Cisco Meraki US Government Region
Overview
Cisco Meraki is investing significant resources into launching the Cisco Meraki US Government region to provide Meraki services to US Federal agencies, US government contractors, and critical infrastructure customers. We have obtained our Authorization to Operate (ATO) under the Federal Risk and Authorization Management Program (FedRAMP) at the Moderate impact level. This is a requirement for any cloud service provider to operate a service for the US Federal Government to use.
This document will cover key technical information for customers looking to get started with the Cisco Meraki US Government region or migrate their existing Meraki networks.
Getting Started
New Cisco Meraki users who are looking to migrate to the Cisco Meraki US Government region should get in touch with their Account (Sales) Representative to initiate the onboarding process. The Cisco Meraki US Government region is designed to provide an enhanced and secure experience for government users, tailored to meet the stringent compliance and operational standards required in government environments. As a result, onboarding to this specialized platform involves certain unique procedures that ensure alignment with government regulations and security requirements. Account Representatives are equipped with the necessary expertise and resources to facilitate this transition effectively. They understand the nuances of the Cisco Meraki US Government region and can provide step-by-step assistance tailored to your organization's specific needs.
Account Representatives play a pivotal role in ensuring that all prerequisites for migration are met, such as verifying eligibility, setting up the appropriate licensing, and providing any necessary documentation. Moreover, they act as a liaison between your organization and Cisco Meraki's technical teams, ensuring that the onboarding process is smooth and that all concerns are promptly addressed. Engaging with them early ensures that you are well prepared and helps avoid potential delays or complications in the migration process. We have a specific document on migration that goes over the steps involved.
If you are new to Cisco Meraki and/or are unsure of who your Account Representative is, you can typically find their contact information in your Cisco Meraki dashboard or by Contacting Support.
Creating Organizations in Cisco Meraki US Government Region
Cisco Meraki US Government region dashboard is currently live at dashboard.gov-meraki.com. Users can create an account in the Cisco Meraki US Government region on this page. You can find step by step instruction on Creating a Dashboard Account and Organization in Cisco Meraki for Government.
Supported Devices
The following lists out the hardware devices supported by the Cisco Meraki US Government region
SD-WAN |
Wireless |
Switching |
Cellular |
MX67, MX67W, MX67C-HW-NA** |
MR36, MR36H |
MS120* |
MG21, MG21E |
MX68, MX68W, MX68CW-HW-NA** |
MR44 |
MS125 |
MG41, MG41E |
MX75 |
MR46, MR46E |
MS130 |
MG51, MG51E |
MX85 |
MR56 |
MS355 |
MG52, MG52E |
MX95 |
MR57 |
MS450 |
MX105 |
MR76 |
C9300-24T-M C9300-24P-M C9300-24U-M C9300-48T-M C9300-48P-M C9300-48U-M C9300-24UX-M C9300-48UXM-M C9300-48UN-M C9300-24S-M C9300-48S-M C9300L-24T-4X-M C9300L-24P-4X-M C9300L-48T-4X-M C9300L-48P-4X-M C9300L-48PF-4X-M C9300L-24UXG-4X-M C9300L-48UXG-4X-M C9300X-24HX-M C9300X-48HX-M C9300X-48HXN-M C9300X-48TX-M C9300X-12Y-M C9300X-24Y-M |
MX250 |
MR86 |
MS390 |
MX450 |
CW9166I-MR |
MS150 |
C8455-G2-MX |
CW9164I-MR |
C8111-G2-MX |
CW9162I-MR |
| CW9176i | |||
CW9176D1 |
| CW9178i | |||
| CW9166D1 | |||
| CW9163E | |||
| CW9172I | |||
| CW9179F | |||
| CW9174 | |||
| CW9171 |
* MS120 has limited TAA Compliance
** MX67C-HW-WW & MX68CW-HW-WW devices are not supported at this time
Supported Firmware
In order for certain features to work as expected, the following minimum product firmware versions should be used for nodes hosted in the Cisco Meraki US Government region:
- Supported FIPS Firmware List: FIPS 140 Devices and Firmware for Cisco Meraki - Cisco Meraki Documentation
FIPS Compliance Letters: Meraki Device-to-Cloud Connectivity - FIPS - Cisco Meraki Documentation
When migrating devices below the minimum version you will see a delay in time required for the device to check in. The device will reach out to the Cisco Meraki US Government region, try to connect, and will be redirected to upgrade their firmware to a newer version. During this time, the device will not be providing any data to Dashboard and will appear offline. This can take upwards of 20 minutes. If the device does not connect by then please reach out to Meraki support.
Supported Features
MX, MG, MR, and MS Enterprise Tier features
Select MX Advanced Security features
Geography based firewall rules
Intrusion Detection and Prevention System (IDS/IPS)
Content Filtering powered by Talos Intelligence
Cisco Advanced Malware Protection (AMP)
YouTube Content Restriction
Web Search Filtering
Cisco Secure Malware Analytics Integration (formerly know as Threat Grid)
Adaptive Policy
MS Advanced Licensing tier
Cisco Secure Client using Custom Server certificate
SNMP Device Polling & SNMP Cloud Proxy
Cisco Spaces Federal Integration
Currently only supported via API Key, seamless integration is not supported
Unified Licensing for EA
A-La-Carte will be supported at a future release, currently unsupported.
