Switch Settings
Click 日本語 for Japanese
Overview
Configure > Switch Settings is where you can configure global switch settings such as the management VLAN, spanning tree for the switch stack, quality of service, and more.
Management VLAN
By default, the switch will try to contact Meraki Dashboard on the untagged (native) VLAN. Alternately, you can specify the management VLAN under Configure > Switch settings. This allows the switch to reach the internet via a trunk port.
VLAN configuration where the Management VLAN is set to 4000
Assigning a static IP address and/or VLAN to a switch will override management VLAN settings configured on this page.
If you change the management VLAN and the switch can no longer obtain a DHCP lease or reach Meraki Dashboard, the switch will revert to its previous management VLAN configuration.
If your network does not allow the native VLAN or any of the default VLANs to DHCP or connect to the internet, you will need to manually assign a management VLAN. To do this, place the switch on a network running DHCP, then from dashboard navigate to Monitor >> Switches and select the target switch. From the details page, choose "Set IP Address" and save your changes.
An Alternate Management Interface can also be configured to source management traffic such as Syslog messages and communication with RADIUS servers from a different VLAN.
Management VLAN on Catalyst switches
When configuring DHCP for management on Catalyst switches using a native VLAN, the VLAN field must be explicitly specified, even if it is the native VLAN. This differs from the configuration on access points (APs), where the VLAN field is often left blank.
  • Unlike APs, a Catalyst switch requires the VLAN to be defined to indicate which VLAN the switch will use for management. By default, if the VLAN field is left blank, the switch assumes VLAN 1 for management.
  • Once a VLAN value has been configured for management on the switch, it cannot be left blank again; the VLAN field must always contain a value.
  • The VLAN specified for management determines the VLAN used for management traffic, and whether tagging is applied depends on the port configuration.
Rapid Spanning Tree Protocol (STP/RSTP)
RSTP/STP helps prevent network loops by creating a loop-free network topology. For details on how to configure spanning tree, check out our Configuring Spanning Tree on Meraki Switches article.
Spanning Tree bridge priority of 0 set to CORE_SWITCH_1
Quality of Service (QoS)
QoS can help re-prioritize network traffic. For more information on implementing QoS, please refer to this article.
Quality of service settings configured for multiple ports and VLANs
Multicast Settings
IP multicast is a method of sending Internet Protocol (IP) datagrams to a group of interested receivers in a single transmission; helping to save throughput as the traffic is sent from the source once in total. MS switches can forward IGMP traffic and will run IGMP snooping by default, with certain MS switches also supporting multicast routing. For more information regarding multicast on the MS, please refer to the Multicast Overview, Configuration, and Best Practices article.
Multicast settings setup where 'IGMP snooping' is enabled and 'flood unknown multicast traffic' is disabled
MTU Configuration
The Maximum Transfer Unit (MTU) is the payload size allowed in an Ethernet frame. The Meraki MS Series supports Jumbo Frames up to 9578 bytes.
The Default MTU value is 9578 for all switches in a Network. You can configure a custom MTU size for all switches in a network or adjust the MTU value for individual switches. If a switch does not have a specific MTU value set, it will use the network default. This default setting also applies to any new switches added to the network in the future.
You can can set the MTU size to 1500 if you want to turn off Jumbo Frames support.
SVI MTU size is 1500
Note: Some Devices Datasheet mentions MTU values including 22 Bytes for Ethernet Headers and Frame Check Sequence (FCS). Therefore, make sure you check and enter the correct value according to your switch. Cisco Meraki Examples:
  • The maximum MTU on MS425 is 9416 bytes (i.e.: 9394 + 22 = 9416). Therefore, enter MTU size 9394.
  • The maximum MTU on MS390/C9300/C9300X/C9300L switches is 9198 bytes (i.e.: 9176 + 22= 9198). Therefore, enter MTU size 9176.
A custommtu of 1500 has been configured on switch 'sfo12-1-1-sw-01'
Storm Control
Enhanced Storm Control can be enabled on supported switches to suppress Broadcast, Multicast and Unknown Unicast packets based on a percentage of traffic on a given interface. Suppression monitors the bandwidth of each individual switch port every 1 second. On classic MS switches, if the specified type of traffic exceeds the defined limit, only excess packets will be dropped. For more information on implementing Storm Control, please refer to this article.
Storm control settings configured where broadcast, multicast and unknown unicast traffic have 5 percent of available port bandwidth
Power Supply Settings
Cisco Meraki switches with dual power supplies can be configured in one of two modes; redundant power or combined power. In redundant power mode, the secondary power supply acts as a backup source and doesn't increase the PoE budget. In combined power, the PoE budget is increased however if a power supply fails then the switch may not be able to provide enough power depending on the current client draw. For more information on implementing Combined Power, please refer to this article.
Power supply settings where switches will use redundant power by default. One switch has been configured to always use combined power
Network Client Sampling
Meraki MS Switches by default will disable sampling of clients and traffic on the detected uplink interface to ensure that reporting data is accurate. The discovery mechanisms were to identify MS to MS links, and disable sampling dynamically. This works well for end-to-end Meraki networks, but in networks where there are ANY intermediary devices, or Catalyst + Meraki deployments, client connectivity and locations could become inaccurate. To address this, sampling can be changed to all interfaces.
For more information on Network Client Sampling, please refer to this article.
Network client sampling is configured with the default option to exclude uplink interfaces
  • Was this article helpful?
