Third Generation MV Cameras: Overview and Specifications
Overview
The MV13, MV23, MV33, MV63, MV73, and MV93 series are Cisco Meraki's third generation of smart cameras. They feature faster edge analytics, 4K video recording, and machine learning for custom computer vision and camera intelligence. These cameras include IR illumination for clear visibility in low light and nighttime conditions. They support outdoor and wireless deployment, ensuring easy integration into various environments.
The MV63 and MV13 are fixed-focus cameras, while the MV23 and MV73 are varifocal cameras. They include advanced analytics, computer vision, audio detection, and the ability to record up to 4K. Their smaller form factor allows easy integration into existing environments. The MV93 and MV33 share the same innovative architecture as the rest of the MV family and offer 360° viewing for better area context.
With the new edge analytics and 4K capabilities, the third generation introduces integrated IR illumination, up to 1TB of onboard storage, and physically adjustable pan and tilt for optimal viewing. These cameras also feature built-in automatic security with secure boot and signed firmware, supported by a hardware security chip.
All third-generation cameras comply with NDAA standards. The MV63 and MV93 series are designed to endure transportation environments, offering reliable performance against shock and vibration with EN 50155 Railway Compliance certification.
This image highlights the NDAA compliance and EN 50155 Railway Compliance certification of the MV63 and MV93 series cameras, showcasing their reliability in secure and transportation environments.
Features
  • Managed via Meraki Dashboard
  • Integrated IR illumination for dynamic Day-Night transition
  • Built-in analytics like motion search, motion recap, and motion heatmaps
  • Intelligent motion indexing with search engine
  • Historical person tracking
  • Secure video access to ensure privacy with role-based user accounts
  • Shared, customizable video wall via Meraki Dashboard
  • Built-in automatic security with secure boot and signed firmware, backed by a hardware security chip
  • NDAA Compliant
  • Customizable recording and retention settings with higher retention using Smart Codec and Smart Retention
  • Always-on, Scheduled, or Motion based recording options
  • Cloud-augmented edge storage for minimal physical infrastructure
  • More detailed information with up to 4K resolution*
  • High dynamic Range capability for recording in harsh lighting conditions
  • Event search via Meraki vision portal
  • Configurable Privacy Windows
  • Wired / Wireless deployment
*2880x2880 for the MV93 and MV33
Configuration
The initial setup of third-generation MV cameras is straightforward, similar to other MV models. Additional resources and step-by-step instructions are available through the provided links for completing the configuration process.
  1. Claim the device to an Organization on the Meraki Dashboard
    1. If a Dashboard Organization does not yet exist, Create one
  2. Add the device to a Dashboard Network
    1. If a Network does not yet exist, Create one first
  3. Physically connect the device to the local network
    1. Follow the steps in the corresponding Installation Guide
    2. Connect the device to any existing network infrastructure that provides PoE, DHCP, and Internet access
    3. Boot the device and let it check in to the Dashboard
  4. Allow the device to completely check-in and perform any initial firmware upgrades
  5. Finish configuring the device from the Meraki Dashboard
    1. Configure Wireless Profiles
    2. Configure Privacy Windows
    3. Configure Recording / Retention Settings
Technical Breakdown
Hardware Breakdown
MV63/MV63M/
MV63X
MV93/MV93M/
MV93X
MV13/MV13M MV33/MV33M MV23M/MV23X MV73M/MV73X MV53X
Maximum Possible Video Quality
(Full quality options here)
Up to 4K
