Catalyst 9300-M Datasheet
Overview
The Catalyst 9300-M addresses the most demanding enterprise applications by combining the simplicity of the Meraki dashboard with powerful switching hardware. To satisfy high-bandwidth applications and the deployment of high-speed wifi access points, the Catalyst 9300-M provides multigigabit ports, 480G stacking, and modular 10/25/40G uplinks. The Catalyst 9300-M delivers resiliency with fast stack convergence and StackPower. The Catalyst 9300-M provides Adaptive Policy using an over-the-wire tag which segments traffic into security groups to deliver scalable security. The Catalyst 9300-M is integrated under the Meraki dashboard to provide a simply powerful solution to the most demanding wired access applications.
Adaptive Policy provides simple & scalable security policies to segment traffic using Security Groups. Security Groups are created in the dashboard using natural language such as “IOT device” & “Guest.” The security policy intent (e.g., Permit or Deny) is then simply provisioned between Security Groups which results in the segmentation of each group’s traffic. By making security policy management intuitive and scalable relative to legacy IP-address based Access Control Lists, Adaptive Policy empowers operators to confidently secure their network traffic independent of future network changes.
By pooling & distributing power across C9300-Ms using a series of StackPower cables, StackPower provides simple and resilient power distribution across the stack.
C9300-24UX-M
C9300-48UXM-M
A Catalyst 9300 switch can also be migrated to a Meraki-managed persona, where it would function as its Catalyst Meraki 9300 equivalent. For details on the migration process, please refer to our Getting started: Cisco Catalyst 9300 with Meraki Dashboard guide.
Models
| Number of Ports | Model | Description |
Fiber |
C9300-24S-M | 24-port SFP switch |
| C9300-48S-M | 48-port SFP switch | |
24 Ports |
C9300-24T-M | 24-port GbE switch |
| C9300-24P-M | 24-port GbE PoE+ switch | |
| C9300-24U-M | 24-port GbE UPoE switch | |
| C9300-24UX-M | 24-port mGbE UPoE switch | |
48 Ports |
C9300-48T-M | 48-port GbE switch |
| C9300-48P-M | 48-port GbE PoE+ switch; ENERGY STAR®️ certified | |
| C9300-48U-M | 48-port GbE UPoE switch | |
| C9300-48UXM-M | 36-port 2.5GbE + 12-port mGbE UPoE switch; ENERGY STAR®️ certified | |
| C9300-48UN-M | 48-port 5GbE UPOE switch |
Features
Catalyst 9300/L/X-M Licensing
Technical Breakdown
Interfaces Specifications
| Model/Persona | Interfaces |
Uplink (SFP28, QSFP+) |
120G Hardware Stack Port |
Dedicated Management Interface |
PoE/ UPoE Capabilities |
| C9300-24S-M | 24 x 1G SFP | Modular | 2 | 1 | n/a |
| C9300-24T-M | 24 x 1GbE RJ45 | Modular | 2 | 1 | n/a |
| C9300-24P-M | 24 x 1GbE RJ45 | Modular | 2 | 1 | PoE |
| C9300-24U-M | 24 x 1GbE RJ45 | Modular | 2 | 1 | UPoE |
| C9300-24UX-M | 24 x 100M/1G/2.5G/5G/10G RJ45 | Modular | 2 | 1 | UPoE |
| C9300-48S-M | 48 x 1G SFP | Modular | 2 | 1 | n/a |
| C9300-48T-M | 48 x 1GbE RJ45 | Modular | 2 | 1 | n/a |
| C9300-48P-M | 48 x 1GbE RJ45 | Modular | 2 | 1 | PoE |
| C9300-48U-M | 48 x 1GbE RJ45 | Modular | 2 | 1 | UPoE |
| C9300-48UXM-M |
36 x 100M/1G/2.5G + 12 x 100M/1G/2.5G/5G/10G |
| C9300-48UN-M | 48 x 100M/1G/2.5G/5G | Modular | 2 | 1 | UPoE |
All models are available with modular uplinks that have been listed under the Accessories list. For supported SFP modules please refer the SFP Datasheet.
Cabling Best Practices for Multi-Gigabit operations: While Category-5e cables can support multigigabit data rates upto 2.5/5 Gbps, external factors such as noise, alien crosstalk coupled with longer cable/cable bundle lengths can impede reliable link operation. Noise can originate from cable bundling, RFI, cable movement, lightning, power surges and other transient event. It is recommended to use Category-6a cabling for reliable multigigabit operations as it mitigates alien crosstalk by design.
