MS130 Datasheet
Overview
Cisco Meraki MS130 switches provide Layer 2 access switching, ideal for branch and campus deployments. The MS130 series features a variety of options designed to meet the diverse needs of branch and campus deployments.
With 10 different models, capable of providing up to 740W of power over a variety of port densities, including SFP+ capable uplinks, the MS130 line is fully ready to support future wireless infrastructure deployments across a variety of different environments.
A picture of the different version of the MS130 switch series, stacked next to eachother
Features
  • Managed via Cisco Meraki Dashboard
  • Remote Packet Capture Tools via Meraki Dashboard
  • Automatic Firmware upgrades
  • SNMP/Syslog Integration
  • IPv4/6 ACL support
  • 802.1Q VLAN tagging
  • DHCP Snooping
  • 802.1X Authentication
  • 10/100/1000 Mbps RJ45
  • 100M/1G/2.5G mGbE RJ45
  • 4x 10 Gbe SFP+ models available
  • 802.3at PoE up to 30W per port
Configuration
The basic initial configuration of the MS130 is just as simple as any other model of MS switch. The links below provide additional information and instructions relating to each step in getting the device setup and configured for the first time.
  1. Claim the device to an Organization on the Meraki Dashboard
    1. If a Dashboard Organization does not yet exist, Create one
  2. Add the device to a Dashboard Network
    1. If a Network does not yet exist, Create one first
  3. Physically connect the device to the local network
    1. Connect one of the RJ45 or SFP/SFP+ ports to existing infrastructure to provide a temporary uplink
    2. Power on the device and let it check in to the Dashboard
    3. If necessary, configure a Static IP through the Local Status Page to allow it to communicate with the Meraki Dashboard.
  4. Allow the device to complete check-in and perform any initial firmware upgrades
  5. Finish configuring the device from the Meraki Dashboard
    1. Manage local VLANs / Port configuration
Technical Breakdown
Hardware Breakdown
MS130 Models
  MS130-8 MS130-8P MS130-8P-I MS130-8X MS130-12X
1Gbe RJ45 8 8 8 6
8
mGbe RJ45 (100M/1G/2.5G) - - - 2 x 2.5G 4 x 2.5G
1 Gbe SFP
2 2 2 - -
10GbE SFP+ - - - 2 2
Dedicated Mgmt Interface - - - - -
PoE Type - 802.3at 802.3at 802.3at 802.3at
PoE Port Budget - 30W 30W 30W 30W
PoE Switch Budget - 120W 120W 120W 240W
Power Input 12VDC, 2.5A 54VDC, 2.78A 100-240V~, 2.8A-1.2A, 50-60Hz
54VDC, 2.78A
54VDC, 5.56A
Power Load (idle/max)
8W/8W 8W/128W 8W/128W 16W/136W 19W/260W
Operating Temperature 32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
Storage and Transportation Temperature
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
Humidity 5% to 95% 5% to 95% 5% to 95% 5% to 95% 5% to 95%
Mounting
Desktop
Integrated Wall mount
Desktop
Desktop
Desktop
Desktop
Switching Capacity 20 Gbps 20 Gbps 20 Gbps 62 Gbps 76 Gbps
Power Supply External External Internal External External
Fan Operation Fanless Fanless Fanless Fixed Internal Fixed Internal
Dimensions (h x w x d)
1.1 x 8.74 x 6in
(2.8 x 22.2 x 15cm)
1.1 x 8.74 x 6in
(2.8 x 22.2 x 15cm)
1.75 x 9 x 8.58in
(4.4 x 23 x 23cm)
1.75 x 9 x 8.58in
(4.4 x 23 x 23cm)
1.75 x 9 x 8.58in
(4.4 x 23 x 23cm)
Weight 1.94 lb (0.88 kg) 1.94 lb (0.88 kg) 2.86 lb (1.3 kg) 2.12 lb (0.96 kg) 2.34 lb (1.06 kg)
  MS130-24 MS130-24P MS130-24X MS130-48 MS130-48P MS130-48X
1Gbe RJ45 24 24 18 48 48 40
mGbe RJ45 (100M/1G/2.5G) - - 6 x 2.5G - - 8 x 2.5G
1Gbe SFP 4 4 - 4 4 -
10Gbe SFP+ - - 4 - - 4
Dedicated Mgmt Interface 1 1 1 1 1 1
PoE Type - 802.3at 802.3at - 802.3at 802.3at
PoE Port Budget - 30W 30W - 30W 30W