Unsupported Devices
MV
Z3/Z4 Series
MT
vMX
Campus Gateway
Unsupported Solutions/Features
NOTE The following features are not supported for devices that are configured in the Cisco Meraki US Government region :
SM
SIG-Connect
MI
MR Advanced Licensing
Trusted Traffic Exclusions powered by NBAR
Umbrella DNS Integration
ThousandEyes Agent Integration
MX SD-WAN+
Cisco Catalyst Monitoring
Cloud Management with IOS XE
Meraki Mobile App
SNMP Traps
HTTP proxy for cloud communication
Configuration fetch using HTTP (devices must use HTTPS for configuration fetch)
Email alert notifications via SMS text message
Access Manager
AI Assistant
Cisco Meraki Subscription Licensing
Cloud-Managed Hybrid Operating Mode for Wireless LAN Controllers
Campus Cloud Gateway
SmartPorts
Switch (MS) Device Health
AnyLocate UWB Wayfinding
AP Zero Touch Refresh
Zebra integration with Client Analytics
Workflows
Auto generated: Meraki-managed publicly-trusted certificate with DDNS hostname
Cisco Secure Client using Auto-generated Server certificate
Radsec
Note that these services are subject to change
Firewall Requirements for Cloud Connectivity
Please note that the standard firewall allow list requirements for cloud connectivity are different for the Cisco Meraki US Government region. The requirements for Cisco Meraki US Government region connectivity can be found on the Firewall info page.
For the tests that monitor the connectivity status of MX Appliances in the Cisco Meraki US Government region, you can simply grant ICMP access to the IP addresses of our test servers. You no longer need to use Google’s 8.8.8.8 as a test destination.
Trust and Compliance
For CMMC Audit reference:
- Customer Responsibility Matrix; Trust Portal - Cisco
- FIPS Certifications: Global Government Certifications - FIPS 140
All other audit document requests can be made via emailing Cisco Meraki for Government Compliance.
API Endpoints and Considerations
For the Cisco Meraki US Government region, use api.gov-meraki.com in the endpoint base URI.
Support
Overview:
Cisco Meraki US Government region is supported by a dedicated group of specialist Support engineers
US Person/Soil: All Cisco Meraki US Government region Support engineers meet strict US Person/Soil requirements
Direct Support: Case are addressed by Support engineers with no intermediate/triage tier
Opening a Case:
Online
Cases can be submitted directly within the Dashboard. This option helps Support locate your network and resolve issues more quickly.
To submit a case in Dashboard:
- Log-in to Dashboard.
Navigate to "?" (top-right on green ribbon) > Get help & cases > Pick a Tile to Contact Support > Submit a case.
- Use the provided fields to explain the question or issue. Please include any relevant details.
- Click Submit.
You will receive a confirmation email, and a Support Engineer will get back to you as soon as possible, typically in less then 24 hours. You can update the case if needed by visiting the "?" > Get help > View full case history page in Dashboard.
Phone
Phone support is available for customers experiencing high-impact issues or need an immediate response from support.
Navigate to "?" (top-right on green ribbon) > Get help & cases > Pick a Tile to Contact Support > Call Support team page.
The Cisco Meraki US Government region support number is +1-415-432-1374.
Support Coverage & Hours
Entitlement: Support Coverage is included with all Cisco Meraki licensing
Business Hours Support:
- Hours: Mon-Fri 8:00am to 8:00pm EST
- Scope: Any case severity score
- Access: Phone call or Dashboard case Comments
- Response Time:
- Severity 1 & 2 Cases: 30 Minute SLO
- Severity 3 & 4 Cases: 60 Minute SLO
After Hours Support:
- Hours: (24 / 7 / 365) Including Weekends & Holidays
- Scope: Severity 1 Incidents
- Access: Paging On-Call Network Support Engineer (NSE)
- Open a case via the Dashboard
- Submit a Page request via the Support number +1-415-432-1374
- Response Time:
- Severity 3 & 4 Cases: Next Business Day
Severity Levels
By accurately assessing the severity of your issue, we can prioritize support accordingly.
| Severity Level | Definition | Troubleshooting Guidance |
| Severity 1 | Critical impact on customer's business operations. In production Cisco Meraki hardware, software is down. | Customer and Meraki Support commit to troubleshooting over the phone 24/7 until the issue is resolved or the severity level is appropriately reduced. |
| Severity 2 | Substantial impact on customer's business operations. Cisco Meraki hardware, software, is degraded. | Customer and Meraki Support commit to troubleshooting over the phone during business hours until the case is resolved or severity is appropriately reduced. |
| Severity 3 | Minimal impact on customer's business operations. Cisco hardware, software, or as a service product is partially degraded. | Live troubleshooting is not mandatory but can be accessed by contacting Meraki Support helpline or using Dashboard’s case communications. |
| Severity 4 | No impact on customer's business operations. The customer requests information about features, implementation, or configuration for Cisco’s hardware, software, or as a service product. | Live troubleshooting is not mandatory but can be accessed by contacting Meraki Support helpline or using Dashboard’s case communications. |
Requesting Severity Change (Escalating a Case)
Support treats all Severity 1 cases with at the highest level of escalation by default. If you feel as if your case is not receiving the appropriate response from support please call into the support hotline and request a higher priority level. Duty managers are available ASAP upon request to your network support engineer (NSE).
To escalate case severity, Call the support hotline and simply make the request to your Network Support Engineer (NSE). +1-415-432-1374
FAQ
Are free trials for products available?
Yes, Cisco Meraki free trials of for US Government products are now available. Eligible customers can request a free trial for any dashboard organization set up on the Cisco Meraki US Government region. Please contact a Cisco representative for more details.
Can I migrate my licenses from the Commercial Dashboard to the US Government Dashboard?
1-Way license conversions from Commercial Dashboard to the US Government Dashboard are available with limitations and subject to Terms and Conditions. To inquire about a license migration:
- Please open a case with support to learn more!
Can I see my Meraki for US Government Organizations and Commercial Organizations on the same dashboard/logged into the same account?
No. The accounts created on the Cisco Meraki US Government dashboard are totally separate from commercial accounts and do not cross over or share any information or org membership information.
