How to Move Devices Between Organizations
Overview
This guide covers the process of moving devices between organizations in Cisco Meraki. You may need to move devices between organizations for reasons such as splitting a large organization into smaller ones or transferring a device from a trial to a production environment. Organizations using the co-termination licensing model must perform this process manually.
Prerequisites
Before moving devices between organizations, confirm the following conditions are met:
- Only organization administrators have the permissions required to move a device between organizations.
- For security reasons, Meraki support will not remove or move devices on behalf of an organization administrator.
- Moving devices between organizations typically takes 5 to 60 minutes. While the device is updating, it stays offline
Licenses may only be transferred between organizations managed by the same customer.
Pre-configure the receiving network to match the existing network configuration before moving the device.
Be aware of the following impacts when moving devices
- The static IP addressing set on the devices will change when moved to a different organization.
- The Meraki dashboard configuration applied to the device will not migrate to the new organization.
The steps in this guide apply to organizations using the co-termination licensing model. For instructions on moving devices and licenses between organizations using the per-device licensing (PDL) model, refer to Meraki Per-Device Licensing Overview.
Note: When moving Switch Stacks between organizations, all stacking information is lost. Split the stack and rebuild it in the new organization when moving Switch Stacks between organizations.
Step-by-step instructions
Moving devices to another organization
- Create the organization at dashboard.meraki.com if it has not been created.
If the new organization will be managed by the same user or group as an existing account, refer to the documentation on adding the new account to an MSP Portal for easier administration.
On the current organization, remove the device by following the steps outlined How to Add and Remove Devices from Dashboard Networks
Removing a camera from a network permanently deletes all footage from the device.
- On the new organization, navigate to Organization > Inventory, and click Claim to add the device. Refer to the Organization Inventory documentation for more information.
The system may take up to 60 minutes to sync before a device removed from a network can be claimed again.
4. Add the device to the target network by following the steps outlined How to Add and Remove Devices from Dashboard Networks. If the organization is new, create a network using Creating and Deleting Dashboard Networks.
To move Systems Manager (SM) devices between existing organizations, manually un-enroll the devices from the SM network in the original organization before enrolling them into an SM network in the destination organization. For more information, review the Uninstalling Systems Manager and Removing Managed Devices and Enrolling Devices articles.
Moving licensing
Meraki licenses are for use only by the original customer. Licenses cannot be transferred between customers. Refer to the End Customer Agreement for policy details.
When a device is moved to a new organization, the organization may receive a 30-day grace period before licensing is required.
During this time, the organization must either purchase and claim a new license or transfer an existing license from the previous organization.
Use the following guidance to determine the correct licensing transfer process:
- Co-termination model (both organizations): Organization administrators can move licenses between organizations using How to do a License Transfer in Cotermination documentation.
- Per-device licensing (PDL) model (both organizations): Organization administrators can move licenses themselves. Refer Meraki Per-Device Licensing Overview for steps on transferring licensing under PDL.
- License claimed to the wrong organization within the past 7 days: Refer to Removing and Undoing License Claims (co-termination only).
If a subscription was mistakenly claimed to the wrong organization and needs to be moved, contact support.
Splitting a subscription license into two separate subscriptions is not supported. When devices move to a different organization, a new subscription is required for those devices in the new organization.
Moving devices between networks
For procedures, refer to Moving Devices between Networks. Review the documentation to understand the impact on device settings, licensing, and network configurations.
