Returns (RMAs), Warranties and End-of-Life Information
Click 日本語 for Japanese
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact Support to address the issue. Once Support determines that the device hardware is in a failed state, they can process an RMA and send out a replacement device free of charge. Support will give you a reference number to manage your RMA, including returning the failed device, using the POWR tool.
More details on how to generate return label can be found here: Quick Start Guide
Note that, for end-customer device security, RMAs may only be requested by Organization Admins (Read Only or Full), or Network Write Admins (only for devices in networks of which they are Admins). Meraki Support will not process RMAs unless the support agent can verify the requester has sufficient network permissions.
For more information about Cisco Meraki returns, please refer to our Return Policy.
Note: Return policy terms may vary by region. Please refer to the Regional Return Policies section of the Return Policy documentation for region-specific terms.
Hardware Returns
If you are experiencing hardware issues, please contact Cisco Meraki support by logging in to Dashboard (Help > Get help) or by calling us.
To request a warranty Return Materials Authorization (RMA), please call Cisco Meraki technical support. Unless you have purchased Cisco RMA Upgrade (fomerly Meraki Now), advance replacement orders will ship within 1 business day on a best case effort basis.
Additional information about Cisco Meraki’s hardware warranty can be found in Cisco Meraki’s End Customer Agreement.
Note: Devices that are dormant (grey status) and not connected or seen by the Meraki Dashboard require a photograph of the device with the serial number to process the RMA.
This does not apply to devices that have failed and show as recently offline in Dashboard (red status), or devices that are being RMA’ed for other reasons.
Customer must return defective parts in accordance with Cisco’s return materials authorization (RMA) procedure located at www.cisco.com within ten (10) calendar days of receipt of the replacement parts. If Customer has not returned the defective parts (which must conform in quantity and serial number to the RMA request) within thirty (30) calendar days of receipt of the replacement parts, Cisco may:
- charge Customer for the full list price (not discounted) of the parts not returned; and
- reduce or deny Services until the parts are returned or payment for non-return is made.
This policy also applies to returns facilitated by Cisco authorized resellers.
You must have a current service contract to return a defective part for replacement. The type of maintenance contract purchased determines when your replacement part is received. See the list of service contract types.
If you require an extension to due date because of special circumstances, contact Cisco Asset Recovery to request approval.
Warranty Coverage Period
Cisco Meraki stands behind its products. Hardware products generally come with a 1-5 year warranty or a lifetime warranty.
The below table is a general guideline for warranty terms and is not final. Warranty terms are subject to printed warranty information on the relevant datasheets located in the "Notes" column of the table below, or on the Explore Collateral page of the Cisco Meraki website.
Some general warranty term lengths can be found below:
| Product/Category | Warranty Period*** | Notes |
| MX or Z-Series | Lifetime** | Refer to datasheets on the MX Overview and Specifications page for warranty information. |
| C8455-G2-MX | 2 Year | Cisco 8400 Series Secure Routers come standard with a Cisco Limited 2-Year Return To Factory Hardware Warranty. |
| MG | Lifetime** | Refer to datasheets and technical specifications on the MG Datasheets page for warranty information. |
| MS/CS (e.g. MS120, MS350, C9300-M) |
Lifetime** |
| Indoor MR/CW | Lifetime** |
Applies to MR device and ethernet cables in box Refer to datasheets on the MR Overview and Specifications page for warranty information and indoor/outdoor use. |
| Outdoor MR/CW | 1 Year |
| MV Gen 1 and MV2 | 3 Years | Includes MV21, MV71, MV2 |
| MV Gen 2 and beyond (e.g. MV12, MV32, MV63) | 5 Years | Does not include MV2 |
| MT Sensors | 3 Years | Includes all MT sensors |
| Accessories* | 1 Year |
The following are considered accessories: Meraki SFP Modules, twinax/SFP+ cables, stacking cables, all mounting kits and stands, antennas, interface modules, additional power cords, PoE injectors, MT accessories |
*Original and replacement modular power supply units and fans for MS and MX Products are included in lifetime warranty and not the 1-year warranty for accessories.
**Product lifetime ends concurrently with product End-of-Support (EOST) Date as described in Cisco Meraki's End of Life (EOL) Policy.
***The Warranty Period commences on the date Hardware is shipped to the original purchaser as outlined in Cisco's General Terms
Note: Causes of performance issues that are beyond the reasonable control of Cisco Meraki are not included in the scope of the warranty.
For more information, refer to the Service Level Warranty or Cisco's General Terms
Note: a warranty is not the same as a license.
Example: MR74 can have a valid 3-year Enterprise MR license, but that is separate from the 1-year warranty coverage period. In the given scenario, the MR device is not replaceable after the coverage period ends, regardless of license validity.
RMA Processing For Outdoor Cameras
Note that before RMA can be submitted for outdoor cameras, we require 3 photos of the unit showing the following:
RJ-45 waterproof coupling (black cable connector) assembled in its original deployed state
Photo showing close up of the internal pins inside the ethernet connector of the camera
Image which clearly shows serial number of the unit
Specifically for the MV63/93 models we will also require the following:
Picture of the Ethernet cable and termination that was connected to the camera; if possible, a sample of the cable along with the camera.
Shipments for Warranty RMAs
Cisco can only ship warranty RMAs to the original shipping country/region as listed on the original order.
Please note, this is not necessarily the registered customer address, but where Cisco physically shipped the order.
Purchasing a service contract, like Cisco RMA Upgrade, will allow the shipment to alternate countries based on the Install address listed in CCW-R. Availability of service contracts is based on the Service Availability Matrix (SAM). If you are interested in purchasing a service contract, please work with your Cisco Sales team or preferred Cisco approve Partner.
