Systems Manager Agent and MDM Profile Enrollment
Because Systems Manager supports so many different operating systems, there are a few primary enrollment methods to add management capability to your devices. This guide will cover the two primary aspects of management, agent installs, and enrollment profiles, and the features associated with each of them.
For detailed instructions on how to enroll a particular device type, see this article.
What are the Meraki Agent and MDM Profiles?
The MDM enrollment profile provides most of the management functionality on devices, such as restrictions or live tools like sending notifications and remote reboot commands. These profiles exist as configurations on the device's operating system, using the vendor's native APIs, and are provisioned during the enrollment process. You can see examples of where the profile can be found on each device type in this article.
Although MDM profiles are used for most platforms, desktop versions of Windows and macOS support installing an agent as well. The Meraki agent installs like an application and runs as a service in the background of your enrolled Windows/Mac machine. The agent provides additional functionality, such as custom software deployment and remote desktop. The agent and profile are not mutually exclusive, you can enroll a device using either method or with both.
We typically recommend enrolling with both methods for full Systems Manager functionality.
Operating System Compatibility
Agent
MDM Profile
macOS
iOS/iPadOS/tvOS
Android
Windows 10
Windows 11
Chrome OS*
* Chrome OS technically does not run an agent or install a profile and connects via Google's APIs for management. See here.
For a list of supported operating systems and versions see the Supported Operating Systems KB article.
How to Enroll
Enrollment instructions can be found in the Meraki Dashboard under Systems Manager > Manage > Add Devices. You can also find guides on how to enroll every operating system for a detailed breakdown.
Agent Version Control
Systems Manager admins have the ability to manage the preferred version of the agent used for all devices in their networks, or upgrade or downgrade the agent on specific devices.
To manage the preferred version in a network, navigate to Systems Manager > Configure > General and select the preferred agent version under Agent Version.  The Agent version can be set to a specific version number or "Latest" which will automatically update the agent on currently managed and newly enrolled devices with each new Agent release.
To manage the preferred version for a specific device, navigate to the "Device Details" page for a target device and select the expected version under Agent Version. Click on "Set" to automatically upgrade or downgrade the agent on the next device check-in.
Use agent versions greater than 3.7.2.
For a list of feature updates and bug fixes across all agent versions, see the Systems Manager Agent Release Notes.
Auto-installing the macOS Agent
Please note, the agent will require making PPPC adjustments on macOS 10.14+
Privacy Preferences Policy Control (PPPC) on macOS with Systems Manager
The macOS agent can be pushed down as an application to Mac devices that have gone through profile enrollment. This can help streamline the enrollment process of macOS devices, ensuring that both profile and agent are installed without needing to manually run the .pkg on devices. The agent can be added Systems Manager > Manage > Apps > + Add new and scoped to all devices, or via tags. Once configured, enrolled devices can automatically install the agent if within the specified scope.
Auto-installing the Windows Agent
The Windows agent can be pushed down as an application to Windows devices that have gone through profile enrollment. This can help streamline the enrollment process of Windows devices, ensuring that both profile and agent are installed without needing to manually run the .msi on devices. The agent can be added Systems Manager > Manage > Apps > + Add app > Windows > Custom app via MDM and scoped to all devices, or via tags. Please note that the MSI will need to manually be uploaded, with installation arguments following the logic outlined in our Windows Enrollment  article (see example below for 4.2.2.) Once configured, enrolled devices can automatically install the agent if within the specified scope.
Agent vs Profile Features
Meraki Systems Manager enables device management through two primary components: the agent and the management profile. Each provides access to different sets of features on your devices. For comprehensive functionality on Windows 10/11 desktops and macOS devices, we recommend enrolling devices using both the agent and the management profile whenever possible.
For a detailed comparison of supported features, please refer to the feature comparison section below.
  Windows Profile Windows Agent
Apple
Unsupervised  Profile
Apple
Supervised Profile
macOS Agent
Push MDM profiles
Lock Device
Selective Wipe
Erase Device
Fetch process list
Command line
Network stats
Screenshot
Remote Desktop
Power Control
Install Software Binaries               Checkbox.png**   Checkbox.png**       Checkbox.png**
Send Notification
Install OS updates
 Checkbox.png*
Activation Lock/Bypass
* Installing OS updates on iOS requires ADE supervision specifically, and will not work with Apple Configurator supervision.
** On Windows, you can install .exe and .msi files using the Meraki Agent, while .msi files can also be installed via the Windows management profile (MDM). On macOS, installation is supported for .pkg files or .app files that are packaged inside a .dmg disk image. It is important to use the appropriate file type and installation method based on the operating system of the device.
Checking Enrollment Status on Dashboard
For Windows desktop and macOS devices, there are a few ways to check whether a device has the management profile installed, agent installed, or both.
Client Details
After selecting a client, scroll down to the 'Online status' section. A device with the agent installed with show 'Last online' here. A device with the management profile installed will show "Last check-in'. Devices enrolled through both methods will show both lines, as in the below image.
You can also tell how a device was enrolled based on the MDM commands available. With just the management profile installed, you'll see:
With both the profile and agent installed, you'll see:
Clients List
On the Systems manager > Clients page, click the '+' sign at the top right, and add the 'Managed?' column to the table. Devices that are enrolled with 'Managed? No' are enrolled through the agent, and do not have a management profile installed.
Checking for Management Profile on Devices
iOS/iPadOS
For iOS/iPadOS, the enrollment profile is stored in Settings > General > Profiles & Device Management > Meraki Management/Meraki Systems Manager.
In addition to the Meraki Management enrollment profile, you can also add the Meraki Systems Manager app to iOS, which allows some additional features to be enabled, including Backpack, GPS tracking, Push Notifications, and much more.
macOS
For macOS, the enrollment profile is stored in System Preferences > Profiles > Meraki Management/Meraki Systems Manager.
Android
For Android, the enrollment profile can be viewed in the Meraki Systems Manager app on the Configuration page.
Windows 10/11
For Windows 10/11, the enrollment profile is stored in Settings > Accounts > Work Access.
Checking for the Agent on Devices
The agent is a process that will be running in the background on macOS and Windows 7, Windows 8, and Windows 10/11.
To confirm that the agent is running on macOS and view the Meraki agent's log file, run the following command in Terminal:
tail -f /var/log/m_agent.log
If you see logging information being generated for today's date, your Meraki agent is currently running!
To confirm that the agent is running on Windows 10, or Windows 11, view the Meraki agent's log file by opening m_agent_service.log located in one of the directories below (depending on what agent version is installed).
Agents ≤ 3.6.0: C:\Windows\temp\m_agent_service.log
Agents ≥ 3.7.0: C:\ProgramData\Meraki\Systems Manager Agent\Logs\m_agent_service.log
If you see logging information generated for today's date, your Meraki agent is currently running!
For extra Windows agent running confirmation, you can also find the m_agent_service running with the Task Manager:
What about Chrome OS?
Chromebooks are enrolled through the Google Admin Console with API access enabled. If you are interested in managing your Chrome OS devices, please view our documentation on enrolling Chrome OS into Meraki Systems Manager.
