Using Layer 3 Firewall Rules
Layer 3 Firewall rules provide an administrator granular access control of outbound client traffic. With the MR series, outbound traffic refers to client traffic originating from the wireless network that is destined for the wired LAN or Internet. On the MX, outbound traffic refers to traffic originating from one VLAN that is destined for another VLAN or traffic originating from the LAN that is destined for the Internet or a remote network that is located over a static LAN route. This article discusses how to use Layer 3 Firewall rules on MR series access points, MX Security Appliance or Z-series Teleworker gateways.
Learn more with these free online training courses on the Meraki Learning Hub:
A layer 3 firewall rule on the MX or Z-series appliance is stateful and can be based on protocol, source IP address and port, and destination IP address (or FQDN) and port. Layer 3 firewall rules on the MR are stateless and can be based on destination IP address and port. Dashboard presents the rules in numeric order, they are evaluated from top to bottom beginning with rule number 1. The first rule that matches is applied, and subsequent rules are not evaluated. If no rules match, the default rule (allow all traffic) is applied.
Note: Prior to MX 26.1 firmware layer 3 firewall rules are stateless when configured within Meraki Dashboard network-wide group policies. Group policy layer 3 firewall rules can be based on protocol, destination IP (or FQDN for MX and Z-series appliances), and port. You can specify a range of ports, such as "1024-400" in group policy layer 3 firewall rules. However, listing individual ports separated by commas, such as "80,443" is not supported.
In MX 26.1+ firmware the group policy firewall rules are now stateful to align with the regular MX firewall rules.  Additionally, a new org-wide group policy capability was introduced which supports port, port ranges and comma separated port lists within single rules.  The org-wide group policy rules also combine the traditionally separate layer 3 and layer 7 rules so now a single rule can define both layer 3 and layer 7 match criteria as well as allow or block decisions.
Note: Layer 3 Firewall rules (configured on the Firewall page) do not apply to traffic destined for locations across both AutoVPN and Non-Meraki VPN. To configure Layer 3 Firewall rules for VPN destined traffic, refer to this KB.
Firewall rules configured in a network-wide group policy or org-wide group policy apply to all traffic from the client or VLAN where it is applied no matter if the traffic is destined over VPN or not.  The site-to-site outbound firewall applies in addition to and after group policy firewall rules.
An explanation of the fields in a Layer-3 firewall rule is shown below.
  • #: The sequence number of a particular firewall rule.
  • Policy: Specifies the action the firewall should take when traffic matches the rule. Matching traffic can be allowed or denied.
  • Protocol: Specifies the protocol to match in outbound traffic i.e. TCP, UDP, ICMP, ANY.
  • Source (MX/Z-series only): Specifies the source IP address or network address using CIDR notation to match in outbound traffic. "Any" can also be used to specify all networks.
  • Src port (MX/Z-series only): Specifies the source port number to match in outbound traffic. This can be a single port, port range, multiple comma-separated ports, or "any".
  • Destination: Specifies the destination IP address, FQDN (for MX and Z-series appliances), or network address using CIDR notation to match outbound traffic. "Any" can also be used to specify all networks. Note that, on a network with an MX handling inter-VLAN routing, the IP address of the MX on the destination subnet may still respond to any services (For example: ICMP pings, SNMP, and so forth) it's configured to listen for, even if the rule is set to block traffic. This is due to the nature of software routing on the MX and does not pose a security risk; host devices on the destination subnet will still be blocked according to the rule.
  • Dst port: Specifies the remote port number to match in outbound traffic. On the MX, this can be a single port or multiple comma-separated ports. On the MR, this can be a single port or port range.
  • Comment: A description of the rule.
  • Hits (MX/Z-series only): A counter reflecting the number of times the rule was applied. The counter starts each time the page is accessed.
  • Actions: Options to delete or change the order of a rule.
  • Logging: If syslog reporting is enabled, denotes whether or not to report on a given rule.
When specifying the Src port and the Dst port with the use of port ranges, the formatting should be considered.
For example: "1024-5000" or "1024, 5000" is valid, but "1024-5000, 5004" is not valid.
In MX 13.4 firmware and higher, fully qualified domain names (FQDNs) can be configured in the Destination field. For more details, please read the FQDN Support section of Firewall Settings. FQDNs cannot be configured for MR network firewall rules and will not apply to MR clients if configured in a group policy.
Example Configurations
Use Case 1: In the example below we want to block all IP traffic originating from network 10.0.0.0/8 that is destined for network 192.168.1.0/24. However, we do not want to block traffic originating from network 192.168.1.0/24 that is destined for 10.0.0.0/8 or block either network from accessing other remote networks such as the Internet.
Block all IP traffic from 10.0.0.0/8 to 192.168.1.0/24 while allowing traffic in the reverse direction and unrestricted access to other networks, including the Internet.
Based on the rules shown below, any traffic originating from the 10.0.0.0/8 network destined for the 192.168.1.0/24 network matches rule 1 which is evaluated first. Because the "Policy" for this rule specifies a "Deny" action, the firewall will block all traffic when the rule is hit. The second rule evaluated which is the default rule, enforces an implicit allow all. All other traffic will match this rule. Hosts on either network can send data to any other remote network.
Note: When selecting “ANY” from the Protocol menu, the choice for Src port and Dst port become grayed out because this setting matches all IP traffic.
When "ANY" is selected in the Protocol menu, Src port and Dst port options are disabled as this setting applies to all IP traffic.
Use Case 2: In the example below, we want to allow any host in the network 10.0.0.0/8 to access a web server 192.168.1.254 that is listening on TCP port 80. However, we want to block any other outbound traffic from hosts in 10.0.0.0/8 or host 192.168.1.254.
Allow hosts in 10.0.0.0/8 to access web server 192.168.1.254 on TCP port 80 while blocking all other outbound traffic from 10.0.0.0/8 and 192.168.1.254.
Based on the rules shown below, traffic originating from any host on the 10.0.0.0/8 network that is destined for web server 192.168.1.254 on TCP port 80 is allowed. When the local host communicates with a service on a remote host, it normally picks an ephemeral source port and sends traffic to the port used by the service on the remote host. This is why the source port in this rule is set to "Any." Because there is an implicit allow rule processed last and we want to perform a "Deny" action on all other outbound traffic from hosts on the 10.0.0.0/8 network and the web server, a deny all rule is required. This rule needs to be evaluated right after rule 1. Because the firewall is stateful, replies from the web server to hosts on the 10.0.0.0/8 network are allowed the bypass the deny rule due to the connection is already being established. The deny will rule which is processed second will match all other traffic besides traffic to the web server.
Note: Cisco Meraki firewalls implement an inherent Allow All rule which can't be modified and is the last rule processed. Firewall rules are processed from the top down.
Cisco Meraki firewalls process rules from top to bottom, ending with an unmodifiable Allow All rule as the last rule.
  • Was this article helpful?
