MR Firmware Release Notes (32.1.6 and older)
[ARCHIVE] MR Access Point Release notes
This article is no longer being updated and is available only as an archive of release notes for MR 32.1.6 and before.
For the latest release notes refer to MR Firmware Release Status and Nomenclature.
MR 32.2.4 changelog
Bug fixes
Detailed bug fixes for 32.2.4 moved here
MR 32.2.3 changelog
Bug fixes
  • General stability, performance, and experience improvements.
  • Intermittent ACK frames ignored due to devices not honoring SIFS backoff (Wi-Fi 7)
MR 32.2.2 changelog
Bug fixes
  • APs don’t forward mDNS traffic out wireless interface when using named VLANs (Wi-Fi 7)
MR 32.2.1 changelog
New feature
  • Cisco Spaces Connect on Meraki – Enables APs to efficiently and securely transmit BLE data to the Spaces cloud.
Enhancement
Bug fixes
MR 32.1.7 changelog
Important note
  • MR45/55 APs are not supported on MR 32.x.x and will instead upgrade to the backup version (MR 31.1.8) if they are in networks configured for MR 32.x.x versions, and thus, new features will not be available.
Bug fixes (with Bug IDs)
Detailed bug fixes for 32.1.7 moved here.
MR 32.1.6 changelog
Important note
Enhancement
  • Enhancements to Ethernet link negotiation mechanisms have been implemented to detect temporal link degradation and attempt link recovery when a degraded state is identified.
Bug fixes
  • APs not using configured SGT tag (Wi-Fi 6, 6e, Wi-Fi 7)
  • RADSec authentication stuck (Wi-Fi 6, 6e, Wi-Fi 7)
  • Wi-Fi calling not working (Wi-Fi 6, 6e, Wi-Fi 7)
  • WebEx DeskPro connectivity issues (Wi-Fi 6, 6e, Wi-Fi 7)
MR 32.1.5 changelog
Important note
Bug fixes
  • APs that require 802.3bt PoE for full capability request greater than 30W via CDP when connected to 802.3at (30W-capable) switch port (Wi-Fi 7)
  • AP disassociates previously disassociated client with reason code 2 (Wi-Fi 6, 6e, Wi-Fi 7)
MR 32.1.4 changelog
Important note
  • LSP speed test deprecated
New feature
  • The Per SSID toggle for 802.11be (Wi-Fi 7) feature allows WiFi 7 access points to operate some SSIDs in 802.11ax mode while others operate in 802.11be mode. This is also called "ax/be mixed mode", "per-SSID 11be."
Bug fixes
  • APs intermittently stop sending beacons & responding to clients on 5GHz (Wi-Fi 6e)
  • APs not responding to probe/auth requests from clients on 2.4 & 5GHz (Wi-Fi 6, 6e)
  • Multi/Broadcast packets (RA/DHCP) not forwarded by APs (Wi-Fi 7)
  • Mesh not forming 6GHz 160MHz (Wi-Fi 6e)
MR 32.1.3 changelog
Important note
  • MR45/55 APs are not supported on MR 32.x.x and will instead upgrade to the backup version (MR 31.1.7.1) if they are in networks configured for MR 32.x.x versions, and thus, new features will not be available.
Bug fixes
  • APs do not send beacon frames on 5GHz radio (Wi-Fi 7 APs)
  • MAC auth fails with RADIUS servers that do not supply Message-Authenticator in Access-Accept reply (Wi-Fi 6, 6e, 7 APs)
MR 32.1.2 changelog
New feature
  • Support for DHCP Option 82
Important note
Bug fixes
  • Dashboard channel utilization incorrectly reported above 100% (Wi-Fi 7 APs)
Known issues
  • 6GHz/160MHz mesh not forming on CW9166I APs
MR 32.1.1 changelog
New feature
  • Support for AAA accounting + Fast roaming (802.11r)
  • Support for Mandatory DHCP + Fast roaming (802.11r)
  • Support for Client Exclusion Policies (Manual)
  • Support COA Support + Fast roaming (802.11r)
  • Enables Wi-Fi 7 APs with an embedded UWB radio to conduct sub-centimeter level ranging measurements to improve placement accuracy and flexibility in location-based services
Enhancement
  • 6GHz Support for Transition mode with SAE SSIDs
  • MLO Support with 802.3at power for CW9178
  • Safe Config Override for Site Surveying
  • Support for AP name in beacon without CCX
  • Dashboard support for Zebra devices to report Serial Number, Device Type/Model Number, OS, and Recent disconnect codes
Important note
  • MR45/55 APs are not supported on MR 32.x.x and will instead upgrade to the backup version (MR 31.1.7) if they are in networks configured for MR 32.x.x versions, and thus, new features will not be available.