Physical Specifications
| Model |
Dimensions (h x w x d) W/ Default Power Supply |
Weight | Mount Type | Hot Swap Fans | Operating Temperature | Humidity |
| C9300-24S-M |
1.73" x 17.5" x17.7" (4.3 x 44.4 x 44.9cm) |
16.84 lb (7.64 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-24T-M |
1.73” x 17.5” x 17.7” (4.4 x 44.5 x 44.9cm) |
16.03 lb (7.27 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-24P-M |
16.33 lb (7.4 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-24U-M |
1.73” x 17.5” x 19.2” (4.4 x 44.5 x 44.8cm) |
16.63 lb (7.54 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-24UX-M |
1.73” x 17.5” x 20.2” (4.4 x 44.5 x 51.3cm) |
18.18 lb (8.25 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48S-M |
1.73" x 17.5" x 19.2" (4.3 x 44.4 x 44.9cm) |
17.32 lb (7.86kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48T-M |
1.73” x 17.5” x17.7” (4.4 x 44.5 x 44.9cm) |
16.43 lb (7.45 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48P-M |
16.73 lb (7.59 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48U-M |
1.73” x 17.5” x 19.2” (4.4 x 44.5 x 48.8cm) |
17.03 lb (7.72 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48UXM-M |
1.73” x 17.5” x 22.2” (4.4 x 44.5 x 56.4cm) |
20.50 lb (9.34 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300-48UN-M |
20.05 lb (9.09 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
Performance
Model |
Switching Capacity | Stacking Bandwidth | Forwarding rate |
| C9300-24S-M | 208 Gbps | 480 Gbps | 154.76 Mpps |
| C9300-24T-M | 208 Gbps | 480 Gbps | 154.76 Mpps |
| C9300-24P-M | 208 Gbps | 480 Gbps | 154.76 Mpps |
| C9300-24U-M | 208 Gbps | 480 Gbps | 154.76 Mpps |
| C9300-24UX-M | 640 Gbps | 480 Gbps | 476.19 Mpps |
| C9300-48S-M | 256 Gbps | 480 Gbps | 190.48 Mpps |
| C9300-48T-M | 256 Gbps | 480 Gbps | 190.48 Mpps |
| C9300-48P-M | 256 Gbps | 480 Gbps | 190.48 Mpps |
| C9300-48U-M | 256 Gbps | 480 Gbps | 190.48 Mpps |
| C9300-48UXM-M | 580 Gbps | 480 Gbps | 431.54 Mpps |
| C9300-48UN-M | 640 Gbps | 480 Gbps | 476.19 Mpps |
Power Supply and Specifications
Model |
Default Power Supply | Hot Swap Power Supply | Available PoE W/ Primary PS | Max Available PoE W/ Secondary PS** |
Power Load (idle/max) |
| C9300-24S-M | PWR-C1-715WAC-P-M | Yes, Dual | n/a | n/a | 84.60 / 124.30 W |
| C9300-24T-M | PWR-C1-350WAC-P-M | Yes, Dual | n/a | n/a | 79.2 / 99 W |
| C9300-24P-M | PWR-C1-715WAC-P-M | Yes, Dual | 445W | 720W | 84.1 / 554.4 W |
| C9300-24U-M | PWR-C1-1100WAC-P-M | Yes, Dual | 830W | 1440W | 85.4 / 990.3 W |
| C9300-24UX-M | PWR-C1-1100WAC-P-M | Yes, Dual | 560W | 1440W | 162.7 / 809.9 W |
| C9300-48S-M | PWR-C1-715WAC-P-M | Yes, Dual | n/a | n/a | 88.90 / 158.30 W |
| C9300-48T-M | PWR-C1-350WAC-P-M | Yes, Dual | n/a | n/a | 83.9 / 109.9 W |
| C9300-48P-M | PWR-C1-715WAC-P-M | Yes, Dual | 437W | 1152W | 92.6 / 555 W |
| C9300-48U-M | PWR-C1-1100WAC-P-M | Yes, Dual | 822W | 1800W | 145 / 844.9 W |
| C9300-48UXM-M | PWR-C1-1100WAC-P-M | Yes, Dual | 490W | 1590W | 218.5 / 785.5 W |
| C9300-48UN-M | PWR-C1-1100WAC-P-M | Yes, Dual | 645W | 1745W | 157.9 / 843.8 W |
** The PoE values are provided considering the secondary PS to be the default power supply of the respective model.
Note: For Japan, the recommendation is to deploy the switch with 200V+ outlets. The 1100WAC power supplies will not operate on 100V. Please reference Table 13. AC Power Cords for the appropriate 250VAC power cable.
