Meraki MX/Z Security and SD-WAN Licensing
Overview
The Meraki MX security appliance is a multi-functional security & SD-WAN enterprise appliance with a wide set of capabilities to address multiple use cases for organizations of all sizes, in all industries.
Given the range of use cases that can be solved, there are three license options for the MX security appliance that provides customers the flexibility to select the license most appropriate for their intended use.
Enterprise |
Advanced Security |
Secure SD-WAN Plus |
| “All I require is Auto VPN and a firewall” | “I connect directly to the Internet so need a UTM too” | “My business is reliant on SaaS/IaaS/DC served apps” |
The licensing structure for MX security appliances is the same as that of any other Meraki device – 1:1 ratio of devices to licenses. Pair your chosen MX appliance(s) with the relevant license for your use case:
Enterprise license
OR
Advanced security license
OR
Secure SD-WAN Plus license (Org-Wide and Per Device)
For subscription licensing, refer to the MX and Z subscription articles for all the details. At this time, subscription and co-termination licenses can not be mixed in the same dashboard organization.
A subscription order can be created with a mix of essentials and advantage licenses. You may have one or more subscription in the same org and each network must be bound to one subscription to consume licenses from that subscription.
The vMX only supports Essentials and does not support the Advantage tier. Essentials tier will support all the Advanced Security features noted here.
Features by License Option
The following feature breakdown is from the latest stable release. For the latest firmware release and its features, please refer to the features directory documentation.
For API support, please refer to the API documentation.
**Requires a separate license
*** MI features supported on C8000-series devices with MX OS 26.2+.
For licenses and their respective features available in mainland China, please refer to the following article for the details.
Teleworker Gateway License Breakdown
The Meraki Teleworker Gateway is a type of a security appliance intended for use in small remote offices and homes of remote workers. Allowing them to securely connect back to their head offices while also offering the same security as our MX security appliance Platform.
Refer to Meraki Licensing FAQs for more information.
With the introduction of the Z4/C, we are also introducing two new types of licenses for the Teleworker series.
These licenses are not supported by the Z1 and Z3 teleworker gateways
Z-Enterprise |
Secure Teleworker |
Teleworker Features by License Options
Feature |
Z-Enterprise |
Secure Teleworker |
Centralized management |
Zero-touch firmware updates |
True zero-touch provisioning |
24x7 enterprise support |
Open APIs |
Automatic WAN failover |
Sub-second site-to-site VPN failover |
Sub-second dynamic path selection |
| Cellular failover | ✔ | ✔ |
Stateful firewall |
VLAN to VLAN routing |
Advanced Routing |
Traffic shaping/prioritization |
Site-to-site VPN |
Client VPN |
Splash pages |
Configuration templates |
Group Policies |
Client connectivity alerts |
Source-Based Routing |
Local Breakout (IP based) |
Umbrella DNS Integration** |
Geography based firewall rules |
Content filtering |
YouTube Content Restriction |
Web Search Filtering |
Cisco Advanced Malware Protection (AMP) |
Threat Grid Integration** |
WAN Health Analytics (MI) |
VoIP Health Analytics (MI) |
Smart breakout |
Z4 Licenses are as follows:
- Z-Enterprise: LIC-Z4-ENT-[X]Y
- Secure Teleworker: LIC-Z4-SEC-[X]Y
X= Number of Years
Virtual MX (vMX) License Breakdown
Meraki vMX is a virtual security and SD-WAN appliance that creates a fast, secure, and persistent connection between networks across different physical and virtual mediums, different cloud hyperscalers, and different public cloud regions.
Any vMX running firmware 19.1 and above supports two licensing options in Co-Termination licensing model.
Enterprise |
Advanced Security |
The vMX Enterprise and vMX Advanced Security have a similar feature set as the MX.
vMX Features by License Options
Feature |
Enterprise |
Advanced Security * |
Zero-touch firmware updates (including security patches) |
Open APIs |
High Availability (Act- Act model, via eBGP to Cloud routers) |
Sub-second Site-to-Site VPN failover |
Site-to-site VPN (Auto VPN and 3rd party peering) |
IPv6 Support |
Client VPN |
Policy-Based Routing |
Local Breakout (IP and Port based) |
Advanced Routing |
Security Appliance alerts |
Splash pages |
Cloud Integrations |
Group Policies |
Stateful firewall |
Next-gen Traffic Analytics Engine - Network-Based Application Recognition (NBAR) Integration |
Layer 7 (Application) Enforcement powered by NBAR |
Enhanced Live Firewall Logging and Troubleshooting |
Traffic Shaping Enforcement powered by NBAR |
Intrusion Detection and Prevention System (IDS/IPS) |
Content Filtering powered by Talos Intelligence |
* Advanced Security supported on MX19.1+ for the vMX
vMX Licenses are as follows:
vMX-Enterprise: LIC-VMX-S/M/L-ENT-[X]Y
vMX-Advanced-Security: LIC-VMX-S/M/L-SEC-[X]Y
X= Number of Years
Per Device SD-WAN+ License
This new license type will bring SD-WAN+ licenses for a per-network basis for organizations on the Co-termination Licensing model with Advanced Security Licensing. Customers can now purchase the appropriate license type and assign them to the respective network to get all SD-WAN features on a per-network basis. The terms available are 1, 3 and 5 years only. Please see the table below to have the MX platforms mapped to their respective SKUs.
