Meraki Auto VPN Configuration Settings
Click 日本語 for Japanese
Overview
Meraki Auto VPN is a feature on Cisco Secure Routers, MX and Z-series WAN appliances that enables site-to-site VPN connectivity between networks. It allows administrators to configure VPN settings through the Meraki dashboard, where tunnels between devices are automatically established and maintained. Auto VPN performs the work normally required for manual VPN configurations with a simple cloud based process.
When enabled through the dashboard, each participating MX and Z Series appliances automatically does the following:
  • Advertises its local subnets that are participating in the VPN.
  • Advertises its WAN IP addresses on Internet 1 and Internet 2 ports.
  • Downloads the global VPN route table from the dashboard (automatically generated by the dashboard, based on each MXs advertised WAN IP/local subnet in the VPN network).
  • Downloads the preshared key for establishing the VPN tunnel and traffic encryption.
The net result is an automatic mesh site-to-site VPN solution that is configured with a single click.
This article outlines how the Auto VPN mechanisms work and how Meraki manages the cloud processes for Auto VPN.
Definitions
  • VPN Registry: This is the main server mechanism that allows Auto VPN to happen. It is a cloud service that is used to keep track of the contact information for all the WAN Appliance participating in Auto VPN for an organization.
WAN Appliances in warm spare with Virtual IP address (VIP) will use VIP to communicate with the VPN registry.
  • Hub: Hubs are devices in a VPN topology that service connectivity from a remote peer site (such as a spoke) to the hub and the hub to the remote peer site. Hubs also act as a gateway for remote peer sites to communicate with each other via the hub.
  • Spoke: Remote sites that connect to a central hub and communicate with each other only through the hub.
  • Peer: This refers to another WAN Appliance within the same organization that a local WAN Appliance will form or has formed a VPN tunnel to.
  • Contact: This is the public IP and the UDP port that the WAN Appliance will communicate on for Auto VPN.
Auto VPN: A Component of Meraki SD-WAN
    SD-WAN Characteristics         Meraki SD-WAN Component
Support for VPNs Meraki Auto VPN
Multiple connection types (MPLS, Internet, LTE, etc.) WAN Appliance uplink options allow for multiple connection type.
Dynamic path selection (allows for load sharing across WAN connection) WAN Appliances can perform uplink load balancing across WAN connections
Simple WAN Configurations Interface (Must support zero-touch provisioning at a branch, should be easy to set up) Meraki dashboard & API configuration interfaces
Auto VPN, as a component of SD-WAN, transitions the manual steps for setting the VPN tunnel into a simple automated process. It takes only a few clicks and makes it easy to deploy and manage an SD-WAN environment. It gives resilience, security and application optimization. It has automatic VPN route generation using the IKE/IPSec-like tunnels and all this is done in the Meraki cloud.
If you have two uplinks on your WAN Appliance, Auto VPN as a component of SD-WAN allows you to decide the flow preferences within the VPN tunnel under Security & SD-WAN > Configure > SD-WAN & traffic shaping page > Uplink selection > Multi-Uplink Auto VPN. Multi-Uplink Auto VPN allows you to create a VPN tunnel with flow preferences over both the uplinks.
If Multi-Uplink Auto VPN is disabled, the tunnel will be formed over the primary WAN link and will failover to the secondary if the primary fails.
Learn more with these free online training courses on the Meraki Learning Hub:
Prerequisites and limitations
Licensing requirements
  • Cisco Secure Routers, MX and Z-series devices use a per-device licensing model, where each device requires a corresponding license in the Meraki dashboard
  • There are three license tiers such as Enterprise, Advanced Security, and Secure SD-WAN Plus
  • Auto VPN functionality is included as part of the MX and Z-Series feature set and does not require a separate license
  • Auto VPN can operate between MX and Z-Series Teleworker with supported license configurations, depending on the organization’s licensing model
Hardware requirements
  • All MX and Z-Series models support Auto VPN
Limitations
  • Auto VPN requires connectivity to the Meraki cloud to establish and maintain VPN tunnels
  • Upstream firewalls must allow outbound UDP ports 9350–9381 for Auto VPN registry communication
  • Network conditions such as restrictive NAT or firewall policies may prevent VPN tunnels from forming. In such situations, a manual upstream port forward to the MX may be required. Refer to  NAT Traversal section down below.
