MS130R Datasheet
Overview
Cisco Meraki MS130R extends reliable and secure layer 2 connectivity to ruggedized environments. The MS130R provides up to 240W of PoE and IP30 protection, making it perfect for connecting outdoor access points, cameras, and devices in extreme temperatures (-40°C to 70°C or -40°F to 158°F) and tight spaces.
Designed for adapting to non-traditional environments, the diverse mounting and power options offer deployment flexibility. The powerful Meraki cloud-native platform enables seamless and remote deployment and management of entire Meraki product suite through one centralized dashboard.
Features
Configuration
The basic initial configuration of the MS130R is just as simple as any other model of MS switch. The links below provide additional information and instructions relating to each step in getting the device setup and configured for the first time.
- Claim the device to an Organization on the Meraki Dashboard
- If a Dashboard Organization does not yet exist, Create one
- Add the device to a Dashboard Network
- If a Network does not yet exist, Create one first
- Physically connect the device to the local network
- Connect one of the RJ45 or SFP ports to existing infrastructure to provide a temporary uplink
- Power on the device and let it check in to the Dashboard
- If necessary, configure a Static IP through the Local Status Page to allow it to communicate with the Meraki Dashboard.
- Allow the device to complete check-in and perform any initial firmware upgrades
- Finish configuring the device from the Meraki Dashboard
Technical Breakdown
Hardware Breakdown
MS130R Models
| MS130R-8P | |
| 1Gbe RJ45 | 8 |
| 1GbE SFP | 2 |
| Dedicated Mgmt Interface | - |
| PoE Type |
802.3bt * |
| PoE Port Budget | 30W * |
| PoE Switch Budget | 240W |
Power Input |
50-54VDC, 5.6A |
Power Load (idle/max) |
12W/257W |
| Power Consumption | 12W-257W |
| Operating Temperature | |
Storage and Transportation Temperature |
-40°F - 185 °F -40°C - 85°C |
| Humidity | 5% to 95% |
| Mounting |
Desktop, Wall mount, DIN rail options |
| Switching Capacity | 20Gbps |
| Power Supply | External AC Adapter or DIN rail AC power supply options |
| Fan Operation | Fanless |
| Dimensions (h x w x d) |
1.75 x 6.18 x 6.69in (4.4 x 15.7 x 17cm) |
| Weight | 2.12 lb (0.96 kg) |
* Note: This model uses and understands IEEE 802.3bt-2018 PoE negotiation and capabilities but is limited to 30W per port PoE budget.
Thermal and PoE limitations
Operating temperature limitations
| Installation Environment |
Fan/blower equipped enclosure |
Vented enclosure | Sealed enclosure | Desktop |
| Ventilation | 200 LFM | 40 LFM | 0 LFM | 40 LFM |
| Operating Temperature Limits |
-40°F - 158°F -40ºC to 70ºC |
-40°F - 149°F -40ºC to 65ºC |
-40°F - 140°F -40ºC to 60ºC |
Vertical -40ºC to 60ºC Horizontal -40ºC to 55ºC |
Airflow around the switch must be unrestricted. To prevent the switch from overheating, you must have the following minimum clearances:
- Top and bottom: 2.0 in. (50.8 mm)
- Sides: 1.0 in. (25.4 mm)
- Front: 2.0 in. (50.8 mm)
Caution: When the switch is installed in an enclosure, the temperature within the enclosure is greater than normal room temperature outside the enclosure. For example the DIN rail power supply also generates heat which may raise the temperature on the switch. To reduce this increase ventilation or space between the power supply and the switch.
Power Supply De-rating
De-rating is the reduction of the output power depending on the ambient temperatures. When the ambient temperature rises above a certain threshold, the amount of power that the power supply can output decreases as the temperature rises, which limits the amount of power the switch can provide to connected PoE devices.
| Power Supply |
MA-PWR-300W-INDADP |
PWR-IE240W-PCAC-L= |
PWR-IE480W-PCAC-L= |
| De-rating |
24W/5°C over 45°C |
30W/5°C over 50°C |
60W/5°C over 50°C |
What's In the Box
| Model | Included |
| MS130R-8P |
Power Supplies
MS130R can be powered via an external AC power supply adapter or DIN rail power supply*. Power supplies must be ordered separately and are not included in the box.
