Unified Branch CVD Medium Design
For detailed comprehensive guide on the Cisco Validated Design (CVD), refer to the Cisco Unified Branch Design Guide.
Design Components
Prerequisites
Component
Model Family
Software Minimum
Co-term License*
Subscription License**
 Secure Router
MX67/MX68/MX85/MX95/MX105
MX 19.2
Secure SD-WAN Plus
Advantage
Access Switch
C9300/X/L (-M versions)
CS 17/IOS XE 17.15 or 17.18 depending on the model
Advanced
Advantage
Access Switch
C9200/L (-M versions)
IOS XE 17.15 or 17.18, depending on the model
Advanced
Advantage
Access Switch
 MS150/MS130
MS 17.1.4
Advanced
Advantage
Wireless LAN Access Points
AP CW9172
AP CW9176
MR 31
Advanced
Advantage
*For more information on subscription licensing, refer to Co-term – Licensing Overview.
**For more information on co-term licensing, refer to Subscription – Licensing Overview.
Before attempting to onboard a device to the dashboard, ensure all the dashboard pre-requisites are met. This includes creating an organization and adding licenses. Refer to the Getting Started Checklist for additional information.
Automation and Deployment
You can deploy a full-stack Unified Branch within couple minutes through two methods: using the Meraki dashboard interface or leveraging the AI Assistant.
Meraki dashboard-driven execution process:
  1. Go to Automation in the main menu and select Exchange.
  2. Find Unified Branch CVD in the list and click Install.
  3. Next, return to Automation and choose Workspace.
  4. In the Workspace, select Unified Branch and click View workflow.
  5. Locate the Run button at the top right corner and click it.
  6. Enter all required variables as prompted.
  7. Double-check your entered variables, then click Run to proceed.
  8. Once complete, your full-stack branch site will be deployed according to Cisco's validated design.
For more details on Cisco Workflows, refer to Workflow Overview.
AI Assistance-driven execution process:
  1. Request the AI Assistant to deploy a unified branch - ex. "Can you help me automate the deployment of a Unified Branch based on Cisco validated design?" Keywords must include "automate" and "unified branch".
  2. Input your variables
  3. Review your inputs and confirm—deployment begins instantly!
  4. After execution, your full-stack branch site will be provisioned in line with the Cisco-approved design.
You can view a complete demo here, showcasing a sub‑two‑minute branch deployment.
You can view a complete demo here, showcasing a sub‑two‑minute full-stack CVD branch deployment.
What's being provisioned?
Base template includes 2 Secure Routers, 2 Smart Switches, and 2 Access Points:
Network-wide Settings
Under Network-wide>Configure on the Dashboard
Main Menu
Section
Subsection
Values
Network name
<User Input>
Traffic Analysis
Detailed: collect destination hostnames
Reporting
Syslog Servers
<User Input Syslog Server IPv4 Address>, port 514, Appliance Event log, Appliance Security events, Switch Event log, Wireless Air Marshal events, Wireless Event log
Reporting
Network traffic reporting
NetFlow collector IP
NetFlow collector port
Enabled: send netflow traffic statistics
<User Input Netflow Server IPv4 Address>
2055
Alerts
Alerts Settings
Network-wide
WAN appliance
A rogue access point is detected
Malware is downloaded
Organization-wide Settings
Under Organization-wide>Configure on the Dashboard
Main Menu
Section
Subsection
Values
Settings
SNMP
Version 2C
Version 3
Authentication mode
Authentication password
Privacy mode
Privacy password
IP restrictions
SNMP V2C disabled
SNMP V3 enabled
SHA
<passphrase>
AES128
<passphrase>
<IP address>
Policy Objects
All objects
3 objects
<User Input>
3 IPv4 Addresses
<User Input>
Policy Objects
All objects
3 subnets
<User Input>
3 IPv4 Subnets
<User Input>
MX Secure Router Settings
Under Security & SD-WAN>Configure on the Dashboard
Main Menu
Section
Subsection
Values
Appliance Status
Summary
Appliance name
<User Input>
Site-to-site VPN
Site-to-site VPN
Type
Spoke
Site-to-site VPN
Site-to-site VPN
Hubs
<User Input>, IPv4 default route enabled