PSU configuration and PoE budgets
Model |
Primary PSU |
PoE |
With 350W Secondary PSU |
With 715W Secondary PSU |
With 1100W Secondary PSU |
C9300-24P-M |
PWR-C1-715WAC-P-M | 445W | 720W 2 | 720W 2 | 720W 2 |
| PWR-C1-1100WAC-P-M 1 | 720W 2 | 720W 2 | 720W 2 | 720W 2 | |
| C9300-24U-M | PWR-C1-1100WAC-P-M | 830W | 1180W 2 | 1440W 2 | 1440W 2 |
| C9300-24UX-M | PWR-C1-1100WAC-P-M | 560W | 910W | 1275W | 1440W 2 |
C9300-48P-M |
PWR-C1-715WAC-P-M | 437W | 787W | 1152W | 1440W 2 |
| PWR-C1-1100WAC-P-M 1 | 822W | 1172W | 1440W 2 | 1440W 2 | |
| C9300-48U-M | PWR-C1-1100WAC-P-M | 822W | 1172W | 1537W | 1800W 3 |
| C9300-48UXM-M | PWR-C1-1100WAC-P-M | 490W | 840W | 1205W | 1590W |
| C9300-48UN-M | PWR-C1-1100WAC-P-M | 645W | 995W | 1360W | 1745W |
1 Using upgraded power supply option.
2 Limited by port density and per-port PoE capacity.
3 Limited by design.
Package Contents
In addition to the MS switch, each shipment includes the following.
- 1 x default power supply unit for the switch model (please refer to the power supply and specifications section)
- Rack mount brackets (rack screws not included)
- 3 x Pre-installed fans.
Note: Contact your Meraki partner or reseller to confirm if a power cord is included with your order.
Optional Accessories
| Accessory | Description | Supported Models |
| PWR-C1-350WAC-P-M | 350W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-715WAC-P-M | 715W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-1100WAC-P-M | 1100W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-1900WAC-P-M | 1900W AC Power Supply (230V)** | C9300, C9300X |
| C9300X-NM-4C | 4 x 40/100G QSFP28 Uplink Module | C9300X-48HX, C9300X-48TX and C9300X-24Y |
| C9300X-NM-8Y-M | 8 x 25G SFP28 Uplink Module | C9300X |
| C9300X-NM-2C-M | 2 x 40/100G QSFP28 Uplink Module | C9300X |
| C9300-NM-2Q-M | 2 x 40G QSFP Uplink Module | C9300 |
| C9300-NM-8X-M | 8 x 1G/10G SFP+ Uplink Module | C9300 |
| C9300-NM-2Y-M* | 2 x 25G/10G/1G SFP28 Uplink Module | C9300 |
| C9300-NM-4M | 4 x 100M/1G/2.5G/5G/10G RJ-45 Uplink Module | C9300 |
| C9300-NM-4G | 4 x 1G SFP Uplink Module | C9300 |
| STACK-T1-50CM-M | Catalyst Meraki 480G Stacking Cable, 0.5 Meter | C9300, C9300X |
| STACK-T1-1M-M | Catalyst Meraki 480G Stacking Cable, 1 Meter | C9300, C9300X |
| STACK-T1-3M-M | Catalyst Meraki 480G Stacking Cable, 3 Meter | C9300, C9300X |
| CAB-SPWR-30CM-M | Catalyst 9300-M 30CM StackPower Cable | C9300, C9300X |
| CAB-SPWR-150CM-M | Catalyst 9300-M 150CM StackPower Cable | C9300, C9300X |
| FAN-T2-M | System Fan | C9300, C9300L, C9300X |
| 4PT-KIT-T2-M | Catalyst 9300-M Rack Mount Kit | C9300, C9300L, C9300X |
*Note: The C9300-NM-2Y-M module is supported on C9300-24S/48S with firmware CS16.7. Support for the other C9300 switch models require CS16.8
*Note: The SFP28/QSFP28 modules will be orderable March 2024 with software support in CS16.7. 25Gbps Dashboard support is slated for CS17 firmware. 25Gbps optics can be used in CS16.8, but should be considered 'Beta'.
