GNSS Site Survey Mode
Overview
Site Survey Mode now supports GNSS Validation, leveraging the internal or external GNSS modules on Cisco Wireless Access Points. This enhancement allows delivery teams to conduct "Readiness Assessments"—verifying that a specific physical location can achieve the stable satellite lock required for 6 GHz Standard Power (SP)—long before the permanent network is installed.
Why GNSS Validation Matters for Planning?
  • For an AP to operate in 6 GHz SP mode, it must successfully query it location with an Automated Frequency Coordination (AFC) system. This query requires high-precision location data.
  • Improved Planning: Since GNSS signal strength varies significantly indoors, this feature allows you to identify "GNSS Anchor" points during the design phase.
  • Reduces location uncertainty: By validating the GNSS subsystem beforehand, you ensure that location certainty remains high. Low certainty or unstable locks can result in the AFC imposing severe power constraints or disabling the 6 GHz radio entirely.
How it Works during a Readiness Assessment
  • While the 6 GHz radio will not transmit in SP mode during a survey (as the AP has not yet received a formal AFC response), Site Survey Mode allows you to evaluate the "suitability" of the environment for the technology.
The Workflow:
  • Placement: Position an AP (e.g., via an "AP on a Stick" kit) at a proposed mounting location.
  • Evaluation: Power the AP and access the Local Status Page to monitor GNSS receiver metrics such as satellite visibility, signal-to-noise ratio, and Time-to-First-Fix (TTFF).
  • Validation: If the metrics meet the required threshold, you have successfully validated a GNSS Anchor point.
  • Iteration: Move to the next location to ensure your deployment has a sufficient density of anchors to support interior APs.
Key Enhancements
  • GNSS Module Validation: Real-time feedback on the health and performance of the installed GNSS hardware.
  • Pre-Deployment Stability Verification: Confirms that environmental factors (building materials, urban canyons) won't prevent the AP from maintaining a consistent AFC-compliant lock.
  • Support for SP Implementation: While you cannot test the 6 GHz SP signal coverage itself in this mode, you are validating the underlying requirement (GNSS stability) that makes Standard Power possible.
  • Note for Support Teams: If a customer asks how to implement SP when Site Survey mode doesn't support it, clarify that this feature is a prerequisite validation. It ensures the AP can talk to the AFC once the network is live, preventing "No GPS Lock" issues after the final installation.
How does GPS/GNSS validation enable improved planning?
GNSS reception validation is a critical component in the deployment of location-aware access points. By verifying GNSS signal availability and strength, installers can eliminate uncertainty regarding an AP’s ability to accurately determine its coordinates. Reliable GNSS reception is essential for ensuring precise location reporting to the Automated Frequency Coordination (AFC) provider, which is a fundamental requirement for compliant and efficient network operation.
  • Verifying "Anchor AP" Viability: Planning requires identifying which APs can act as "Anchors." Validation tells you exactly which perimeter locations can see enough satellites to provide a location for the rest of the floor.
  • Preventing "Dead Zones": If a survey shows a specific spot has high GNSS uncertainty the planner knows that an AP placed there will likely be throttled by the AFC. They can then adjust the plan to move that AP or use an external GNSS antenna.
  • {Change Out} Link Budgeting: By knowing an AP will successfully reach SP levels (up to 36 dBm EIRP), planners can design for larger cells, potentially reducing the total AP count compared to a Low Power Indoor (LPI) design (max 30 dBm EIRP).
What are readiness assessments?
A readiness assessment is a "Go/No-Go" audit performed before the final hardware mounting. It ensures the infrastructure is capable of meeting AFC requirements the moment the AP joins the Dashboard.
  • Physical Layer Audit: Checking for signal obstructions like metallic "Low-E" glass or heavy overhead HVAC ducting that wasn't in the original blueprints.
  • Time-to-Lock (TTFF) Testing: Confirming the AP can achieve a GPS lock within the recommended 15-minute window. If it takes 45 minutes, it’s a sign of a "marginal" location that may fail during bad weather or high atmospheric interference.
  • Documentation: Captures and download the GNSS receiver report allows detailed data to be included in a report and saved as a baseline in the event conditions change in the future..
6 GHz outdoor and high-ceiling deployments apply broadly across industries:
High-ceiling indoor deployments (e.g., warehouses, atriums, manufacturing floors) are especially sensitive to GNSS placement and lock time.
