Organization-wide Group Policy Overview
Overview
Network and Security policies in any organization today are becoming very complex, repetitive, and enforced across several independent devices in the network. Although intent may be common, such as blocking network access or malicious, objectionable, and intrusive content, administrators may find themselves adding the same policy many times to different enforcement points across their organization.
Organization-wide Group Policy is a framework in the Meraki Dashboard created to unify and simplify the configuration and management of network and security policies across the platform. Rulesets can be used to define firewall rules and then reuse those across many Policies in an organization.
Policies are defined once, at the organization level and can be enforced across any number of MX devices at the same time. Any changes to the policy will automatically be propagated to relevant MX devices. By centralizing policy management, organizations can maintain a more organized and scalable network and security posture, ultimately improving their overall compliance.
Benefits
- Object-Based Configuration: Decouples policy definitions from specific devices, simplifying management and improving configuration visibility.
- Scalable Enforcement: Applies policies across the entire organization simultaneously, ensuring consistency.
- Reusable Rulesets: Allows administrators to define rule logic once and apply it broadly, reducing redundancy and potential for human error.
Prerequisites, Requirements and Limitations
In order for an MX to use this feature, it must satisfy the following requirements:
- Firmware Version: MX appliances must be running firmware version 26.1.2 or newer.
- Note: You can upgrade your appliance via Organization > Configure > Firmware Upgrades. Please review this document to confirm hardware compatibility.
- Please see the table in the next section for supported enforcement target and rule criteria support
- Enforcement Targets: Networks running unsupported firmware versions cannot be selected as Enforcement Targets.
- Scale Limits for the UI:
- Maximum Policies: 300
- Maximum Networks: 5,000
- Policy Enforcement & Device Scale: Dashboard configuration limits (e.g., 5,000 rules) represent the maximum supported scale for the organization. Individual device enforcement is subject to the available resources of the specific appliance model. If a policy exceeds the processing capacity of a target device (e.g., a teleworker gateway vs. a campus concentrator), the device may not apply the full ruleset. We recommend grouping devices of similar classes when applying large-scale policies.
Enforcement Target Firmware Requirements
| Type | 26.1.2 | 26.2 | 27.1 |
| VLAN | X | X | X |
| SGT | X | X | X |
| Uplink (inbound) | X | ||
| IPsec (inbound) | X |
Source Rule Criteria Firmware Requirements
IPv4 CIDR |
X |
X |
X |
IPv6 CIDR |
X |
X |
X |
Ports |
X |
X |
X |
Policy/Group Objects |
X |
X |
X |
| SGT | X | ||
| Geolocations | X |
Destination Rule Criteria Firmware Requirements
Type |
26.1.2 |
26.2 |
27.1 |
IPv4 CIDR |
X |
X |
X |
IPv6 CIDR |
X |
X |
X |
Multi Protocol & Ports |
X |
X |
X |
X |
X |
X |
L7 Applications |
X |
X |
X |
Site-specific VLANs + Offset |
X |
X |
Geolocations |
X |
X |
FQDN |
X |
X |
| SGT | 26.1.2 | X | |
| IPv4 Range | X |
Definition of Components
Understanding the core components of Organization-wide Group Policy:
- Enforcement Target: Defines the "who" or "what" the policy applies to (acting as the "source" in a typical firewall rule). This can be a specific VLAN(s) or an SGT from which traffic originates.
- Rulesets: A collection of firewall rules that can include both Layer 3 (IPv4) and Layer 7 (Application) criteria.
- Firewall Rule: Specifies the criteria (source, destination, port, protocol) and the action (allow or deny) to be taken on traffic.
By defining the Enforcement Target(s) and associating specific Rulesets, administrators can ensure that only authorized traffic is permitted while blocking potentially harmful traffic, significantly enhancing security posture. To get started with this feature, please see these relevant articles for details:
- Firmware Version Requirement: A network will only be displayed within the Network-wide enforcement targets list if the network is currently running firmware version 26.2.2 or greater.
- Verification: Before attempting to configure enforcement targets, please verify that your devices are updated to the required firmware version to ensure the network appears as a valid selection in the dashboard.
| Article name | Description |
| User Guide | Refer to the article to learn more about the following:
| Troubleshooting | Refer to the article to learn more about the following troubleshooting this feature |
| FAQ | Frequently Asked Questions |