Configuration steps
To enable Auto VPN between WAN appliances:
Step 1: Select the network containing the device you want to include in the VPN topology
Step 2: Setting up Auto VPN
Navigate to Security & SD-WAN > Configure > Site-to-site VPN and select the Type (Hub or Spoke) to enable VPN connectivity. Auto VPN takes care of all connection settings and brokers the connections immediately.
Type
There are three options for configuring  MX and Z-series devices in the Auto VPN topology:
  • Off: The MX and Z-series devices does not participate in Site-to-Site VPN
  • Hub (Mesh): The MX and Z-series devices establishes VPN tunnels to all remote Meraki VPN peers configured in Hub (Mesh) mode.  The device also establish VPN tunnels to other MX and Z-series appliances in hub-and-spoke mode, where the other MX and Z-series device configured as a hub.
  • Spoke: The MX device establishes VPN tunnels only to the specified hub devices. Other spokes are reachable through their respective hubs unless restricted by site-to-site firewall rules.  If the majority of WAN Appliances in the Auto VPN domain are configured as Spoke with only a few key locations (such as data centers or headquarters) configured as hubs, then the Auto VPN environment has a hub-and-spoke topology.
Hub type
Exit hubs
This option is available only when the MX appliance is configured as a Hub.
It designates a remote MX device to receive all network traffic from the local MX. This creates a full tunnel configuration, where all traffic destined for the default route is sent to the specified MX.
Security features over full-tunnel VPN
In a full tunnel topology, all security and content filtering must be performed on the full tunnel client. The Exit hub will not apply content filtering, Intrusion Prevention System (IPS) blocking, or malware scanning to traffic coming in over the VPN. However, an Intrusion Detection System (IDS) scanning will be performed for this traffic.
Screenshot of the Site-to-site VPN settings page. This Security appliance is configured as a Hub, and has an exit hub selected.
Spoke type
Hubs
When an WAN appliance is configured as a spoke, multiple VPN hubs can be configured for that appliance. In this configuration, the spoke MX and Z-series device will send all site-to-site traffic to its configured VPN hubs.
Screenshot of the Site-to-site VPN settings page. This Security appliance is configured as a spoke, and has a hub selected and IPv4 default route is not selected.
Default route
When configuring hubs for a spoke, there is an option to select a hub as a Default route.
When enabled, the selected hub acts as the default route (0.0.0.0/0) for the spoke. Any traffic not destined for the following is sent to the default route:
  • Configured VPN peer networks
  • Static routes
  • Local networks
This routing applies to traffic originating from:
  • Subnets set to “In VPN”
  • Subnets with VPN mode “Enabled”
Subnets with VPN mode “Disabled” do not follow the VPN routing table.
Multiple hubs can be selected as default routes. These hubs are prioritized in descending order, with the highest priority at the top.
Screenshot of the Site-to-site VPN settings page. This Security appliance is configured as a spoke, and has a hub selected and an IPv4 default route enabled.
Configuring multiple VPN hubs
To add additional hubs, select the Add a hub button below the existing hub.
Only appliances in Mesh VPN mode can be configured as hubs. The number of Mesh VPN appliances in your dashboard organization determines the maximum number of hubs that can be configured.