To ensure a successful 6 GHz Standard Power (SP) deployment, it is vital to account for the unique challenges of indoor GNSS reception, particularly for access points (APs) located deep within a building's interior.
Note: For detailed technical reference and deployment guidance, please refer to the Cisco document "GNSS Best Practices for AFC and Cisco Wireless AP Location Deployments" at:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/gnss-best-practices.htmlhttps://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/gnss-best-practices.html
Indoor AP Placement and GNSS Accessibility
Site surveys for 6 GHz Standard Power (SP) must prioritize GNSS validation across the entire floorplan, including the building interior and middle floors. However, achieving an AFC-compliant lock does not require every single AP to serve as a GNSS anchor.
Instead, the goal is to ensure that GNSS Anchors are strategically placed close enough to the interior APs to maintain a low area of uncertainty. Both hardware stacks include built-in methods to derive the necessary X and Y coordinates for interior APs based on the locations of these anchors.
While APs on the indoor perimeter naturally benefit from better satellite visibility, those located further from windows can still operate within standard power limits by leveraging the positioning data of nearby anchors. This proximity is key; as long as the interior units remain within the recommended range of a validated GNSS source, the system can maintain the precise location data required for AFC queries.
For specific ratios regarding the recommended number of GNSS anchors per interior AP, please refer to the Deployment Guide, which provides detailed scaling metrics for various floor plans.
Factors Influencing Signal Degradation
While it’s a common industry assumption that GNSS signals are unusable indoors, our real-world testing has shown that indoor positioning is more capable and resilient than previously thought. Many environments provide enough signal penetration for successful operation; however, to ensure the highest level of reliability for 6 GHz Standard Power services, a proactive approach to signal management is key.
Optimized GNSS Performance
Modern building materials do present challenges, but they are far from insurmountable. By understanding the environment and utilizing the right tools, you can maintain the precise location data required for the Automated Frequency Coordination (AFC) process.
  • Antenna Solutions: We offer high-performance external GNSS antennas designed to overcome local signal attenuation. Including an external antenna as a standard part of your installation kit is highly recommended; it provides a significant boost in signal gain and ensures stability in even the most challenging architectural layouts.
  • Structural Resilience: While materials like concrete or Low-E glass can attenuate signals (often ranging from 24 dB to 35 dB), many modern GNSS receivers are sensitive enough to maintain a lock. In cases where metallic films or heavy shielding are present, the external antenna serves as the perfect bridge to clear satellite visibility.
  • Managing the Environment: In "urban canyons" or dense indoor spaces where multipath interference (reflections off walls or machinery) can occur, proper antenna placement can mitigate positional uncertainty and ensure timing accuracy.
Validation through Site Survey Mode
Because GNSS signal strength is dynamic and can vary significantly within a small radius, Site Survey Mode is your best tool for success. It allows you to confirm that a specific mounting location meets the stability requirements for AFC and 6 GHz Standard Power before the final deployment.
Environmental Monitoring
GNSS performance is a reliable component of your network when managed correctly. By recommending an external antenna as a foundational part of your deployment kit, you ensure that orbital variations and environmental factors do not impact the reliability of your AFC queries, keeping your 6 GHz services running at peak performance.
Prerequisites
AP Auto Locate is supported on the following models:
  • MR78
  • MR36
  • MR46
  • MR56
  • MR57(GPS capable)**
  • CW9162 (GPS capable)**
  • CW9164 (GPS capable)**
  • CW9166I (GPS capable)**
  • CW9172I (GPS capable)**
  • CW9174I (GPS capable)**
  • CW9176I (Integrated GPS)
  • CW9178I (Integrated GPS)
Deployment Prerequisites
  • AP is powered on and mobile
  • AP is powered by a wall outlet or external battery pack
Note: Cisco legal recommends the surveyor to attach a physical label to identify the AP as “Indoor RF survey use only”
  • AP is NOT connected to the Internet
  • AP is NOT connected to the Meraki Dashboard
  • AP is operating in Site Survey Mode
  • GNSS module is:
  • Plugged in (Wi-Fi 6E APs)
  • Embedded or externally attached (Wi-Fi 7 APs)
Dashboard Connectivity & AFC Validation While in Site Survey Mode, the Access Point operates without an active uplink to Dashboard. Because a real-time connection to a cloud-based Automatic Frequency Coordination (AFC) service is a strict regulatory requirement for 6 GHz Standard Power, the AP cannot invoke AFC or authorize SP operation while in this mode. AFC site survey Mode is for validation and planning of GNSS readiness; 6 GHz radios will remain in a restricted state until the AP is fully deployed with active internet connectivity.