- Per Device SD-WAN+ Licenses are NOT available with Per Device for Subscription models.
- Per Device SD-WAN+ Licenses are a per network license used to upgrade a network from Advance Security to SD-WAN+.
Once the licenses are claimed under Organization→ License info, you will need to go to Insight→ Configure→ Licensing to assign the licenses to the respective compatible networks.
You can assign the licenses using the ‘Add licenses to network’ or remove licenses using the ‘Remove Licenses from network’
You can assign a higher license-tiered SKU to a lower licensed-tiered network. Example: You can assign LIC-MX-SDW-M-1YR to a MX64
Assigning the Per Device SD-WAN+ SKU to a network will give that network access to all of the below SD-WAN features, except when the network is bound to configuration template.
| MX Platform | SKU |
| MX64/W, MX65/W | LIC-MX-SDW-XS-1Y |
| MX64/W, MX65/W | LIC-MX-SDW-XS-3Y |
| MX64/W, MX65/W | LIC-MX-SDW-XS-5Y |
| MX67/C/W, MX68C/W | LIC-MX-SDW-S-1Y |
| MX67/C/W, MX68C/W | LIC-MX-SDW-S-3Y |
| MX67/C/W, MX68C/W | LIC-MX-SDW-S-5Y |
| MX75, MX84, MX85 | LIC-MX-SDW-M-1Y |
| MX75, MX84, MX85 | LIC-MX-SDW-M-3Y |
| MX75, MX84, MX85 | LIC-MX-SDW-M-5Y |
| MX95, MX100, MX105 | LIC-MX-SDW-L-1Y |
| MX95, MX100, MX105 | LIC-MX-SDW-L-3Y |
| MX95, MX100, MX105 | LIC-MX-SDW-L-5Y |
| MX250, MX450 | LIC-MX-SDW-XL-1Y |
| MX250, MX450 | LIC-MX-SDW-XL-3Y |
| MX250, MX450 | LIC-MX-SDW-XL-5Y |
For Enterprise Agreement Customers, contact your respective Meraki seller to add Per Device SD-WAN+ Licensing to a Meraki EA Dashboard. Please note the following key points about this licensing:
- Legacy Enterprise Agreement Dashboard customers will be able to utilize Per Device SD-WAN+ (Per Dev SDW+) as they would in an a-la-carte co-term dashboard.
- EA terms including True Forward and Value Shift will apply to per-device SDW as well.
Note: Enterprise licensed customers cannot be in a mixed license environment. Advance Security License is required to support a mixed license environment on the Co-termination Licensing model. Please refer to the FAQ section below for mode details.
Please refer to Meraki Licensing FAQs for more licensing information.
FAQs
How are licenses enforced on MX security appliance?
The licenses are on a per-model basis. Every MX model has a corresponding license. They are non-transferable between appliance models. For instance, an MX64 license will not be covered by an MX84 license.
Can we mix two license types in a single organization?
Yes, but it depends on the Organization's use-case. The following use-cases are possible:
1. Organization is licensed in Co-termination Enterprise license: this Org can add Per device Z-Series
Z-Series can be added to organizations regardless of current MX license type. In general, Enterprise licensed customers cannot be in a mixed license environment. However, this does not apply to Z-Series devices (including the new Z-Series Secure Teleworker licenses).
In-addition, with the Jan 14 2025 launch of the Advanced Security License for the vMX, the vMX now also has to be at Advanced Security if the MX Org license tier is Advanced Security or SDWAN+. ENT vMX cannot be used with a Adv Sec or SD-WAN+ MX Org. SDWAN+ is not available for vMX devices but an Adv Sec vMX license can be used with SDWAN+ MX Orgs.
The Z4 enterprise and Z4 teleworker licenses cannot be mixed on the same org.
2. Organization is licensed in Co-termination Advanced Security license: this Org can add Per Device SD-WAN+ licenses.
Check section Per Device SD-WAN+ licenses for more details. Example: if you have 25 MX networks in your organization, you can have 20 MX devices with Advance Security features and upgrade 5 MX devices with Per Device SD-WAN Plus licenses to get SD-WAN features.
This is not supported with Enterprise licenses.
Is there a separate license to cover support or device warranty or software upgrades?
Each license is inclusive of device RMA, 24x7 enterprise support, and software upgrades.
Will there be a requirement to pay extra for new features?
New features are added by license type.
- Features added to the enterprise license option will be available free-of-charge to all existing MX customers.
- Features added to the advanced security license option will be available free-of-charge to all existing MX customers with an advanced security or SD-WAN Plus license.