The order in which hubs are configured defines the hub priority. Hub priority determines which hub is used when more than one VPN hub advertises the same subnet. The highest priority hub that meets the following criteria is used:
  • Advertises the subnet
  • Currently reachable via VPN
You can manage hubs as follows:
  • Delete a hub: Click the grey X next to the hub under the Actions column
  • Reorder hubs: Drag and drop the grey four-point arrow icon to change priority
Tunneling
There are two tunneling modes available for MX and Z devices configured as a Spoke:
  • Split tunnel (no default route): By default all WAN Appliances in the Auto VPN domain (dashboard organization) will only send traffic to an Auto VPN peer if the traffic is destined for a subnet contained within the Auto VPN domain. This is often referred to as 'split-tunnelling,' meaning that VPN-subnet-bound traffic is sent over VPN, and other traffic is routed normally via the primary WAN Appliance WAN uplink. If an organization wants to route all traffic (including traffic not contained within the Auto VPN domain) through a specific hub site, this is referred to as 'full-tunneling.' Full-tunneling only affects client data and all Meraki management traffic will egress directly via the primary WAN regardless.
To configure full-tunneling in a full mesh topology simply define an Exit hub from the WAN Appliances in the Auto VPN domain.
Send only site-to-site traffic, meaning that if a subnet is at a remote site, the traffic destined for that subnet is sent over the VPN. However, if traffic is destined for a network that is not in the VPN mesh (for example, traffic going to a public web service such as www.google.com), the traffic is not sent over the VPN. Instead, this traffic is routed using another available route, most commonly being sent directly to the Internet from the local MX and Z-series device. Split tunneling allows for the configuration of multiple hubs.
  • Full tunnel (default route): To configure full-tunneling in a hub-and-spoke topology, simply associate a ‘Default route’ with one or more hub WAN Appliances.
The configured Exit hub(s) advertise a default route over Auto VPN to the spoke MX and Z series device. Traffic destined for subnets that are not reachable through other routes will be sent over VPN to the Exit hub(s). Exit hubs' default routes will be prioritized in descending order.
Full tunneling only affects client data, and Meraki management traffic will continue to use the WAN uplink directly.
Concentrator priority
The concentrator priority determines how appliances in Hub (Mesh) mode will reach subnets that are advertised from more than one Meraki VPN peer. Similarly to hub priorities, the uppermost concentrator in the list that meets the following criteria will be used for such a subnet.
A) Advertises the subnet
B) Currently reachable via VPN
It is important to note that concentrator priorities are used only by appliances in Mesh mode. An appliance in hub-and-spoke mode will ignore the concentrator priorities and will use its hub priorities instead.
NAT traversal
If the MX and Z-series device is behind a firewall or other Network Address Translation (NAT) device, there are two options for establishing the VPN tunnel:
  • Automatic: In most cases, the MX and Z-series device can automatically establish site-to-site VPN connectivity to remote Meraki VPN peers even through a firewall or NAT device using a technique known as "UDP hole punching". This is the recommended (and default) option.
  • Manual: Port forwarding: If the Automatic option does not work, you can use this option. When Manual: Port forwarding is enabled, Meraki VPN peers contact the MX and Z-series device using the specified public IP address and UDP port number. You will need to configure the upstream firewall to forward all incoming traffic on that UDP port to the IP address of the MX and Z-series device.
Make sure the port number you have chosen is not already used by another service. For example, do not use port 500 or 4500 as these are used for Client VPN and 3rd party VPN peer communication.
Screenshot of the Site-to-site VPN settings page. NAT traversal is set to "Manual: Port forwarding", and the public IP and port are configured as 1.1.1.1:50000.
Local networks
If you have multiple LAN subnets, you can specify which VLANs and static routes participate in the VPN.
Select Enabled under VPN Mode to define which locally defined or available subnets are to be exported to the Auto VPN domain.
The same subnet can be advertised from more than one WAN appliance only if all advertising WAN appliances are in Passthrough or VPN Concentrator mode.
All subnets advertised from a WAN appliance in Routed mode must be unique within the Auto VPN topology.
Subnets to which the MX and Z-series device have Static LAN routes can also be advertised over the VPN. If you choose to advertise a statically routed subnet over the VPN, ensure that the gateway device for each subnet is configured to route traffic for remote VPN subnets to the MX and Z-series device, to keep your routing symmetrical.