Mobility and Power Constraints Per current regulatory frameworks (e.g., FCC/ISED), 6 GHz Standard Power operation is strictly reserved for fixed infrastructure.
  • No Mobile Operation: An AP that is mobile, non-fixed, or mounted on a temporary/moving platform is prohibited from SP operation.
  • Battery Power: APs are powered by an internal or external battery pack (typical for portable survey rigs) do not meet the "fixed installation" criteria for Standard Power and must not be used to represent final SP performance.
Connecting to the Local Status Page of MR Access Points
Connection Requirements
Before attempting to access the LSP, ensure your client device (laptop or tablet) is connected correctly:
  • Wireless Connection (Required): For security reasons, MR APs do not allow access to the LSP via a wired Ethernet connection. You must be connected wirelessly to an SSID being broadcasted by the AP.
  • Standard Access: Connect to any configured service SSID currently being broadcasted.
  • Default SSIDs (Troubleshooting): If the AP is not yet configured or has lost internet connectivity, look for and connect to these default SSIDs:
  • meraki (Standard out-of-the-box SSID)
  • Meraki Setup
  • meraki-<MAC_Address> (e.g., meraki-xx:xx:xx:xx:xx:xx)
Accessing the Page
Once connected to the SSID being broadcasted by the AP's radios.
  1. Open a Web Browser (Chrome, Firefox, Safari).
  1. Enter the URL: Navigate to one of the following addresses:
  1. http://ap.meraki.com
  1. http://my.meraki.com
  1. Direct IP: 10.128.128.126
Note: If using the Direct IP, you must manually configure your computer's IP settings to:
  • IP Address: 10.128.128.125
  • Subnet Mask: 255.255.255.0
Login Credentials
Depending on your firmware version, use the following credentials:
Firmware 31.7.1+:
  • Username: admin
  • Password: The Serial Number (all caps with dashes, e.g., Q2XX-XXXX-XXXX) or the Cloud ID of the device.
Older Firmware:
  • Username: The Serial Number of the device.
  • Password: Leave blank.
Key Features and Tools
The LSP is divided into several tabs depending on the AP model (MR31 and earlier vs. MR32+):
Tab
Description
Connection
Shows real-time status of the AP's connection to the Meraki Cloud, current channels, and network info.
Configure
Allows you to set a Static IP, configure a Proxy, or enable Site Survey Mode (requires the AP to have checked into the dashboard at least once).
Neighbors
(MR32+ only) Displays nearby access points, including their SSID, BSSID, and signal strength (SNR).
Access Point Details
Shows hardware utilization and channel congestion data.
Troubleshooting Access
If you cannot reach the LSP:
  • Verify Power: Ensure the AP's LED indicates it is receiving power.
  • Check SSID: Ensure you are connected to an SSID specifically broadcast by the target AP.
  • Check Gateway Failures: If you see an SSID like <SSID_name>-bad-gateway, the AP cannot reach its default gateway. Use the LSP to check the IP configuration.
  • Remote Access: By default, the LSP is only accessible via Wi-Fi. If you need to access it via the LAN IP (wired), this must be enabled in the Meraki Dashboard under Network-wide > Configure > General.
Enabling GNSS Site Survey Mode
  1. Navigate to the Configure tab
  1. Enable Survey mode
3. Enable GNSS Measurements
4. Save the Configuration
5. The AP will reboot into Site Survey mode
undefined
Connecting to the Survey mode SSID
The AP will stop broadcasting its production SSIDs and instead broadcast a specific Site Survey SSID.
The name of the site survey SSID follows a standard format:
  • SSID Name: site_survey-<MAC_Address>
  • Format Example: site_survey-xx:xx:xx:xx:xx:xx
  • Security: This is an Open SSID (no password required), allowing you to associate quickly to perform signal testing or access the LSP wirelessly while the AP is offline.