w/ H.264 Smart Retention at 15fps
Up to 8MP (2880x2880)
Up to 4K
Up to 4K
Up to 4K
Up to 4K
Image Sensor 1/2.8” 8.41MP (3854x2176) progressive CMOS
image sensor
1/2.3” 12.4MP (4072x3046) progressive CMOS
image sensor
backlit image sensor
image sensor
image sensor
1/1.8" 8.41MP
image sensor
Focal Length
3.3 mm focal length
1.6 mm focal length
3.3 mm focal length
1.6 mm focal length
3 mm - 9 mm
focal length
3 mm - 9 mm
focal length
2.5 mm - 38 mm
focal length
Aperture
f/2.0
f/2.0
f/2.0
f/2.0
f/1.6-f/2.9  f/1.6-f/2.9 f/2.05-f/2.2
Shutter Speed 1/30s - 1/32000s 1/30s - 1/32000s 1/30s - 1/32000s 1/30s - 1/32000s 1/30s - 1/32000s 1/30s - 1/32000s 1/30s - 1/32000s
Field of View
Horizontal: 102°
Vertical: 55°
Diagonal: 120°
Horizontal: 180°
Vertical: 180°
Horizontal:
101.3°
Vertical: 54.4°
Diagonal: 119.7°
Horizontal: 180°
Vertical: 180°
Horizontal: 36°-112°
Horizontal:
36°-112°
Vertical:
20°-57°
Diagonal:
42°-138°
Horizontal:
12-37°
Lens Adjustment Range
Tilt: 65°
Rotation: 350°
Pan: 350°
N/A
Tilt: 65°
Rotation: 350°
Pan: 350°
N/A Tilt: 65°
Rotation: 350°
Pan: 350°
Tilt: 65°
Rotation: 350°
Pan: 350°
IR Illuminators
Yes, up to 20m (66ft)
Yes, up to 15m (49ft) N/A Yes, up to 30m (98ft) Yes, up to 30m (98ft) Yes, up to 50m (164 ft)
Video Storage
MV63- 256GB high endurance solid state
MV63X- 1TB high endurance solid state
MV93- 256GB high endurance solid state
MV93X- 1TB high endurance solid state
MV13 - 256GB high endurance solid-state
MV13M - 512GB high endurance solid-state
MV33 - 256GB high endurance solid-state
MV33M - 512GB high endurance solid-state
MV23M- 512GB high endurance solid state
MV23X- 1TB high endurance solid state
MV73M- 512GB high endurance solid state
MV73X- 1TB high endurance solid state
Wireless
802.11a/b/g/n/ac
802.11a/b/g/n/ac
802.11a/b/g/n/ac
802.11a/b/g/n/ac
802.11a/b/g/n/ac 802.11a/b/g/n/ac N/A
Thermal Elements
Yes
Yes
N/A N/A Yes Yes Yes
Ratings
IK10+ and IP67
IK10+ and IP67
N/A N/A IK10+ and IP67 IK10+ and IP67 IK10+ and IP67
Refer to the Video Retention knowledge base article for details on the number of retention days achievable for each MV camera model.
Wireless Radio
  Third Gen
Radios
2.4 GHz 802.11b/g/n
5 GHz 802.11a/n/ac
Antenna
Integrated 1x1 MU-MIMO Omnidirectional
(4.4 dBi gain at 2.4 GHz, 6.3 dBi gain at 5 GHz)
Channel Width 20, 40, and 80 MHz channels
Supported Frequencies
2.412 - 2.484 GHz
5.150 - 5.250 GHz (UNII-1)
5.250 - 5.350 GHz (UNII-2)
5.470 - 5.600, 5.660 - 5.725 GHz (UNII-2e)
5.725 - 5.825 GHz (UNII-3)
QAM Up to 256 QAM on both 2.4 GHz and 5 GHz bands
802.11 Security WPA, WPA2-PSK, WPA2-Enterprise with 802.1X,WPA3-Personal (PSK / SAE), EAP-TTLS, TKIP and AES encryption
Physical
Series
MV63/MV63M/
MV63X
MV93/MV93M/
MV93X
Mount Oritentation Wall / Ceiling Mount Wall / Ceiling Mount Wall / Ceiling Mount Wall / Ceiling Mount Wall / Ceiling Mount Wall / Ceiling Mount Wall Mount
Supported Mount Accessories Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount Pole mount, Wall mount L bracket, Wall mount arm, Conduit back box, T-rail adapter, Corner mount
Pole mount, Conduit
back box,
Corner Mount
Dimensions (dia x h)
5.1 x 3.7 in /
130.98 x 95 mm
5.4 x 2.6 in /
137.68 x 67.9 mm
4.72 x 3.28 in /
120 mm x
83.5 mm
4.72 x 1.96 in /
120.66mm x 49.8mm
5.85 x 3.77 in /
148.54 mm x 95.80 mm
6.55 x 4.06 in /
166.39 mm x
103 mm
Weight 2.02 lb / 0.92kg
2.31 lb / 1.05 kg
0.94 lb / 0.43 kg 0.72 lb / 0.33 kg 1.85 lb / 0.84 kg 3.26 lb / 1.48 kg
Power Supply 802.3at PoE 802.3at PoE 802.3af PoE  802.3af PoE  802.3at PoE 802.3at PoE 802.3at PoE
Power Load (max) 25.5W 25.5W 12.95W 12.95W 25.5W 25.5W 25.5W
Environmental Temperature  -40°C to 50°C (-40°F to 122°F) -40°C to 50°C (-40°F to 122°F) 0°C to 40°C (32°F - 104°F)  0°C to 40°C (32°F - 104°F)  0°C to 45°C (32°F to 113°F) -40°C to 50°C (-40°F to 122°F) -40°C - 50°C (-40°F - 122°F)
Accessories
A complete set of options and guidelines are outlined in the article: MV Mounting Options and Guidelines.
