Cloud Monitoring for Catalyst
Cloud Monitoring for Catalyst is no longer available for new devices. Organizations with existing devices can continue to use Cloud Monitoring until March 31, 2026. For more details, see Cloud Monitoring End of Service - Transition to Cloud-Native IOS XE.
Cloud Monitoring functionality has been replaced by cloud management with device configuration, an enhanced solution with new features. We recommend upgrading to cloud management with device configuration as soon as possible.
Learn more with these free online training courses on the Meraki Learning Hub:
Cloud Monitoring for Catalyst Wireless is now Cloud-native IOS XE for wireless controllers. Please go to Cloud-native IOS XE Wireless Controllers to learn how to onboard your wireless controllers to dashboard.
What is Cloud Monitoring?
Cloud monitoring for Catalyst provides an integrated view of Catalyst 9000 series switches in the Meraki dashboard, seamlessly integrated into a single-pane-of-glass experience.
Cloud monitoring provides the ability to view switch statistics, configuration, and troubleshooting capabilities. These devices will be automatically tagged with “Monitor Only” in the dashboard to distinguish from fully managed Meraki switches and access points. Aside from this difference, “Monitor Only” Catalyst device appear and function very similarly to Meraki MS switches in the dashboard, including a visual representation of connected ports and traffic information.
What Cloud Monitoring is Not
Cloud monitoring does not replace other management solutions for configuration of switches. As a monitoring tool, most operations are read-only (exception example: Image Upgrade for Cloud Monitoring for Catalyst switches) . All live troubleshooting capabilities will also not result in persistent changes to configuration following the troubleshooting operation.
Cloud Monitoring Terms and Conditions
Use of and access to Cloud Monitoring features in the Meraki Dashboard are governed by the Meraki Offer Description and Cisco General Terms (the "Terms"). Any terms applicable to your Catalyst devices prior to enrollment in Cloud Monitoring (e.g., hardware warranty, end of life policy, technical support) continue to apply. By using Cloud Monitoring you agree to the Terms and further agree that certain mandatory configurations will be pushed to your enrolled Catalyst wireless controllers devices as further described HERE. And for Catalyst switches as further described HERE.
Quick Start Guide
Learn
Switching Customers
Detailed Onboarding Guides
Switching Customers
Feature Guides
Switching Customers
  • Was this article helpful?