- Features added to the Secure SD-WAN Plus license option will be available free-of-charge to all existing MX customers with an SD-WAN Plus license.
Are MX licenses available on both Co-Term and PDL versions?
All of the MX licenses are available under Co-Term as well as Per-Device Licensing (PDL), with the exception of the Per Dev SDW+ license, which is not supported in PDL. For More information and general differences between the two, please see the documentation on Meraki Licensing.
Can you move from one MX license edition to another, for example, Enterprise to Advanced Security or SD-WAN Plus?
Currently, there are two ways to move to a different MX license edition:
- Purchase the desired MX license type (one license for all compatible MXs in the organization) and apply them to the organization which will convert the entire organization to the desired license type. Note: This will adjust your remaining licensing term depending on the license type (duration, MX model, license type)
If you are claiming the key using the “Renew my dashboard” option (in the co-termination licensing model), it will automatically upgrade the entire organization to reflect the product edition of the new key. Note: There is no such thing as a “partial” renewal in the co-termination model, so if you wish to convert using this option, you must ensure you have new licenses for all other devices as well.
If you are claiming the license using the “License more devices” option, you will need to reach out to Meraki Support for assistance, as the organization (all existing MX licenses) will first need to be upgraded to the desired security edition before the dashboard allows you to claim the new security edition to your organization. In order for Support to fulfill the request, it must come from a write privilege organizational-level administrator.
- Contact Meraki support and convert the organization to the desired license option. Note: You will have a new co-termination date for your organization with this method.
- If upgrading moving from Enterprise to Advanced Security, the remaining credit for the MXs will be cut in half due to the increased feature set.
- If upgrading from Enterprise to SD-WAN+, the remaining credit for the MXs will be cut by 60 to 75% depending on the MX model being converted.
- If upgrading from Advanced Security to SD-WAN+, the remaining credit for the MXs will be cut by 25% to 50% depending on the MX model being converted.
- The following MXs are eligible for SD-WAN+ Upgrades: MX64/W, MX65/W, MX67/W/C, MX68/W/CW, MX75, MX84, MX85, MX95, MX100, MX105, MX250, MX450
- If you are choosing to downgrade your organization's security edition, there will be no additional credit given back.
Upgrading to SD-WAN+ is only available in Co-Term through the above-mentioned ways. To upgrade to SD-WAN+ in a Per-Device-Licensing organization, you must purchase the corresponding SD-WAN+ device licenses and claim them to the organization, which will force the organization into SD-WAN+.
Are free trials available for each of the MX license types?
Yes. Please contact your Meraki Sales representative for more information.
How does Warm-Spare MX set up work with the license?
In a network where two MXs are configured in Warm-Spare mode will only require one MX license.
Will Meraki Insight be available as a separate license?
No. The separate Meraki Insight license has been deprecated. If you need the Meraki Insight current and future feature sets, please use the Secure SD-WAN Plus license.
Is Per Dev SDW+ going to be available on PDL or subscriptions?
No, Per Dev SDW+ is only available in Co-term and won’t be available in PDL or subscriptions.
Can Per Dev SDW+ be assigned to networks with Enterprise License?
No, the minimum requirement to have Per Dev SDW+ assignment is for the org to have Advance Security licenses.
Will Per Dev SDW+ affect my co-term date?
Yes, it will follow the same logic as the other licenses and will affect the co-term end date.
Where can I find information on Licensing and Free Tests for the ThousandEyes integration with the Meraki MX?
The licensing and free tests information for the ThousandEyes integration can be found in the Meraki MX ThousandEyes Configuration Guide.
Can I upgrade my organization from Enterprise to Advanced Security or Secure SD-WAN Plus (MX only)?
Yes, this can be done one of two ways:
- You can opt for Advanced Security or Secure SD-WAN Plus licensing when you Extend Device Expiration Dates or renew your organization as per Meraki Licensing - License More Devices vs Renewal article.
You can also contact the Cisco Meraki Licensing Support team via phone (see Contacting Support) or open a case from the Support home page, requesting that they assess if your organization can be upgraded to Advanced Security or Secure SD-WAN Plus without purchasing additional licensing.
- Any MX security appliance keys will be adjusted to account for cost weight between Enterprise and Advanced Security or Secure SD-WAN Plus.
- Please note that if going through Cisco Meraki Support, the process is irreversible.
If the incorrect license key edition was purchased within the past 30 days, the Cisco Meraki team will not upgrade/downgrade the key. The key must be returned and the correct key reordered.
MX licenses under the per-device licensing model cannot be upgraded to SD-WAN+ by Meraki Support at this time.
Can my organization be downgraded from Secure SD-WAN Plus or Advanced Security to Enterprise (MX only)?
Yes, you can purchase and apply an Enterprise renewal key that covers all devices in your organization, which will revert your organization to an Enterprise state. You can also contact Cisco Meraki Licensing Support via phone or email and have your organization downgraded. Please note that if the organization is downgraded, you will not receive any additional time from the downgraded license keys. This process is irreversible.
