Systems Manager Passcode Payload
The passcode policy payload allows the MDM administrator to specify various requirements for passcodes or passwords on enrolled devices. The majority of settings on this payload do what you would expect, but due to the differences between various operating systems, these values may be interpreted differently on client devices. This article describes the differences between OSs for each available setting on the passcode payload, where applicable.
Passcode Payload General Settings
Passcode Strength
Allow Simple Values
Apple devices: This prevents setting the passcode to sequences of repeating or sequential characters (i.e. 1111, 1234, abcd, etc.). Setting this value to "False" has the same behavior as setting minimum complex characters to "1."
Android devices: Same as Apple devices.
Require Alphanumeric Values
Apple devices: Forces at least one alpha character to be included in the passcode (abcd) instead of allowing only numeric characters (1234).
Minimum Length
Apple devices: Defines the minimum length of the passcode. Values may range from 0 to 14.
Minimum Number of Complex Characters
Apple devices: Defines the minimum number of non-alphanumeric characters (!@#$). Values may range from 0 to 4.
Maximum Passcode Age
Apple devices: The number of days which a passcode may remain unchanged. Allowed values range from 1 to 730. Setting this value to 0 will trigger an immediate passcode change on iOS devices.
Auto-Lock
Apple devices: Sets the maximum duration a device may remain idle before locking the screen or enabling the screen saver. Allowed values 0-15.
NOTE: on iOS/iPadOS this value may be adjusted down by end users, but cannot exceed the value specified, and will round down to the nearest allowed value by the UI.
iPhone: 1,2,3,4,5
iPad: 1,2,5,10,15
Android devices: Sets the maximum duration a device may remain idle before locking the screen. Allowed values 0-15.
Maximum Number of Failed Attempts
Apple devices: Sets the maximum number of failed log-in attempts. Allowed values 4-10. Default (when unset): 11. On macOS, this will lock the device when exceeded; on iOS/iPadOS, this will erase the device.
Android devices: Sets the maximum number of failed log-in attempts. Allowed values 4-10. Erases the device when exceeded. Default: unlimited.
Exceptions
iOS Manual Enrollment
Devices which are enrolled via Manual enrollment on iOS can be scoped with a passcode payload, but all values on it are ignored by the device in favor of the following settings:
Allow simple values: False
Require PIN: True
Minimum passcode length: six characters
