Cisco Meraki Local Status Page: Catalyst IOS XE Switches
Click 日本語 for Japanese
By Kamal Haidar
Catalyst IOS XE LSP Overview
This article covers the features, configuration options, and access methods available on the Cisco Meraki Local Status Page (LSP) for Catalyst IOS XE switches. It outlines how to use the LSP for monitoring connectivity, adjusting network settings, troubleshooting, and managing various configuration options. The default username is "admin" and the password is the Serial Number/Cloud ID.
Any changes on the local status page are only intended to be used when necessary to get a switch connected to the dashboard. Before making any changes on the local status page to bring a switch online, ensure the same changes are applied in the dashboard first. Failing to do so will cause the device’s configuration to be overwritten by the dashboard configuration, which may cause the switch to go offline.
Accessing the Catalyst IOS XE Local Status Page
In order to access the local status page DHCP is typically provided by the management port, otherwise, configure a device with the following IP settings, and then browse the address in a web browser or "switch.meraki.com".
IP address: 198.18.0.2
Subnet mask:255.255.255.240
DNS: 198.18.0.1
Note: If the switch has already been configured/connected and has a MGMT IP, you may alternatively browse to that IP if plugged into a front-panel port. This is especially true for C9200CX switches since they do not have a dedicated management port.
To physically access the Local Status Page on catalyst hardware, the management port should be used, NOT the console port. The console port does NOT provide access to the LSP and is only used to get basic progress information during a migration and has no use once a device has moved to the dashboard. Depending on the model of the switch, the management port may be on the right-side or the bottom-side as labeled below:
Furthermore, accessing the Local Status page of IOS XE Catalyst switches (17.5.1+) differs from traditional Meraki devices. Once connected to the local status page, you will be prompted to login to a page that looks different and without any information available prior to authentication:
Catalyst IOS XE Local Status Page Options
Catalyst IOS XE switches offer the following information and configuration options on their local status page:
  • Connection
    Provides information regarding the client's connectivity to the switch, the switch's current network, VLAN information, as well as other cloud connectivity and status information.
  • Administration
    Provides options for setting the IP address of the switch, other addressing settings.
    The Download support data function will allow you to download a special file to submit to Meraki support for additional troubleshooting if you are unable to get the unit online (see more in Support Data Bundle (SDB) article).
  • Switchport
    Provides switchport operational status, bytes in/out, and basic port configuration. Also provides options for limited configuration changes, including enabled/disabled, native VLAN, Allowed VLAN(s), and link negotiation(on the right-hand side not visible below).
Local Status Page for Catalyst showing the Switchport tab.
  • Was this article helpful?