  Description
MA-MNT-MV-18 Mounting Plate. Used for attaching camera perpendicular to mounting surface
Dimensions for bracket (l x w x d) 160 x 104 x 286mm
Combined weight: 0.67kg
MA-MNT-MV-28 Pole Mount. Can be used in conjunction with MA-MNT-MV-18.
Dimensions : 46.5 mm x 181.193 mm x 110 mm
Combined weight: 0.509 kg
MA-MNT-MV-38 Wall Mount L-bracket. Used for attaching camera perpendicular to mounting surface.
Dimensions : 179.55 mm x 159.954 mm x 104 mm
Combined weight: 0.547 kg
MA-MNT-MV-48 Wall-mount arm bracket
Dimensions: 339.55 mm x 159.54 mm x 104 mm
Combined weight 0.908 kg
MA-MNT-MV-58 Conduit back box.
Dimensions: 46 mm x 150.681 mm
Weight: 0.671 Kg
MA-MNT-MV-68 T-rail adapter
Deep:
Dimensions: 34.242 mm x 72.142 mm x 74 mm
Weight: 0.040 kg
MA-MNT-MV-88 Corner Mount
Dimensions: 218 mm × 150 mm x 135 mm
Weight: 0.781 kg
MA-PWR-MV-LV
Meraki Low Voltage Power Adapter for MV cameras.
MA-INJ-4-US Meraki 802.3at PoE Injector (US plug)
MA-INJ-4-EU Meraki 802.3at PoE Injector (EU plug)
MA-INJ-4-UK Meraki 802.3at PoE Injector (UK plug)
MA-INJ-4-AU Meraki 802.3at PoE Injector (AU plug)
Comparisons with Similar Models
  MV63/MV63M/MV63X MV13/MV13M MV33/MV33M MV93/MV93M/MV93X MV23M/MV23X MV73M/MV73X MV53X
Max Video Quality 4K video recording (3840x2160) with H.264 Smart Retention, up to 15fps 4K video recording (3840x2160) with H.264 Smart Retention, up to 15fps 8MP video recording (2880x2880) with H.264 Smart Retention, up to 15fps 8MP video recording (2880x2880) with H.264 Smart Retention, up to 15fps 4K video recording (3840x2160) with H.264 Smart Retention, up to 15fps 4K video recording (3840x2160) with H.264 Smart Retention, up to 15fps 4K video recording (3840x2160) with H.264 Smart Retention, up to 15fps
Video Storage 256GB/512GB/1TB 256GB/512GB 256GB/512GB 256GB/512GB/1TB 512GB/1TB 512GB/1TB 1TB
Troubleshooting
Common Troubleshooting
My MV isn't connecting to the wireless network.
Ensure the wireless profiles are correctly configured in the Meraki Dashboard by navigating to Camera > Settings > Wireless. Before connecting to a wireless network, use a hardwired connection to allow the device to check in with the Meraki Dashboard, download the configuration, and perform any necessary firmware updates.
The Video Feed is all white / too bright
Ensure Night Mode (Camera > Settings > Night mode) is not set to 'Always On' if the camera is in a well-lit area. This setting increases sensitivity to infrared light, which can cause the image to appear washed out
The Video Feed is all black / too dark
Ensure that Night Mode is not set to 'Always Off' if the camera is in a location that experiences low lighting levels. Night Mode makes the camera much more sensitive to infrared light and can help improve visibility in low light conditions.
I can't get the direct LAN stream to work, even when connected to the same network
Each MV camera generates a unique domain name for secure direct streaming. These domain names resolve to an A record pointing to the camera's private IP address. Any public recursive DNS server can resolve this domain.
If utilizing an on-site DNS server, please allow '*.devices.meraki.direct' or configure a conditional forwarder so that local domains are not appended to '*.devices.meraki.direct' and that these domain requests are forwarded to Google public DNS.
Event Log
The most common Event Log messages and their meaning are listed below.
Night mode transition
This event indicates the camera transitioned into or out of Night Mode. Includes the current lux reading and the new state of Night Mode.
Image settings change
Indicates there was a change to the image or recording configuration. Includes the user that applied the change, the option that was changed, old value, and new value
Refer to Technical FAQs for more information.
