Vision Portal: Introduction
Introduction
Meraki Vision is a camera-viewing portal designed for core physical security use cases. It allows you to easily navigate between cameras to view video, conduct motion search, and share footage.
Learn more with these free online training courses on the Meraki Learning Hub:
Navigate to vision.meraki.com and sign in using your Dashboard credentials.
This image illustrates the steps to access the Meraki Vision portal by navigating to vision.meraki.com and signing in with Dashboard credentials.
You can access the portal through links available on the Meraki Dashboard.
Camera settings, configuration, troubleshooting, and analytics will remain on the Meraki Dashboard. Existing features such as the video player, video wall, and exports page will also stay available on the Dashboard for now.
Key Improvements
The following is a list of key improvements on the Vision portal compared to the Meraki dashboard.
  • Everything at your fingertips
    • Powerful search options
    • Collapsible navigation pane
    • Integrated map view for camera navigation
  • Faster, cleaner, and more intuitive viewing experience
    • New time-picker with 24-hour option and time zone view
    • Related tags and video walls list
    • Two motion search experiences: quick and advanced
  • Easier and more powerful export experience
    • Custom export filename
    • Video wall exports (export from multiple cameras simultaneously)
    • Export previews
  • A more complete video wall experience
    • Create MULTI NETWORK VIDEO WALLS (NEW)
    • Video Wall creation flow (NEW)
    • Full bitrate stream
    • No idle timeout in full-screen view
    • Digital zoom and dewarp on an individual camera
  • Event Search (NEW)
    • Search for Motion events (Vehicle or Person)
Tour of the Interface
This image displays interface tour.
How-Tos
Find something across networks
This image is displayed to illustrate the process of finding something across networks.
  • Use the org-wide search to type in any string
  • It will search for matches across your cameras, video walls, and exports across all networks in the organization
    • It uses “fuzzy search,” which might accommodate any misspelling like “entrnce” vs. “entrance”
Find a camera in a network
This image is displayed to demonstrate the process of locating a camera within a network
Cameras page > Navigation pane (map)
You can use the global search to find the right camera, but if you’re already on a single network, you can use the Cameras page → Navigation pane.
  • From here you can use the mini-map to find the right camera based on its location
    • The blue dot refers to the selected camera, and red dots are cameras that are offline
  • Expand this for a larger view, and to switch between floor plans
  • Collapse this if you don’t have any placements or don’t need this; your setting will be remembered on your device
You can configure placement and FoV on the Meraki dashboard. Read more here.
This image displays "Backstage - Meraki vision".
Cameras page > Navigation pane (search and list)
On top of the global search or the mini-map, you can use the search input or the list view below the mini-map.
  • Type in a string that corresponds to a camera name or tag
    • Check which tags are associated with a camera by looking at the tag icon next to the camera name
  • Or, use the thumbnails to select the correct camera
    • Green dots correspond to cameras online, red dots are cameras that are offline
This image is displayed to find the video wall in a network.
Scroll through the list of video walls on the navigation pane.
Video wall order and configuration are still managed through the Meraki dashboard.
You can watch live video through either the cameras or video wall video player page.
  • On each page, click “NOW” on the video timeline to go to live video.
  • On the video wall page, you can also edit and start a video wall rotation to flip through live video on many video walls one after another.
    • You can generate a link that will start a video wall rotation and enter theater mode without user intervention by appending the following at the end of the URL: "?&autostart=true&fullPage=true"
  • Use the audio on/off button on the video timeline to listen to audio (if enabled)
  • Hit "Theater" or “Fullscreen” on the video timeline if needed
    • Org idle timeout is ignored if this is done on the video wall
  • Click and zoom into any of the cameras on the video wall
For best experience with video performance, we suggest using the recommended browsers cited in our Dashboard Browser Compatibility article.
This image displays to "Find and play historical video".
Cameras and video wall page → Video timeline
The video timeline on both the cameras and video wall page can help you navigate to historical video.
  • Use the time-picker to type in a date and time using natural language processing, or click the date and time using the calendar and clock
  • Browse through the timeline by clicking the arrows and changing the zoom level
  • The timeline also provides options to go backwards and forward by one frame or ten seconds
  • The timeline also provides a way to play back by 0.25x, 0.5x, 1x, 2x, and 4x
Cameras and video wall page → Motion search
 This image is displayed to demonstrate how the motion search feature on the video wall page helps locate specific motion events efficiently.
Motion search on the video actions page can help you find historical video.
  • The drawer version by default will search the entire camera’s field of view for a default time period (based on your currently selected time period on the timeline)
    • For live, this is backwards 50% of the timeline zoom until current time
    • For historical, this is backwards and forwards by 50% of the timeline zoom
  • You can narrow down the search criteria by selecting a smaller region on the video player
This image is displayed to illustrate how selecting a smaller region on the video player can refine motion search results and improve search accuracy.
Choose “Advanced Search” for a larger, more focused motion search experience with a larger grid view and more filters.
The motion search results are provided in the form of motion recap images. These represent an entire motion event in a single frame.
  • Once you click on a result you can play it back
  • From here, you can download the motion recap image
  • You can directly export the entire event
This image is displayed to demonstrate how to directly export an entire event from the Meraki Dashboard.
If you have Event Search enabled (via the Meraki Early Access page) you will be directed onto a different tab on the Vision Portal!
There are many options to retrieve footage
  • The screenshot button on the video timeline grabs a single frame from what you’re viewing
  • Export allows you to rename the export, select a duration, and save a video file to share later
    • View and share these exports from that same drawer, or on the network-wide exports page
    • From the network-wide exports page, you can also combine exports into a single file
    • You can also delete exports, or get the checksum to verify integrity
  • Share allows you to share a link to the video you are watching with another Meraki Vision portal user
This image is displayed to illustrate how to share a video link with another Meraki Vision portal user.
You can create video walls for Single and Multi-Network Video Walls
Find more information here
  • Get help (link to documentation) and an FYI on keyboard shortcuts on the top-right
  • Give us feedback on the top-right
  • Log out on the top-right
  • For any other features, use the Meraki dashboard
Permissions are managed on the dashboard like before. All users will be provided access to both the dashboard.meraki.com and the vision.meraki.com experience. There is no way to prevent users from using the dashboard experience and only using Meraki Vision. Read the full article on camera permissions.
SSO login from the IdP provider is possible. Read this article for more info.
You can use the Meraki Vision portal just like any other website, by going to vision.meraki.com and logging in with your Meraki dashboard credentials. There are links to the interface from the dashboard as well. Note: permissions are still managed on the dashboard like before.
There are links to the interface from the dashboard as well, however, as a PWA you can also download the app by clicking on the button to the right of the address bar. From there, you can add the app to your dock or desktop to open for next time.
Screen Shot 2021-11-12 at 12.50.12 PM.png    Screen Shot 2021-11-12 at 12.40.50 PM.png
Use the “Feedback” button on the top-right corner to send Meraki your thoughts on the interface.
Changelog
Refer to full list: Meraki Vision Changelog for more information.
Have questions?
FAQ can be found here.
  • Was this article helpful?
