Apple Device Enrollment Program (DEP)
The Apple Device Enrollment Program (DEP) allows administrators to pre-provision iOS, iPadOS, and macOS devices to automatically self-enroll into Systems Manager before even touching them, and provides an additional level of management control through bulk device supervision. This greatly simplifies adding and deploying iOS, iPadOS, macOS, and tvOS devices with Automatic Device Enrollment into Meraki Systems Manager. This article will cover how to use the Apple Automatic Device Enrollment with System Manager.
For additional information on DEP, including how to qualify for the program, please review Apple's official deployment guide. Additional information can be found directly from Apple Business Manager portal or Apple School Manager portal.
Linking Systems Manager to Apple DEP
In order to use the Apple DEP with Systems Manager, a Systems Manager deployment must be linked to an organization within DEP. These steps assume an Apple ID for the organization has already been created, as outlined in the Device Enrollment Program Guide. You can also use Apple Business Manager portal or Apple School Manager portal for the same functionality.
In Dashboard, create an EMM network for Systems Manager.
Navigate to Organization > Configure > MDM, then scroll down to the Apple Device Enrollment Program section.
Download the Meraki_Apple_DEP_cert.pem file provided.
If someone has downloaded the .pem file previously, and the server token has expired, click clear token in order to download the .pem file again.
In another browser window, go to the Apple Business Manager or Apple School Manager portal and sign in with the Apple ID tied to the desired organization.
Navigate to Settings > Device Management Settings
Click Add MDM Server.
Enter a Name for the MDM server in DEP, then click Next.
Click Choose File... and upload the .pem public key downloaded in step 3, then click Next.
Download the server token provided, then click Done.
Back in Dashboard, click on the Choose File button in the DEP section.
Select/upload the server token downloaded in step 9.
Choose the default Systems Manager network where devices tied to this MDM server in DEP will be enrolled.
Click Save Changes.
If you encounter an error uploading the server token to Dashboard, make sure that the file name ends in 'smime.p7m' without any trailing characters like '(1)' that may appear from downloading multiple copies of the file.
The last downloaded DEP token on the Apple portal is the only one that MDMs can sync with. You may see error "Sync failed: Unable to connect to Apple's servers at this time." or "Sync failed. Please try again later." in the event that the current token is unable to sync. The Apple portal shows the following warning if someone tries to download a token twice:
In this case, the token would need to be renewed again in order to continue syncing with Meraki Systems Manager.
Renewing a DEP Token
Apple DEP tokens last for one year by design. To continue enrolling via DEP:
In your Meraki Dashboard navigate to Organization > MDM and click on the Apple DEP Server you want to renew. In the Edit DEP Server window press Update Token.
Then, press download your public key cert to download the Meraki_Apple_DEP_cert.pem file.
Log in to the Apple Business Manager or Apple School Manager portal.
Navigate to Settings > MDM Servers > Click on the MDM server to renew ("Meraki" in the screenshot below).
Click on Edit and then click on Upload New...
Upload the Meraki_Apple_DEP_cert.pem file and click Apply to save. Then press on Download Token to download the Meraki_Token_smime.p7m file.
Now back in your Meraki Dashboard upload the Meraki_Token_smime.p7m file to Meraki to finish updating your DEP token.
After this process is finished, the token is valid for another 365 days.
If the existing DEP token is cleared or the DEP server is deleted instead of renewing the token, all associated DEP settings profiles will be removed from the Systems Manager > DEP page and will have to be re-created manually.
Importing Devices
The following steps will help you import devices into your Apple DEP server and sync them into Systems Manager.
To import devices into your Apple DEP server via Apple Order Number or Serial Number:
In Apple Apple Business Manager or Apple School Manager, navigate to Devices > Device Assignments
Choose Order Number, Serial Number, or Upload CSV file and provide the appropriate information.
Choose the Assign to Server action and select the desired MDM server.
Click Done.
To sync the devices from your Apple DEP server into System Manager, there are two ways.
Navigate to Systems Manager > Manage > DEP, this will cause a partial sync between System Manager and Apple DEP server.
If devices are missing, you can try a full sync by clicking on the full sync button in the top right of the page.
Note: To be eligible, devices must have been purchased directly from Apple within the last three years, or through participating resellers and carriers. This requirement will be changing with iOS 11, which will allow users to add iOS or iPadOS devices from any purchaser into DEP. For more information regarding this and supported countries, please refer to Apple's Device Enrollment Program page.
iOS 11+ devices can be added into an existing DEP account through Apple Configurator on macOS, even if it was not purchased from Apple or an Apple reseller. For steps on how to do this, see this article.