Note: Disconnection from Dashboard
In Site Survey Mode, the AP is designed to operate "offline." and does not need to reach the Meraki Dashboard to function. This is critical for new deployments where the local internet infrastructure (cabling, switches, or an ISP) may not yet be installed.
View GNSS data
  • Satellite Availability: As the GNSS measurements are in progress, display the information regarding available satellites in real-time and its attributes:
  • GNSS Post Processor Output: As satellite readings get reported and GNSS lock is received, display the measurements calculated by the GNSS Post Processor: Latitude Longitude Uncertainty Eclipse
  • Cisco GNSS Processor Output: Display the measurements calculated by Cisco GNSS Processor obtained by fine-tuning the GNSS Post Processor output over time.
To provide a complete "Proof of Performance" for your deployment, the local status page includes a GNSS Report Download feature. This serves as the physical verification that a specific mounting point is capable of Standard Power (SP) operation.
Note: For a reliable validation of 6 GHz Standard Power (SP) readiness, it is recommended to allow the AP to remain stationary in its test position for at least 15 to 20 minutes before saving the GNSS report.
Why: This allows the Cisco GNSS Processor to filter out Multipath Interference (signal echoes) and refine the Uncertainty Ellipse.
Verify AFC Status
  1. Connect AP to the Internet and onboard the device to Dashboard.
  2. Navigate to the Access Point list, and select an AP that is now enabled for AFC.
  3. From the AP’s overview page, select the AFC tab. Verify AFC status
AFC Status
The AFC overview page shows the current AFC status of an AP. A status of active means a successful request to the AFC provider along with the associated response. The AFC status page includes the target expiration time at which the current AFC response expires. Per regulation, every AP operating in 6 GHz, AFC status needs to be refreshed once a day (every 24 hours).
Placement Recommendation
Based on the quality of the GNSS signal and time to get a location lock, during survey mode for GNSS:
Optimal for GNSS Placement
  • ≥ 8 satellites (High quality)
  • Stable lock within ≤ 15 minutes
  • Low uncertainty ellipse
Conditionally Acceptable
  • 4–8 satellites
  • Lock within ≤ 15 minutes
  • Moderate uncertainty
Not Recommended for GNSS Placement
  • < 4 satellites
  • Lock time > 15 minutes
  • High positional uncertainty
  • Frequent loss of lock
Without reliable GNSS:
Anchor AP Placement
A Minimum of 4 Anchor APs per floor: This provides the geometric diversity needed for the system to triangulate the positions of indoor APs.
Strategic Placement: Anchor APs should be placed at the edges of the building (near windows or thin walls) where a strong GNSS signal is expected.
Distance Awareness: Anchor APs should be within "hearing distance" of non-anchor APs. If an AP is too far away to exchange beacon frames, it won't be able to inherit a location on dashboard.
Geolocation Propagation Methods
When an AP is deep in the interior and cannot see satellites, it uses AP Auto Locate (Cisco’s "Any Locate" technology) to determine its position relative to the anchor APs on a floorplan.
Wireless Propagation (FTM/802.11mc)
How it works: APs use Fine Timing Measurement (FTM) to measure the round-trip time of radio signals between themselves and the Anchor APs.
Benefit: This calculates the distance down to a few meters, allowing an indoor AP to "borrow" the coordinates of the anchors and calculate its own offset.
Requirement: APs must be able to "see" each other on the 6 GHz or 5 GHz bands to perform these measurements.
Wired/Manual Propagation
How it works: If wireless ranging is impossible (e.g., extremely thick lead-lined walls in healthcare), you can manually set the location of an AP on the Meraki Map.
SP Constraint: Manually placed APs can act as anchors for others, but they require high-precision placement on a georeferenced floor plan to ensure the AFC uncertainty remains within regulatory bounds.
3. Implementation Checklist & Resources
To ensure your Standard Power deployment doesn't fall back to Low Power (LPI), keep these links handy for your implementation team:
Automatic Frequency Coordination (AFC) Overview: The definitive guide on regulatory sub-bands (U-NII-5 and U-NII-7) and power levels.
AP Auto Locate Deployment Guide: Detailed steps on how to configure anchors and run the "Ranging" process in Dashboard.
6 GHz Frequently Asked Questions: Covers the nuances of client device compatibility and PSD (Power Spectral Density) rules.