PoE Switch Budget - 370W 370W - 740W 740W
Power Input 100-240V~, 1.5-0.85A, 50-60Hz 100-240V~, 8A-4A, 50-60Hz 100-240V~, 8A-4A, 50-60Hz 100-240V~, 1.5-0.85A, 50-60Hz 100-240V~, 12-6A, 50-60Hz 100-240V~, 12-6A, 50-60Hz
Power Load (idle/max) 15W/15W 32W/406W 50W/421W 28W/28W 49W/803W 60W/808W
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
32°F - 113 °F
0°C - 45°C
Storage and Transportation Temperature -4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
-4°F - 158 °F
-20°C - 70°C
Humidity 5% to 95%     5% to 95%     5% to 95%     5% to 95%     5% to 95%     5% to 95%
Mounting Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount Integrated 1U Rack Mount
Switching Capacity 56 Gbps 56 Gbps 146 Gbps 104 Gbps 104 Gbps 200 Gbps
Power Supply Fixed Internal Fixed Internal Fixed Internal Fixed Internal Fixed Internal Fixed Internal
Fan Operation Fanless Fixed Internal Fixed Internal Fanless Fixed Internal Fixed Internal
Dimensions
1.73 x 17.32 x 10in
(4.4 x 44 x 25cm)
1.73 x 17.32 x 10in
(4.4 x 44 x 25cm)
1.73 x 17.32 x 10in
(4.4 x 44 x 25cm)
1.73 x 17.32 x 10in
(4.4 x 44 x 25cm)
1.73 x 17.32 x 13.4in
(4.4 x 44 x 34cm)
(4.4 x 44 x 34cm)
Weight 7.19 lb (3.26 kg) 8.91 lb (4.04 kg) 9.37 lb (4.25 kg) 8.14 lb (3.69 kg) 12.13 lb (5.5 kg) 12.59 lb (5.71 kg)
Whats In the Box
Model Included
MS130-8, 8P, 8X, 12X MS130 switch, AC Power Supply
MS130-8P-I, MS130-24, 24P. 24X, 48, 48P, 48X MS130 switch
Region-specific power cords are not included in the box*. Order the appropriate power cord separately:
  • MA-PWR-CORD-US
  • MA-PWR-CORD-EU
  • MA-PWR-CORD-UK
  • MA-PWR-CORD-CN
  • MA-PWR-CORD-IN
  • MA-PWR-CORD-BR
  • MA-PWR-CORD-TW
  • MA-PWR-CORD-AU
  • MA-PWR-CORD-AR
  • MA-PWR-CORD-JP
*1 MA-PWR-CORD-US is included automatically with US orders only
Rack mount screws are included with the MS130-24, 24P. 24X, 48, 48P, 48X models.
Accessories
Power Supplies
Description Accessory Supported models
150 W power adapter MA-PWR-150WAC-ADP MS130-8X and MS130-8P
300 W power adapter MA-PWR-300WAC-ADP MS130-12X
30 W power adapter MA-PWR-30WAC MS130-8
SFP Modules
The following SFP/Fiber transceivers are supported
SFP Models
  • MS130-8, 8P, 8P-I
  • MS130-24, 24P
  • MS130-48, 48P
Supported Modules
  • MA-SFP-1GB-SX
  • MA-SFP-1GB-LX10
  • MA-SFP-1GB-TX
SFP+ Models
  • MS130-8X
  • MS130-12X
  • MS130-24X
  • MS130-48X
Supported Modules
  • MA-SFP-1GB-SX
  • MA-SFP-1GB-LX10
  • MA-SFP-1GB-TX
  • MA-SFP-10GB-SR
  • MA-SFP-10GB-LR
  • MA-SFP-10GB-ER
  • MA-CBL-TA-1M
  • MA-CBL-TA-3M
* For more information regarding the SFP modules, see the following Cisco Meraki datasheets:
-  SFP and Stacking Accessories
Troubleshooting
The MS uses LEDs to inform the user of the device's status. Functions are described below, from left to right. For fixed Ethernet ports, the status LED is on the top left or bottom right depending on port orientation. There is also a traffic LED which flashes orange as traffic is sent/received through that port.
Function
LED Status
Meaning
Power
Solid orange
Switch is unable to connect to the Meraki cloud
Flashing white
Firmware upgrade in process
Solid white
Switch is fully operational and connected to the Meraki cloud
Off
Switch does not have power
Switch Ports
Off
Port is operating at less than full speed. For example:
  • 10/100M on a 1GE port
  • 100M/1GE on 2.5GE ports
  • 1G on SFP+ ports
Solid green
Port is operating at full speed
  • 1GE on 1GE ports
  • 2.5GE on 2.5GE ports
  • 10GE on SFP+
Common Troubleshooting
My device is connected to the network but not checking in to the Meraki cloud or shows a solid Orange LED.