And on macOS devices with Apple Silicon, add them to your organization's DEP account with an iOS device running the Apple Configurator app. More information here.
Applying Settings to Devices
DEP settings are applied during setup assistant, either upon setting up the device for the first time, or after a factory reset for devices already in use.
DEP Enrollment Status
There are 3 states for the 'DEP enrollment' status column. If you've just synced your devices from the DEP server into Systems Manager, they will be labeled 'Empty'.
Empty: The default state when devices are first synced from DEP into Systems Manager. This means that the device has no DEP settings assigned to them.
Assigned: This means new DEP settings have been assigned to the device, but not yet applied. Upon initial setup, or after a factory reset, the applied settings will take effect.
Pushed: This means the device has its DEP settings applied. You can see information on what settings were pushed, and when, on the other columns of the table.
NOTE: DEP Push status is only related to Device Enrollment status, and does not strictly determine it. This means that you may have devices which show their DEP payloads as 'Empty' which have already been enrolled (and therefore, have a valid link to their Device Details page in the Name column), and devices which show their DEP payloads as 'Pushed' but have yet to complete enrollment (most often because they stopped at the authentication step).
Assigning Settings
After devices have been assigned to Systems Manager via DEP, they will automatically be enrolled in the default Systems Manager network upon setup. Additional configurations such as supervising the device or skipping setup steps will further customize and streamline your deployment.
Navigate to Systems Manager > Manage > DEP within the Systems Manager network.
Click the checkbox next to any devices that require settings be applied.
Click Assign settings.
If you have existing setting profile created, select it from the dropdown. Otherwise, create a new one and complete the fields/selections that appear in the setup:
Profile details
Name: A friendly name for the group of settings profile applied.
Department: Display the organization department the iPad is assigned to. This is displayed during setup.
Support phone number: A number provided to users during setup if help is required.
Support email address: An email address provided to users during setup if help is required.
Options
Skip: Allows you to specify pages during the setup process to skip, e.g. hiding the prompt to set or sign into an Apple ID. These can be completed later if needed.
Supervising host certificate: Devices are only allowed to pair with computers that have the matching keypair. Note: If left unconfigured and no pairing restriction payload is assigned, the device will have the ability to pair with any computer.
Removable: When checked, the management profile can be removed by the user. When unchecked, the management profile cannot be removed by the user. See here for more info.
Auto-advanced Setup Assistant: automatically clicks through the entire Apple Setup Assistant for the user to get to the desktop/homescreen as fast as possible.
iOS
Enable Shared iPad: Used for shared device deployments with Apple School Manager. Do not select this unless you intend to use Temporary Guest Sessions or if you have Apple School Manager provisioned with managed Apple IDs. See official Apple documentation here.
Quota size: The quota size, in megabytes (MB), for each user on the shared device, or if the quota size is too small, the minimum quota size. Provide either the QuotaSize or ResidentUsers. If you provide both values, the MDM server uses QuotaSize.
Resident Users: The expected number of users. If this value is greater than the value for the maximum possible number of users that the device supports, the MDM server uses that value instead. Provide either the QuotaSize or ResidentUsers. If you provide both values, the MDM server uses QuotaSize.
User session timeout: The timeout, in seconds, for the user session. The user session logs out automatically after the specified period of inactivity. The minimum value is 30 seconds. Setting this value to 0 removes the timeout. Available in iOS 14.5 and later.
Temporary sessions timeout: The timeout, in seconds, for the temporary session. The temporary session logs out automatically after the specified period of inactivity. The minimum value is 30 seconds. Setting this value to 0 removes the timeout. Available in iOS 14.5 and later.
Temporary sessions only: If true, the user only sees the Guest Welcome pane and can only log in as a guest user. If false, the user can sign in with a managed Apple ID. Available in iOS 14.5 and later.
macOS
Provisioning package: Installs a signed binary on macOS during the setup assistant.
To add new Provisioning Packages, click on Manage profiles in the SM > DEP page, and then press the button for Manage provisioning packages.
Create a Name for the provisioning package, and then upload a .pkg, manifest upload .plist, or add a manifest url. This is what will be deployed during macOS Setup Assistant.
The package must be a signed binary. The open-source tool Hancock can be used to assist with .pkg file signatures.
Create administrator account: the local admin of the macOS device.
