Home > Enterprise Mobility Management > Profiles and Settings > Single App mode or Guided Access and Meraki MDM
Single App Mode allows an iOS app to retain control over the device and prevent interaction with other apps or functions. This can be very helpful for:
  • Preventing students from searching for answers during a test*
  • Preventing the accidental closure of an app
  • Setting up a kiosk where access to other apps/menu is not allowed
*For information on configuring Apple Classroom with Systems Manager, see this article.
Systems Manager offers two options for supervised devices related to Single App Mode, located under Systems manager > MDM > Settings > Restrictions > iOS restrictions (supervised). Forcing an app into Single App Mode, and controlling which apps are able to place themselves into Single App Mode. Both options will be discussed below.
These options are only available on supervised devices. For more information on supervision, and how to supervise devices, refer to the articles on the Device Enrollment Program or Apple Configurator.
Forcing an App into Single App Mode
Particularly useful for kiosks, or devices that should only ever be used with a single app, the Single App Mode restrictions allows one app to be forced into Single App Mode. As long as this restriction is in place, the device will only allow this app to run, and will auto-launch it when not running. To enable:
  1. Navigate to Systems manager > MDM > Settings > Restrictions > iOS restrictions (supervised).
  2. Click the checkbox to Enable Single App Mode.
  3. From the dropdown that appears, choose the app to place in Single App Mode. Only built-in apps and managed apps (listed under MDM > Apps) will appear in the list.
  4. Click Save Changes.
Once applied to devices in question, the app will be automatically launched and locked in Single App Mode until the restriction is removed.
Limiting Autonomous Access to Single App Mode
Some apps can place themselves in Single App Mode, such as a testing apps which prevents access to outside information. The Allowed Single App Mode restrictions controls which apps are able to perform this action. It does not limit which apps can be placed in Single App Mode manually by the user with Guided Access. To enable:
  2. Click in the box next to Allowed Single App Mode.
  3. Select any apps from the list to be allowed. Only built-in apps and managed apps (listed under MDM > Apps) will appear in the list.
You must to post a comment.
Last modified
13:01, 17 Jan 2017
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