Troubleshooting before Returns
Prior to performing an RMA, Cisco Meraki Support will need to verify that some basic troubleshooting has been performed to resolve common issues. Please refer to the following articles for common symptoms and troubleshooting steps:
- Troubleshooting a Faulty MR Access Point
- Troubleshooting a Faulty MS Switch
- Troubleshooting a Faulty MX Security Appliance or Z-Series Teleworker Gateway
- Troubleshooting a Faulty MG Cellular Gateway
- Troubleshooting a Faulty MV
Note: Meraki Support may request a video of the device during normal device failure analysis, identification, and troubleshooting.
Product Trial Returns
If you would like to return units from a product trial, please go to your product trial webpage (using the link your rep provided you with) and go to the returns tab to fill out the RMA request form. After you submit the RMA, you will receive an RMA number and be directed to Cisco’s Product Online Web Returns (POWR) tool to schedule carrier pick up or print a pre-paid return label to return the trial.
Refund Requests
Effective October 26, 2025, the Meraki return policy will be fully aligned with Cisco's "All Sales are Final" return policy. As of this date, the Meraki "license-only" exception has been retired and is no longer in effect.
To initiate a return with credit, eligible requestors with CCO access from the billing party must submit requests in CCW Returns Tool.
In accordance with Cisco’s “All sales are final” policy, all return with credit requests including license only returns are subject to Cisco’s approval. Please see the Standard Terms and Conditions of Sale for a list of terms and condition by region. For additional information, please contact your Cisco sales representative.
Return procedure may vary depending on the type of return being requested. Refer to the Return a Product page for more information and complete instructions.
Refer to following CCW Ordering Guides for subscription changes and cancellations:
After returning licenses, the original license key will be invalidated. If any licenses from the order were not returned, a new license key will be generated for the remaining licenses. This new license key will be emailed to the individual(s) who submitted the RMA request. If the original key was previously claimed to an organization, the new license key will automatically take its place (no need for further action).
Returning Your Faulty Device
- Please return units in their entirety, with all accessories that shipped in the original box.
- Please use the original shipping carton and packaging material. If this is not possible, use another shipping carton with padding to protect the units from damage during shipping. DO NOT ship a product without a carton.
- The customer will be charged for product that is damaged due to insufficient packaging.
- Once you have received your RMA number from Cisco Meraki via email, write this RMA number in large letters on the exterior of the shipping carton. Shipments to Cisco Meraki without an RMA approval will not be processed.
- To return the defective device you will need to generate a shipping label via the POWR tool. You can follow the directions given on the Cisco Returns Portal to generate a shipping label and also to request a pickup of the shipment.
- Return labels cannot be emailed or mailed. Labels are only generated via POWR.
To access the POWR tool, you'll need a valid Cisco Account (CCO ID). If you haven't created one yet, please follow the steps outlined in the CCO ID Registration article to get started.
Please note some Cisco Meraki devices do not need to be returned and can be e-wasted. When looking at the RMA in Cisco Product Returns and Replacements (PRR), if there is no "Return" tab, the device does not need to be returned. Cisco Meraki Support can confirm this for you if you cannot view the RMA in PRR.
You can engage the Cisco "Takeback and Reuse" program. Please note you will need to log in with your CCO ID.
Avoiding Licensing Issues After Replacing Device
When adding the replacement device to your Dashboard network, you may see a licensing compliance warning if that additional device caused your total device count to exceed your licensed limit.
Once the replacement device has been added to a network, it is recommended to remove the faulty device from its Dashboard network. The faulty device may remain in your inventory, but as long as it is not currently in a network it will not count toward your device limit.
Product End-of-Life (EOL)
Painting Cisco Meraki Devices
It is sometimes necessary to place APs or cameras in publicly visible areas that require them to blend into their surroundings. With access points, Cisco Meraki typically recommends hiding the AP from view (e.g., above a drop ceiling). However, customers sometimes choose to paint their APs or cameras to match the area where they are mounted.
Points to consider when painting a device:
Because paint has the potential to damage the units, painting does void the Cisco Meraki warranty. There is an exception for indoor Meraki MV smart cameras, see below.*
- Avoid getting paint inside of the unit, especially if painting cameras or indoor APs. Tape over LEDs, antenna connectors, screw holes, the camera dome, etc. to prevent paint from getting inside the chassis.
- The default white color of the device reflects light. Darker colors will absorb more sunlight and may cause the device to overheat.
- Never use paint with metal flakes, lead, carbon, or any other conductive material, as this will greatly degrade the device's ability to operate. This is especially true if used on antennas.
If theft is a concern, APs and cameras can run in "dark mode" which will turn off the LED lights on the unit, making the unit less noticeable at night. Please reference our documentation for more info.
*Warranty for painting Cisco Meraki MV cameras:
If the cause of the failure of the MV camera is due to the painting, we will not honor the Warranty.
Under the condition that the below instructions are met, the product warranty is valid and will be honored for painted INDOOR MVs ONLY.
This does not apply to OUTDOOR MV cameras; painting outdoor MV cameras will void the warranty.
Conditions:
The camera lens or lens cover should not be painted.
Paint must not seep under the casing, chassis, or into the materials at any point.
Things to note when painting cameras:
Product performance may deteriorate due to the painting.
Darker colors absorb more sunlight, which can affect the thermals of the product. This can impact camera's video recording performance such as fluctuation in recording FPS or corrupted video as well as missed object detections.
Meraki Technical Support will not assist in the painting of these cameras. With painted cameras, RMA processing time may be longer than usual due to the further review required before approval.