Addressing & VLANs
Deployment Settings
Mode
Routed
Addressing & VLANs
Routing
LAN Setting
VLANs
Addressing & VLANs
Routing
Subnets
●  511, INFRA, 10.250.1.1/24, VPN mode = Disabled
●  50, GUEST, 172.16.99.1/24, VPN mode = Disabled
●  40, PCI, 10.40.1.1/24, VPN mode = Enabled
●  30, IOT, 10.30.1.1/24, VPN mode = Enabled
●  20, VOICE, 10.20.1.1/24, VPN mode = Enabled
●  10, DATA, 10.10.1.1/24, VPN mode = Enabled
●  1, Default, 192.168.128.1/24, VPN mode = Disabled
Addressing & VLANs
Routing
Per-port VLAN Settings
  • Port 5 Enabled, Type Trunk, Native VLAN 1, Allowed VLANs = 1,10,20,30,40,50,511
Addressing & VLANs
Routing
  • Port 6 Enabled, Type Trunk, Native VLAN 1, Allowed VLANs = 1,10,20,30,40,50,511
DHCP
VLAN 1 (Default)
Client addressing
Run a DHCP server
DHCP
VLAN 1 (Default)
Mandatory DHCP
Enabled
DHCP
VLAN 1 (Default)
DNS nameservers
Use OpenDNS
DHCP
VLAN 10 (DATA/CORP)
Client addressing
Relay DHCP to another server
DHCP
VLAN 10 (DATA/CORP)
DHCP server IPs
10.102.1.160
DHCP
VLAN 10 (DATA/CORP)
Mandatory DHCP
Disabled
DHCP
VLAN 20 (VOICE)
Client addressing
DHCP
VLAN 20 (VOICE)
DHCP server IPs
10.102.1.160
DHCP
VLAN 20 (VOICE)
Mandatory DHCP
Disabled
DHCP
VLAN 30 (IOT)
Client addressing
DHCP
VLAN 30 (IOT)
DHCP server IPs
10.102.1.160
DHCP
VLAN 30 (IOT)
Mandatory DHCP
Disabled
DHCP
VLAN 40 (PCI)
Client addressing
DHCP
VLAN 40 (PCI)
DHCP server IPs
10.102.1.160
DHCP
VLAN 40 (PCI)
Mandatory DHCP
Disabled
DHCP
VLAN 50 (GUEST)
Client addressing
Run a DHCP server
DHCP
VLAN 50 (GUEST)
Mandatory DHCP
Enabled
DHCP
VLAN 50 (GUEST)
DNS nameservers
Use OpenDNS
DHCP
VLAN 511 (INFRA)
Client addressing
Run a DHCP server
DHCP
VLAN 511 (INFRA)
Mandatory DHCP
Enabled
DHCP
VLAN 511 (INFRA)
DNS nameservers
Use OpenDNS
Firewall
Layer 3
Outbound rules
Top-down Prioritiy
  1. Deny Rule: Source = Guest (VLAN 50), Any Source Protocol, Destination =  Default (VLAN 1) and Data (VLAN 10) and Voice (VLAN 20) and IOT (VLAN 30) and PCI (VLAN 40) and INFRA (VLAN 511) and Guest (VLAN 50), Any Destination Protocol
  2. Deny Rule: Source = Default (VLAN 1) and Data (VLAN 10) and Voice (VLAN 20) and IOT (VLAN 30) and PCI (VLAN 40) and INFRA (VLAN 511) and Guest (VLAN 50), Any Source Protocol, Destination = Guest (VLAN 50), Any Destination Protocol
  3. Allow Rule: Source = Default (VLAN 1) and Data (VLAN 10) and Voice (VLAN 20) and IOT (VLAN 30) and PCI (VLAN 40) and INFRA (VLAN 511) and Guest (VLAN 50), Any Source Protocol, Destination = Any, Any Destination Protocol
  4. Deny All Rule: Source = Any, Any Source Protocol, Destination = Any, Any Destination Protocol
  5. Default Allow All Rule: Any, Any Source Protocol, Destination = Any, Any Destination Protocol
Firewall
Layer 3
WAN appliance services
ICMP Any, Web None
Firewall
IP Source Address Spoofing Protection
Mode
Block
SD-WAN & traffic shaping
 Uplink configuration
Uplink Statistics
Test connectivity to:
  • Cloudflare DNS = 1.1.1.1
  •  Google DNS = 8.8.8.8
  • OpenDNS = 208.67.222.222
 Uplink selection
Load balancing
Disabled
Uplink selection
Multi-Uplink AutoVPN
Enabled
SD-WAN policies
Internet traffic
INFRA Traffic
  • Prefer WAN 2. Fail over if uplink down
  • Protocol: Any
  • Source: INFRA VLAN
  • Destination: Custom - Any
SD-WAN policies
Internet traffic
SaaS Traffic
  • Prefer WAN 2. Fail over if "SaaS_Traffic" custom performance class is met
  • Protocol: Any
  • Source: VOICE VLAN
  • Destination: Application Categories -> Productivity -> Office 365 or Webex Video or WebEx Meeting or WebEx Control or Webex Audio or Webex Application Sharing or Sharepoint or Microsoft Office Web Applications
SD-WAN policies
Internet traffic
SaaS Traffic
  • Protocol: Any
  • Source: IOT VLAN
SD-WAN policies
Internet traffic
SaaS Traffic
  • Protocol: Any
  • Source: DATA VLAN
SD-WAN policies
VPN traffic
VoIP and Video Conferencing Traffic
  • Prefer WAN 2. Fail over if "VoIP" custom performance class is met
  • Protocol: Any
  • Source: Any
  • Destination: Application Categories -> VoIP & Video Conferencing -> Select All
SD-WAN policies
VPN traffic
Critical Apps
