SoluM Electronic Shelf Labels (ESL) Integration with MRs
Overview
Electronic shelf labels (ESL) are digital displays of various sizes and shapes that retailers use to show product pricing, promotions, inventory level, etc for goods at the store. Unlike traditional paper price tags, the product pricing on electronic shelf labels can be automatically and remotely updated whenever a price is changed from a central control server.
Cisco Meraki access points with USB ports boost the value of your investment by adding an ability to leverage extra capabilities, for example, IoT applications, by using the USB port. One such application is an Electronic Shelf Label (ESL) integration with our partner SoluM - https://solumesl.com/
Meraki/SoluM ESL Architecture
Network Diagram
SoluM ESL gateways communicate with ESL tags via a proprietary 2.4GHz wireless protocol using its external antennas. SoluM USB gateways build a TCP connection to SoluM Cloud for management purposes. Please refer to a simplified network diagram below.
Note: SoluM USB gateways communicate with the SoluM cloud directly. No data or management ESL traffic is sent through the Meraki cloud.
Requirements and Supported Models
Supported Access Points
Model |
Minimum Firmware |
PoE Requirements for USB ** |
Notes |
MR57 |
MR 29.1+ * |
802.3bt (POE ++ / 40W) |
802.3bt or 802.3at + 802.3at powersharing is required for the USB port to be enabled Please refer to Power Source Options. |
Note: * MR 28.X firmware (including MR 28.6.1 which is the initial firmware for MR57) does not support this integration.
Note: ** Please ensure that your AP has enough power to support the USB gateway.
Supported USB ESL Gateways
Newton USB gateway - https://solumesl.com/en/solution/usb-gateway
Please refer to the SoluM website for specifications and technical details of the USB gateway.
Configuration and Monitoring
SoluM USB gateways are treated like wired clients connected to 2 or 4 port APs using Port Profiles. Meraki access points provide USB to Ethernet bridging to SoluM USB gateways.
First, you need to configure an SSID that can later be assigned to a USB port via port profiles.
Note: We recommend using a separate SSID that is not used to serve wireless clients to configure your USB port via port profiles.
Navigate to Wireless > Configure > Access control
Select an SSID from the dropdown on the top of the page.
Scroll down to Client IP and VLAN
Select Meraki AP assigned (NAT mode) if you want the gateway to get an IP address directly from AP.
5. Otherwise, select the External DHCP server assigned (Bridged) option and configure VLAN tagging, if needed.
6. Save changes
Note: If you choose the NAT mode, the USB gateway will receive an IP address from an AP in the 10.0.0.0/8 network. In this case, it wouldn’t be possible to connect to the USB gateway from a wireless client connected to the same SSID or a wired client located on a LAN.
If you would like to manage your USB gateway via a web UI or Gateway Launcher SoluM tool, please use Bridge mode instead. Please refer to the SoluM documentation.
Configuring a USB port via Port Profiles
Note: The configuration UI is not yet available. Please contact Meraki Support if you want to become an Early Adopter of this feature.
Navigate to Wireless > Configure > Port profiles
Click Create profile
Enable the USB port and assign the previously created SSID
Save changes
Assign the profile to your AP(s),
Connecting a SoluM Gateway to an AP
Note: SoluM USB gateways are hot-pluggable and can be connected to an AP at any point.
Ensure your AP is getting enough power to support a USB port. Please refer to the Supported Meraki Access Points for more information on PoE requirements.
Connect your SoluM gateway to the AP’s USB port
Ensure that the USB gateway receives an IP address via DHCP from the AP if the USB SSID is configured for Meraki AP assigned (NAT mode) or from your upstream network if the USB SSID is configured for the External DHCP server assigned (Bridged).
Note: If the DHCP server is unavailable when the External DHCP server assigned (Bridged) mode is used, please use Meraki AP assigned (NAT mode) or connect to the USB dongle directly via its default IP address. Please consult with SoluM documentation for details.
Once the USB gateway has successfully connected to the SoluM cloud ESL server, the LED on the gateway will turn green and slowly blink. Please consult with SoluM documentation for other LED statuses.
Monitoring SoluM USB Gateways in Meraki Dashboard
Because USB ports are configured via Port Profiles and inert their settings from an SSID, SoluM USB gateways will appear on the Network-wide> Monitor > Clients page as wireless clients. This behavior is the same as for wired clients connected to 2 and 4-port APs using port profiles.
You can search the USB dongle by its MAC address on the Network-wide> Monitor > Clients page.
Template Support
Port profiles are supported in configuration templates. Please refer to Managing Multiple Networks with Configuration Templates for more information.
Common Troubleshooting Scenarios
USB Gateway Does Not Power On When Connected to an AP
Troubleshooting Steps:
Ensure that the AP receives enough power from its power source (PoE switch / PoE injector / AC adapter) to supply power to the USB gateway.
The easiest way to check the PoE mode is by looking at the Power source column on the Wireless > Monitor > Access points page.
Please refer to the Supported Access Points for more information on PoE requirements.
USB Gateway Does Not Have an IP Address
If the External DHCP server assigned (Bridged) option is configured on the SSID assigned to the USB in port profiles, make sure that there is a DHCP server upstream of AP. Also, check VLAN tagging configured on your AP.
Take a packet capture on the uplink port of your AP where the USB gateway is connected and check for DHCP traffic from/to the gateway IP.
If you still have issues, please contact Meraki support
USB Gateway Does Not Come Online in the SoluM Cloud
Check the Wireless > Configure > Firewall & traffic shaping page for the SSID assigned to the USB port in port profiles for any firewall rules preventing communication between the USB gateway and SoluM Cloud.
The following ports should permit communication between the SoluM USB gateway and SoluM Cloud.
Protocol/Port |
Purpose |
TCP 80 (HTTP), TCP 443 (HTTPS) |
GW launcher communication to the USB gateway |
TCP 22 (SSH) |
SSH management |
UDP 67/68 |
DHCP address assignment |
UDP/TCP 53 |
DNS name resolution of ESL server URL |
UDP 123 |
NTP |
TCP 55755 |
Web UI |
RabbitMQ (Default port 5671) |
RabbitMQ |
Additionally, devices/firewall located upstream of your AP(s) need to allow the same ports/protocols.
Take a packet capture on the uplink port of your AP where the USB gateway is connected and check for traffic from/to the gateway IP. Make sure that the traffic to/from SoluM cloud is not blocked somewhere upstream.
Getting More Help
If you have any issues related to the ESL functionality (for example, price update does not come through) please contact SoluM support - https://solumesl.com/en/contacts