Hide admin account: Makes the admin account hidden to non-administrator accounts.
Managed admin account: One user account will be managed. By default, the regular user account created during Setup Assistant will be managed. If you want to manage the admin account instead, select this option.
Skip creation of primary account: When creating an admin account, you can choose to skip the creation of the primary user account during Setup Assistant.
Configure primary user account: the user's local account on the device.
User account type: either regular or admin. Regular accounts corresponds to a 'Standard' user in macOS > System Preferences > Users & Groups. Admin accounts are local administrators. These options are only available when an administrator account is created.
Pre-fill using Systems Manager owner details: Set a Systems Manager Owner for the devices before enrollment, and the Owner's username and name information will be dynamically set for each device.
Lock user account information to prevent editing: macOS Setup Assistant disables editing of account name and username fields.
Click Save and assign. At this point the 'DEP enrollment' status will update to 'Assigned' for all the selected devices.
The devices can now be drop shipped direct to end-users so they can setup the devices using these settings. Or if the device(s) are already in use, they should be factory reset at this point. This is required to ensure the device is activated and configured with DEP settings, as settings are only applied during the Apple Setup Assistant.
To factory reset to apply the DEP settings to existing devices:
On macOS, restart in Recovery Mode and reinstall the operating system.
On iOS and/or iPadOS, navigate to Settings > General > Reset, then tap Erase All Content and Settings. Confirm by tapping Erase.
In some cases, this may be required for brand-new device as well, if device was activated (connected to Wi-Fi) before DEP settings were assigned in Dashboard. For new deployments, it is important to assign these DEP settings before the devices connect online in their initial Setup Assistant.
In iOS and iPadOS, please choose Set Up as New Device, or skip the "Restore from Backup" option entirely when assigning the DEP settings. Apple does not recommend restoring from iCloud, iTunes, or Migration Assistance backups if the supervision state of the device is changing. iCloud can be signed into after device setup to sync settings. Apple information related to this can be found here.
To apply configuration profiles and settings to devices, the appropriate tags will need to be applied. These can be configured in advance so that once a device enrolls, the tags configured below are automatically applied. Profiles and apps tied to those tags will then be automatically installed upon enrollment for a seamless experience.
Navigate to Systems Manager > Manage > DEP .
Click the checkbox next to any devices the tag must be applied to.
Click Tag.
Within the Add box, type the tag that should be applied to the device(s). If it is an existing tag, select it from the list. Otherwise, click Add option create a new tag. Tags must not contain spaces.
Click Add to apply the tag(s).
Now, any configuration profiles and apps scoped with this tag in Systems Manager will be applied to device upon initial setup.
Removing Settings
In the event a device needs to be reset and managed under different conditions, the settings applied via DEP can be removed.
Navigate to Systems Manager > Manage > DEP.
Click the checkbox next to the device(s) in question.
Click Remove settings.
To overwrite existing settings, follow the previous steps for applying settings. Note that the newly assigned settings will not apply until the device has been factory reset.
If tags were applied to a device prior to enrollment, they can also be removed to prevent profiles and apps from associating.
Click Tag.
In the Remove box, select any tags that should be removed from the device.
Click Remove.
Show/Hide Settings
To hide unused DEP settings presets from being displayed when applying settings, hit the 'Show/Hide settings' option and uncheck the settings you wish to hide.
Recovering DEP Devices
If a DEP-enrolled device is removed from Systems Manager, it will not automatically reappear without taking additional steps to sync Dashboard with Apple DEP.
For specific instructions on DEP device recovery, please refer to our documentation for more info.
Clearing Apple DEP Token
There are some instances where a DEP token needs to be removed to resolve an issue, or to use a different MDM server on the Apple side. To do this, navigate to the Organization > MDM page. Under Apple Device Enrollment Program, click the Clear Server Token button. This will remove the existing token and allow a new one to be uploaded.
Note: Once the DEP token has been cleared, the client drop-down menu under Systems Manager > Manage > DEP with existing DEP settings will be cleared.
It is important to note that any devices that need to be associated with the organization in Dashboard must also be assigned to the new MDM server within Apple's DEP portal. So if the MDM server is changing, the devices should also be reassigned. Avoid doing this if possible when there are a large number of devices already assigned with settings, as clearing the DEP token will purge these assigned settings in the cloud (but not on devices themselves). It is also recommended that a list of assigned devices be exported to a spreadsheet, within the Apple site, to aid in the reassignment process.