  • Prefer WAN 2. Fail over if "Critical Apps" custom performance class is met
  • Protocol: TCP
  • Source: 10.102.1.160 (DHCP/DNS Server IP)
  • Destination: Any
SD-WAN policies
VPN traffic
Default SLA
  • Prefer WAN 1. Fail over if "Default SLA" custom performance class is met
  • Protocol: Any
  • Source: Any
  • Destination: Any
SD-WAN policies
Custom performance classes
  • "SaaS_Traffic" = Maximum latency (150), Maximum Jitter (50), Maximum Loss (5)
SD-WAN policies
  • "Critical_Apps" = Maximum latency (150), Maximum Jitter (20), Maximum Loss (2)
SD-WAN policies
  • "Default_SLA" = Maximum latency (none), Maximum Jitter (100), Maximum Loss (5)
Global bandwidth limits
Per-client limit
unlimited
 Traffic shaping rules
Default Rules
Enable default traffic shaping rules
Rule #1
●  Definition: localnet 172.16.99.0/24 (Guest VLAN)
●  Bandwidth limit: Ignore network per-client limit (unlimited)
●  Priority: Low
●  DSCP tagging: 0 (CS0/DF – Best Effort/Default Forwarding)
Rule #2
●  Definition: net/port 10.102.1.160/32 (Server IP)
●  Priority: High
●  DSCP tagging: 18 (AF21 – Low Latency Data, Low Drop)
Threat Protection
Advanced Malware Protection (AMP)
Mode
Enabled
Threat Protection
Intrusion detection and prevention
Mode
Ruleset
Prevention
Balanced
Content Filtering
Category blocking
Content categories
Adult, Hate Speech, Illegal Activities, Illegal Drugs, Pornography, Child Abuse Content, Illegal Downloads, Terrorism and Violent Extremism
Content Filtering
Category blocking
Threat categories
Malware Sites, Spyware and Adware, Phishing, Botnets, Spam, Exploits, High Risk Sites and Locations, Bogon, Ebanking Fraud, Indicators of Compromise (IOC), Malicious Sites, Cryptojacking, Newly Seen Domains, Domain Generated Algorithm, Open HTTP Proxy, Open Mail Relay, TOR exit Nodes, Linkshare
Switch Settings
Under Switching>Configure> on the Dashboard
Main Menu
Section
Subsection
Values
Switches
Summary
Switch name
<User Input>
Switch Settings
 Switch settings
VLAN configuration
511
Switch Settings
Switch settings
STP configuration
Enable Rapid Spanning Tree (RSTP): Enabled
Switch Settings
Switch settings
Quality of service
VLAN: 50, Protocol: Any, Trust: Disabled, Set DSCP: 0
VLAN 10, Protocol: Any, Trust: Enabled
VLAN 20, Protocol: Any, Trust: Enabled
VLAN 30, Protocol: Any, Trust: Enabled
VLAN 40, Protocol: Any, Trust: Enabled
Switch Settings
Switch settings
Storm control
●  Broadcast, 20%
●  Multicast 30%
●  Unknown Unicast 10%
Switch Stacks (select stack)
Stack name (top left, edit)
Unified Branch Medium Design Switch Stack
Access Policies
 Access Policies
 Name
Authentication method
RADIUS servers
RADIUS servers
RADIUS servers
RADIUS server
Connection
Options
Radius-MAB
Radius server
RADIUS Server testing
RADIUS CoA support enabled
Enable RADIUS accounting servers
Host 10.102.1.160 (Server IP), secret <secret>, Auth enabled, Port 1812, Accounting enabled, Port 1813
Hybrid authentication, Multi-Auth, Both
Voice auth enabled
Under Switching>Monitor> on the Dashboard
Main Menu
Section
Subsection
Values
Switch Ports
Switch Ports
Switch 1, Port 1 <--> Appliance 1, Port 5
Switch 1, Port 2 <--> Appliance 2, Port 5
Switch 2, Port 1 <--> Appliance 1, Port 6
Switch 2, Port 2 <--> Appliance 2, Port 6
  • Name: Uplink Trunk Port - Connection to Appliance
  • Port status: Enabled
  • Type: Trunk
  • Native VLAN: 1
  • Allowed VLANs: 1,10,20,30,40,50,999
  • Access policy: Open
  • RSTP: Enabled
  • STP guard: Disabled
  • UDLD: Alert only
  • PoE: Enabled
  • Storm control: Enabled
Switch Settings
Switch Ports
Switch 1, Ports 13-24
Switch 2, Ports 13-24
  • Name: Connection to Wired Client
  • Type: Access
  • Access Policy: RADIUS-MAB
  • VLAN: 10
  • Voice VLAN: 20
  • RSTP: Enabled
  • STP guard: BPDU guard
  • UDLD: Alert only
  • PoE: Enabled
Switch Settings
Switch Ports
Switch 1, Ports 5-12
Switch 2, Ports 5-12
  • Name: Connection to Access Point
  • Type: Trunk
  • Native VLAN: 511
  • RSTP: Enabled
  • UDLD: Alert only
  • PoE: Enabled
Access Point Settings
Under Wireless>Configure> on the Dashboard.
