE:
- Access: Only “Open” Access Policies are supported
- Trunk: To drop untagged traffic, the native vlan ID must be omitted from the list of allowed VLANs.
Layer-3 Interface
Layer 3 Interface configurations are available via API. Please see the developer API for additional information.
IPv6 address configuration not supported
Static Routing
Configuration of LAN Static routes is available via API. Configuration includes next hop and destination subnet. For additional information, please visit the developer API.
Static routes inherit the LAN transport interface's behavior for VPN Enablement/Disablement. If the source interface used for a static route is VPN Enabled, the associated downstream subnet will be implicitly enabled as well.
Object tracking, or IP SLA, is not available for static routes at this time.
eBGP on LAN
eBGP on LAN is available for devices configured as hub only. This configuration is available via API. Please see the developer API for additional information.
- eBGP on LAN is available for devices operating as a hub only.
- Up to 10 eBGP Neighbors can be enabled