**NOTE: The PWR-C1-1900WAC-P-M provides 1900 W output power when the nominal input voltage is 230 V. If the nominal input voltage is 115 V, then the output power is limited to 1500 W. The power supply does not work with standard 125VAC power cords(common with 1100W and lower power supplies), you require a C21 power cable like the North American(C9K-PWR-CAB-AC-US). Also a good option is the universal C20-C21 jumper cable(C9K-PWR-CAB-AC-BL), suitable for Rack PDUs . See Table 2 for all suitable worldwide power cord options. Please note there are no -M versions of these cables, they must be ordered with the Cisco SKU.
SFP Modules
The following SFP/Fiber transceivers are supported. For detailed SFP specifications, refer to the Meraki SFP datasheet.
For information about Cisco Optics compatibility and Cisco's TMGmatrix, please click here.
| Transceiver Model | Standard | Supported C9300-M platform |
1 Gbps MA-SFP-1GB-SX MA-SFP-1GB-LX10
1000BASE-SX over OM1/2/3/4 up to distances of 1KM 1000BASE-LX10 over OS1/0S2 up to distances of 10KM |
10 Gbps MA-SFP-10GB-SR MA-SFP-10GB-LR MA-SFP-10GB-ER MA-SFP-10GB-ZR |
10GBASE-SR over OM1/2/3/4 up to distances of 400 M 10GBASE-LR over OS1/2 up to distances of 10 KM 10GBASE-ER over OS1/2 up to distances of 40 KM 10GBASE-ZR over OS1/2 up to distances of 80 KM |
MA-SFP-10GB-LRM |
10GBASE-LRM over OM1/2/3, OS1/2 up to distances of 300 M |
C9300, C9300L |
| 25 Gbps | Please see TMGmatrix for compatibility for SFP28 modules | C9300, C9300L, C9300X |
40 Gbps MA-QSFP-40G-CSR4 MA-QSFP-40G-SR-BD |
QSFP-MPO12 over OM2/3/4 up to distances of 400 M QSFP Duplex LC over OM2/3/4 up to distances of 150 M |
C9300, C9300X |
100 Gbps MA-QSFP-100G-LR4 MA-QSFP-100G-SR4 |
100GBASE-LR4 over OS1/2 up to distances of 10 KM 100GBASE-SR4 over OM3/4/5 up to distances of 100 M |
C9300X |
Direct Attach MA-CBL-TA-1M MA-CBL-TA-3M |
10GSFP+Cu Passive Twinax |
NOTE: Catalyst 9300X switches do not support LRM modules.
Regulations and Compliance
Electromagnetic Compatibility Certifications |
FCC Part 15 (CFR 47) Class A, ICES-003 Class A, CISPR22 Class A, CNS13438, EN 300 386 V1.6.1, EN 55022 Class A, EN 61000-3-2, EN61000-3-3, KN 32, TCVN 7189 Class A, EN 55032 , CISPR 32 Class A, V-2/2015.04, V-3/2015.04, VCCI-CISPR 32 Class A, CISPR24, EN 300 386 V1.6.1, EN 55024, KN35, TCVN 7317 |
| Safety |
CAN/CSA-C22.2 No. 60950-1, UL 60950-1, EN 60950-1, IEC 60950-1, AS/NZS 60950.1 |
| Environmental | Reduction of Hazardous Substances (RoHS) |
| Warranty | Full lifetime hardware warranty with next-day advanced replacement included |
MTBF Rating
Model |
MTBF at 25°C |
| C9300-24S-M | 284,130 |
| C9300-24T-M |
314,790 |
| C9300-24P-M |
299,000 |
| C9300-24U-M |
238,410 |
| C9300-24UX-M |
214,760 |
| C9300-48S-M | 281,920 |
| C9300-48T-M |
305,870 |
| C9300-48P-M |
277,770 |
| C9300-48U-M |
227,410 |
| C9300-48UXM-M |
202,160 |
| C9300-48UN-M |
198,647 |
Installation Guide
For instructions on how to install and configure the C9300 series switch please refer the C9300 Series Installation Guide