Main Menu
Section
Subsection
Values
Access Points
Summary
Access Point name
<User Input>
Access Control
 Basic info
SSID (name)
Guest-WiFi
Access Control
Security (Guest SSID)
Open (no encryption)
Access Control
Mandatory DHCP
Enabled
Access Control
Splash page (Guest SSID)
Click-through
Splash page
Official themes
Modern
Splash page
Splash behavior (Guest SSID)
Splash frequency
Where should users go after the splash page?
Every day
The URL they were trying to fetch
Access Control
Client IP and VLAN (Guest SSID)
External DHCP server assigned
Enabled/Bridged
Access Control
VLAN tagging
VLAN ID: Default AP tag, VLAN ID 50
Access Control
Basic info
SSID (name)
Data/CORP-WiFi
Access Control
Security (Data/CORP SSID)
Enterprise with my RADIUS server
Access Control
WPA encryption
WPA3 Transition Mode
Access Control
802.11w
Enabled (allow unsupported clients)
Access Control
802.11r
Enabled
Access Control
Mandatory DHCP
Enabled
Access Control
Splash Page (Data/CORP SSID)
None (direct access)
Access Control
RADIUS (Data/CORP SSID)
RADIUS servers
10.102.1.160 (Server IP), 1812, <secret>
Access Control
10.102.1.160 (Server IP), 1813, <secret>
Access Control
RADIUS CoA support
Disabled
Access Control
RADIUS attribute specifying group policy name
Filter-Id
Access Control
Client IP and VLAN (Data/CORP SSID)
RADIUS override
Selected/Bridged
Override VLAN tag
Access Control
VLAN tagging
VLAN ID: Default AP tag, VLAN ID 10
Firewall & traffic shaping
Block IPs and ports (Guest SSID)
Layer 2 LAN isolation
Enabled
Outbound rules
Top-down priority
  • Deny Local LAN Access Rule: Source = Any, Any Source Protocol, Destination = Local LAN, Any Destination Protocol
  • Default Allow All Rule: Any, Any Source Protocol, Destination = Any, Any Destination Protocol
Traffic shaping rules (Guest SSID)
Per-client bandwidth limit
Enable SpeedBurst
Per-SSID bandwidth limit
Shape traffic
Default Rules
50 Mbps
Enabled
100 Mbps
Shape traffic on this SSID
Block IPs and ports (Data/CORP SSID)
Outbound rules
Top-down priority
  1. Allow Local LAN Access Rule: Source = Any, Any Source Protocol, Destination = Local LAN, Any Destination Protocol
  2. Default Allow All Rule: Any, Any Source Protocol, Destination = Any, Any Destination Protocol
Traffic shaping rules (Data/CORP SSID)
Shape traffic
Default Rules
Unlimited
Unlimited
SSID Availability
SSID availability (all SSIDs)
Visibility
Advertise this SSID publicly
SSID Availability
Per access point availability
Enabled on all access points
Radio Settings
RF profiles (Indoor/Outdoor default)
General/Band selection
All  SSIDs
Radio Settings
RRM
AI-RRM
Enabled
Under Wireless>Monitor> on the Dashboard
Main Menu
Section
Subsection
Values
Access Points
<Select AP>
LAN IP (edit)
 DHCP, VLAN 511
Input variables can be conveniently updated through the workflow's user input window, with assistance from the AI Assistant, or by manually accessing the workflow.
Refer to the main KB: Unified Branch
  • Was this article helpful?