Confirm that the device is powered on and has a valid IP address that is able to access the Internet. Use the Local Status Page to get more information about the connectivity status of the device such as if it can successfully reach the Local Gateway, Internet, and/or Meraki Cloud servers. If necessary, contact Meraki Support for additional assistance.
My Status LED is blinking WHITE
A blinking WHITE Status LED indicates that the device is in contact with the Dashboard Cloud servers and is performing a firmware update. This can sometimes take 20-45 minutes or more to complete depending on hardware and other factors.
My Status LED is blinking ORANGE
The device is not able to successfully communicate with the Dashboard Cloud servers or there may be a hardware issue with the device. Check the Local Status Page of the device to confirm the status and reach out to Meraki Support for further troubleshooting.
Event Log
The most common Event Log messages and their meaning are listed below.
  • Port STP change: Indicates the STP state of the port has changed, lists the relevant port number, previous, and new states. Typically accompanied by a 'Port status change' event.
  • Port status change: Indicates the link state of the port has changed, lists the relevant port number, old, and new state. Always accompanied by a 'Port STP change' event.
  • SFP module inserted/removed: Indicates that an SFP module was either inserted or removed, includes SFP module information for inserted events and always lists the relevant port number.
Licensing
MS130 license structure includes two feature tiers:  Enterprise and Advanced. The Enterprise license is available in 1, 3, 5, 7, and 10 year terms. The Advanced License is available in the same terms, except for 7 and 10 years. All MS130s in an organization must have Enterprise or Advanced licenses - they cannot be mixed.
Model
License
Description
MS130-8
MS130-8P
MS130-8P-I
MS130-8X
MS130-12X
LIC-MS130-CMPT-xY
LIC-MS130-CMPTA-xY
MS130 compact switch (8/12) Enterprise License and support
MS130 compact switch (8/12) Advance License and Support
MS130-24
MS130-24P
MS130-24X
LIC-MS130-24-xY
LIC-MS130-24A-xY
MS130 24 ports Enterprise License and support
MS130 24 ports Advance License and Support
MS130-48
MS130-48P
MS130-48X
LIC-MS130-48-xY
LIC-MS130-48A-xY
MS130 48 ports Enterprise License and support
MS130 48 ports Advance License and Support
In the Co-term licensing model (most existing Organizations), an Organization must either have all MS130 Enterprise or all MS130 Advanced licenses - they cannot be mixed. Additonally, a co-term organization cannot mix enterprise and advanced licenses on any switches that have both enterprise and advanced licenses.
For example, if an organization has existing MS390/C9300/MS150s with enterpise licenses, they cannot add MS130's with advanced licenses in that organization - they must be added with enterprise licenses.
If the organization has existing MS390/C9300/MS150s with advanced licenses, they cannot add MS130's with enterprise licenses in that organization - they must be added with advanced licenses.
 In the Per-device licensing model, a mix of Enterprise and Advanced can be added to a single Organization, but certain features may require all devices in a Organization to have Advanced licenses, e.g. Adaptive Policy.
MS130 Advanced License only provides Adaptive policy as an additional feature.
For more information about the differences between the Advanced and Enterprise licenses see the below links:
The MS130 is also available as Subscription Licensing:
Model
License
MS130-8
MS130-8P
MS130-8P-I
MS130-8X
MS130-12X
MS100 Small
Essentials: LIC-MS-100-S-E
Advantage: LIC-MS-100-S-A
MS130-24
MS130-24P
MS130-24X
MS100 Medium
Essentials: LIC-MS-100-M-E
Advantage: LIC-MS-100-M-A
MS130-48
MS130-48P
MS130-48X
MS100 Large
Essentials: LIC-MS-100-L-E
Advantage: LIC-MS-100-L-A MS120
For more information on licensing, refer to Meraki Licensing Models article.
MTBF Rating
Model
MTBF at 25°C
(in hours)
MS130-8 1,927,507
MS130-8P 563,569
MS130-8P-I 608,122
MS130-8X 1,042,108
MS130-12X 682,400
MS130-24 789,842
MS130-24P 768,152
MS130-24X 677,546
MS130-48 425,296
MS130-48P 309,196
MS130-48X 396,536
  • Was this article helpful?
