Cisco+ Secure Connect -Troubleshooting Remote User Reported Errors
Issue/Error |
Possible Cause |
Resolution |
Any issues with establishing a VPN connection |
“Establishing VPN”… and eventually the connection fails | Likely SSL vpn is getting blocked via an upstream device. To double check, have the user run DART |
Configure a SAML IDP ( SAML Configuration Guide) | ||
Valid user account but not a user that is authorized for the service |
This error occurs when logged onto a computer remotely using RDP (Remote Desktop) | AnyConnect blocks this by default but this can be optionally allowed in (Deployments > Remote Access > Settings > Client Configuration"Tunnel | ||
"I can't access my local network services while I'm connected" | Local LAN access not enabled |
Note: This feature is controlled by the headend (Umbrella). See About Traffic Selection for more details |
End user sees this pop up upon connection attempt. Prompt for user authentication is not seen. |
This occurs when Compatibility Mode is enabled in Internet Explorer |
Uncheck "Display intranet sites in Compatibility View" |
User is trying to establish a VPN session via the Remote Desktop Protocol (RDP). |
Allow user to establish a VPN session via RDP by changing "Admin Settings" under Client Configuration to Allow Remote Users |
This occurs when the address pool is exhausted. | Increase the address pool size |