| Power supply type | Part number | Dimensions (W x H x D) |
| External AC adapter |
| DIN rail power supply |
*The DIN Rail power supplies are Cisco branded devices. For more information regarding the DIN rail power supplies, see the Cisco datasheet here
Accessories
Region-specific power cords are not included in the box*. Order the appropriate power cord separately:
- MA-PWR-CORD-US
- MA-PWR-CORD-EU
- MA-PWR-CORD-UK
- MA-PWR-CORD-CN
- MA-PWR-CORD-IN
- MA-PWR-CORD-BR
- MA-PWR-CORD-TW
- MA-PWR-CORD-AU
- MA-PWR-CORD-AR
Rack-mount screws are not included in the box, but can be ordered separately. Meraki recommends sourcing rack-mount screws and nuts made for your specific rack.
SFP Modules
The following SFP/Fiber transceivers are supported
| MS130R-8P |
Note: All the SFPs that are supported by MS130-8P model are also compatible with the MS130R when operating under the SFP module’s operating limits.
*These GLC modules are Cisco branded devices. For more information regarding these modules, see the following Cisco datasheets:
Certifications
| Description | Specification |
| Safety Certifications | UL 60950-1 / UL 62368-1 3rd Edition |
| CAN/CSA C22.2 No. 60950-1 / No. 62368-1 | |
| EN 60950-1 / EN 62368-1 | |
| IEC 60950-1 / IEC 62368-1 2nd & 3rd Edition | |
| NOM-019-SCFI-1998 | |
| CNS 15598-1 | |
| EMC Emissions and Immunity Compliance | FCC 47 CFR Part 15 Class A |
| ICES 003 Class A | |
| EN 55032/ 55035 Class A | |
| AS/NZS CISPR 32 Class A | |
| VCCI Class A | |
| CNS 15936 | |
| EN 300 386 | |
| IEC/EN 61000-4-9 | |
| IEC/EN 61000-4-29 | |
| International Standards | EN 50581 (RoHS) |
| China RoHS | |
| CE Marking | |
| RCM Marking (Australia/New Zealand) | |
| Japan VCCI & JATE | |
| Taiwan BSMI | |
| Korea KC | |
| Brazil ANATEL | |
| China NAL | |
| Mexico IFETEL | |
| EU WEEE | |
| NEMA TS-2 | |
| IP30 | |
IEC 60068 -2-3 / -2-30 |
Troubleshooting
Common Troubleshooting
My device is connected to the network but not checking in to the Meraki cloud or shows a solid Orange LED.
Confirm that the device is powered on and has a valid IP address that is able to access the Internet. Use the Local Status Page to get more information about the connectivity status of the device such as if it can successfully reach the Local Gateway, Internet, and/or Meraki Cloud servers. If necessary, contact Meraki Support for additional assistance.
My Status LED is blinking WHITE
A blinking WHITE Status LED indicates that the device is in contact with the Dashboard Cloud servers and is performing a firmware update. This can sometimes take 20-45 minutes or more to complete depending on hardware and other factors.
My Status LED is blinking ORANGE
The device is not able to successfully communicate with the Dashboard Cloud servers or there may be a hardware issue with the device. Check the Local Status Page of the device to confirm the status and reach out to Meraki Support for further troubleshooting.
Event Log
The most common Event Log messages and their meaning are listed below.
Port STP change
Indicates the STP state of the port has changed, lists the relevant port number, previous, and new states. Typically accompanied by a 'Port status change' event.
Port status change
Indicates the link state of the port has changed, lists the relevant port number, old, and new state. Always accompanied by a 'Port STP change' event.
SFP module inserted/removed
Indicates that an SFP module was either inserted or removed, includes SFP module information for inserted events and always lists the relevant port number.
Licensing
Model |
License |
Description |
MS130R-8P |
LIC-MS130-CMPT-xY LIC-MS130-CMPTA-xY |
MS130R-8P Enterprise license and Support MS130R-8P Advance License and Support |
MS130R Enterprise licenses are available in 1-, 3-, 5-, 7-, and 10- year terms.
MS130R Advanced licenses are available in 1-, 3-, and 5- year terms.
MTBF Rating
Model |
MTBF at 25°C (in hours) |
| MS130R-8P | DIN rail : 682,913 Adapter : 761,689 |