Subnets to which the MX-Z device has Static LAN routes can also be advertised over the VPN. If you choose to advertise a statically routed subnet over the VPN, ensure that the gateway device for each subnet is configured to route traffic for remote VPN subnets to the MX-Z device, in order to keep your routing symmetrical.
In full tunnel configurations when specifying a prefix to be part of a VPN, everything covered by that prefix will be allowed in the VPN. Therefore, subnets that overlap will cause traffic in a more specific subnet to be sent through the VPN, even if it is not configured to be included in the VPN. For example, if 10.0.0.0/16 is configured to be included in the VPN but 10.0.1.0/24 is not, traffic sourced from 10.0.1.50 will still be sent over the VPN.
VPN subnet translation
This feature is only supported for Auto VPN and is not intended to work with IPsec VPN peers.
In large distributed networks, multiple networks may have identical subnet scopes (for example, overlapping subnets). Site-to-site VPN requires unique and non-overlapping subnets. If multiple locations have the same local subnet, enable VPN subnet translation to translate the local subnet to a new subnet with the same number of addresses. For more information, refer to the
 Using Site-to-site VPN Translation article.
Subnet Translation Example
  • Branch 1 local subnet: 192.168.31.0/24
  • Branch 2 local subnet: 192.168.31.0/24 (identical!)
  • Branch 1 translated subnet: 10.0.1.0/24
  • Branch 2 translated subnet: 10.0.2.0/24
In the example above, even though both networks have identical local subnets, they can communicate over the VPN using their translated VPN subnet. Branch 1 is accessible as 10.0.1.0/24 and Branch 2 is accessible as 10.0.2.0/24 over the VPN tunnel.
Screenshot of the Site-to-site VPN settings page. VPN subnet translation is enabled.
Open shortest path first (OSPF) route advertisement
As part of MX 18.1 firmware updates we are introducing a new Routing page, more details found in the "OSPF Configuration" section of the IPv6 Support on MX Security & SD-WAN Platforms - Routing article.
While the WAN Appliance does not currently support full OSPF routing, OSPF can be used to advertise remote VPN subnets to a core switch or other routing device, avoiding the need to create static routes to those subnets. OSPF advertisement is supported in VPN Concentrator mode or in Routed mode on MX 13.4+ firmware with VLANs disabled.
Advertise remote routes: If this is set to Enabled, OSPF will be used to advertise remote VPN subnets as reachable via this MX.
Router ID: The OSPF Router ID that this MX will use to identify itself to neighbors.
Area ID: The OSPF Area ID that this MX will use when sending route advertisements.
Cost: The route cost attached to all OSPF routes advertised from this MX.
Hello timer: How frequently the MX  will send OSPF Hello packets. This should be the same across all devices in your OSPF topology.
Dead timer: How long the MX will wait to see Hello packets from a particular OSPF neighbor before considering that neighbor inactive.
MD5 Authentication: If this is enabled, MD5 hashing will be used to authenticate potential OSPF neighbors. This ensures that no unauthorized devices are injecting OSPF routes into the network.
Authentication Key: The Message Digest Algorithm 5 (MD5) key number and passphrase. Both of these values must match between any devices that you wish to form an OSPF adjacency.
WAN appliances in Routed mode only support OSPF when using the "Single LAN" LAN setting. This can be set on Addressing & VLANs page.
Screenshot of the Routing page after OSPF is enabled.
VPN firewall rules
To configure VPN firewall rules, navigate to the appropriate settings under Security & SD-WAN. These rules control what traffic is allowed to pass through the VPN tunnel and apply to outbound VPN traffic to and from all MX and Z-series WAN appliances in the organization that participate in site-to-site VPN, including outbound IPsec VPN peer tunnel and related BGP control traffic.
Firewall rules will not apply to inbound traffic or to traffic that is not passing through the VPN.
For configuration steps, refer to the Site-to-site VPN Firewall Rule Behavior article.
After completing the configuration steps, the Site-to-site VPN tunnel should be established. If the VPN tunnel does not come up immediately, send a ping to an IP address in the remote subnet to establish the VPN tunnel.
Step 3: Select Save to apply the configuration.
Auto VPN is a simple opt-in process. You can think of the WAN Appliances dashboard organization an existing VPN hub and spoke mesh topology environment, and every WAN appliance that has Auto VPN turned on is simply choosing to participate in that mesh. By default, all hubs contact all other hubs, and all spokes contact specified hubs. Additional configuration options can be found below.
Additional Auto VPN configuration options
Enable Auto VPN by defining how the WAN Appliance will communicate with the rest of the Auto VPN domain
If the WAN Appliance is configured as a Hub, it will build VPN tunnels to all other Hub WAN Appliances in the Auto VPN domain (in the same dashboard organization). It will also build VPN tunnels to all Spoke WAN Appliances in the Auto VPN domain that have this WAN Appliance configured as a hub. If all WAN Appliances in the Auto VPN domain are configured as Hub then the Auto VPN has a full mesh topology.
If the WAN Appliance is configured as a Spoke, it will build tunnels to only the WAN Appliances that are configured as its Hubs.  If the majority of WAN Appliances in the Auto VPN domain are configured as Spoke with only a few key locations (such as data centers or headquarters) configured as hubs, then the Auto VPN environment has a hub-and-spoke topology.
Choose which subnets (local networks) to export over VPN
Earmark which locally defined or available subnets are to be exported to the Auto VPN domain. Select Enabled under VPN Mode to define available subnets over the VPN.
Then save the changes so the WAN Appliance fetches the configurations from the cloud.
Post-configuration steps
Monitoring Auto VPN
To monitor the status of the site-to-site VPN tunnels between Meraki devices, navigate to Security & SD-WAN > Monitor > VPN Status. This page provides real-time status for the configured VPN tunnels. It lists the subnet(s) being exported over the VPN, connectivity information between the MX and Z-series WAN appliance and the Meraki VPN registry, NAT Traversal information, and the encryption type being used for all tunnels. For more information, refer to the VPN Status Page article. 
Additional information
How Auto VPN works
  1. MX1 and MX2 are part of the same organization. MX1 and MX2 are configured to participate in Auto VPN. Both MX1 and MX2 send a Register Request message to their VPN registry in order to share their own contact information, and to get the contact information of the peer WAN Appliance(s) that it should form a VPN tunnel with. The Register Request message contains the IP address and the UDP port that the WAN Appliance communicates on, and the WAN Appliance requests the contact information of its peer WAN Appliance(s).
  2. VPN registries send the Register Response messages to the WAN Appliances with the contact information of the peers the WAN Appliances should establish a tunnel with.
  3. Once the information is shared with the WAN Appliance about its peers, a VPN tunnel is formed WAN Appliance to WAN Appliance. The Meraki cloud already knows the subnet information for each WAN Appliance, and now the IP addresses to use for tunnel creation. The cloud pushes a key to the WAN Appliances in their configuration which is used to establish an AES encrypted IPsec-like tunnel. Local subnets specified by dashboard admins are exported/shared across VPN. During this process, VPN routes are pushed from the dashboard to the WAN Appliances. Finally, the dashboard will dynamically push VPN peer information (e.g., exported subnets,  tunnel IP information) to each WAN Appliance. Every WAN Appliance stores this information in a separate routing table.
Any devices sitting upstream of a WAN Appliance will need the following destinations whitelisted so the WAN Appliance can communicate with the Auto VPN registries:
  • Port
    • UDP 9350-9381
  • IP range for non-China cloud (meraki.com):
    • 209.206.48.0/20
    • 158.115.128.0/19
    • 216.157.128.0/20
  • IP range for China cloud (meraki.cn):
    • 43.192.139.128/25
    • 43.196.13.128/25
Ports used for IPsec tunneling:
  • Source UDP port range 32768-61000
  • Destination UDP port range 32768-61000
The VPN connection can be monitored under Security & SD-WAN > Monitor > VPN status page. The status of each WAN Appliance is displayed, along with their exported subnets, latency, connectivity and routing decisions that are being made over the Auto VPN domain in near real-time.