Bug fixes
  • MAB-based wired clients not re-authenticated after port reset (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
  • Gateway MR to source RADIUS traffic from AMI (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
Known issues
MR 31.x and older releases
Expand/Collapse to view older releases
MR 31.2.5.1 changelog
Bug fixes
MR 31.2.4 changelog
Bug fixes
  • General stability and performance improvements
  • Intra-AP roam between radios not triggering client delete to MCG
  • AP not updating lease record and causing traffic blackhole when mandatory dhcp is enabled
MR 31.2.3 changelog
Bug fixes
  • COA+11r Client session goes to terminated state after roam
MR 31.2.2 changelog
Bug fixes
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)
MR 31.2.1 changelog
Bug fixes
Known issues
MR 31.1.8 changelog
Important note
  • Wi-Fi 5 Wave 2 MRs support - This version and subsequent MR 31.x.x are only supported on 802.11ax (Wi-Fi 6) and newer MR models. 802.11ac Wave 2 and older products will upgrade to the backup version (MR 30.7.1) if they are in networks configured for MR 31.x.x versions, and thus, the new features will not be available. The bug fixes listed below will also not apply to Wi-Fi 5 Wave 2 and older MRs. (https://documentation.meraki.com/MR/Other_Topics/Cisco_Meraki_MR_Firmware_Restrictions_Overview_and_FAQ)
New feature
Bug fixes
  • 6GHz/160MHz mesh not forming on MR57, CW9166I, CW9166D1, CW9164I APs
  • APs do not send beacon frames on the 5GHz radio (Wi-Fi 7 APs)
  • Increased CPU & memory utilization on MR57 APs
MR 31.1.7.1 changelog
Important note
Bug fixes
  • BPDUs not forwarded to LAN ports when using VLAN tagged SSIDs (MR36H APs)
  • SGT source & destination tags swapped (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
Known issues
MR 31.1.7 changelog
Important note
Bug fixes
  • False positive DFS alerts in Japan on MR56 APs
  • APs stop transmitting on wired interfaces due to exception (Wi-Fi 6 APs)
  • Clients disconnect with error code 17 (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
  • Clients disconnect with reason code 0 (reserved) (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
  • Association ID mismatch (Wi-Fi 6, Wi-Fi 6E, Wi-Fi 7 APs)
  • 2.4GHz 802.11n clients unable to connect (Wi-Fi 7 APs)
Known issues
MR 31.1.6 changelog
Important note
  • Wi-Fi 5 Wave 2 MRs support - This version and subsequent MR 31.x.x are only supported on 802.11ax (Wi-Fi 6) and newer MR models. 802.11ac Wave 2 and older products will only upgrade to the backup version (MR 30.7.1) if they are in networks configured for MR 31.x.x versions, and thus, the new features will not be available. The bug fixes listed below will also not apply to Wi-Fi 5 Wave 2 and older MRs. (https://documentation.meraki.com/MR/Other_Topics/Cisco_Meraki_MR_Firmware_Restrictions_Overview_and_FAQ)
Bug fixes
  • MR56 ethernet port flaps occur when connected to C9300-48UN(V04) at 5Gbps speeds
  • MR57 ethernet port flaps occur when connected to MS355 at 5Gbps speeds
  • MR46 not responding to Probe Requests from clients
  • Channel & power not configurable via LSP on CW9163E APs
  • Wildcard NAS-IPv6-Address AVP sent on config change (Wi-Fi 6, Wi-Fi 6E APs)
  • NAS-IP-Address discarded (Wi-Fi 6, Wi-Fi 6E APs)
  • RADSec authentication failures (Wi-Fi 6, Wi-Fi 6E APs)
  • DHCP offer is not forwarded if broadcast flag is set (Wi-Fi 7 APs)
  • mDNS traffic blocked (Wi-Fi 7 APs)
  • SSIDs broadcast on 6Ghz despite being disabled when using WPA3 transition mode (Wi-Fi 7 APs)
MR 31.1.5.1 changelog
Important note
Bug fixes
  • Potential crash loops for 6GHz in non-US regulatory domains (Wi-Fi 6E APs)
  • CW916X APs are requesting 40W PoE power when USB is disabled
Known issues
MR 31.1.4 changelog
Important note
Bug fixes
  • Roaming-related issues with 802.11r configured SSID (Wi-Fi 6 APs)
Known issues
  • APs may experience OOM with NBAR enabled (Wi-Fi 6 APs)
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6 APs)
MR 31.1.3 changelog
Important note
New feature
  • Intelligent Capture for Wireless Proactive packet capture support
Bug fixes
  • Client balancing rejects clients when 9 SSIDs are created
Security fixes
  • libxml2 upgraded to 2.11.7 (CVE-2024-25062)
Known issues
  • Roaming-related issues with 802.11r configured SSID on MR45/55 APs
MR 31.1.2 changelog
Important note
Bug fixes
  • HTTPS redirection does not work for LSP on wired interface
  • Channels missing for rogue detection
Known issues
MR 31.1.1 changelog
Important note
New feature
  • Additional RF Temetries and NDP support for AI-RRM
  • Adding 6 GHz Radio support for 20 Countries
Bug fixes
  • In high-capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 6 and Wi-Fi 6E APs)
Known issues
  • Clients may experience intermittent re-auth issues on MR45/55 APs
  • AFC not available on CW9163E APs
MR 30.7.1 changelog
Important note
Legacy product notice
  • When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
Bug fixes
  • Client balancing rejects clients when the 9th or 10th SSID is enabled
  • AP instability when RADSec is enabled (Wi-Fi 5 Wave 2 APs)
  • VLAN override fails on SSIDs configured to use VLAN ID tagging
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
MR 30.7 changelog
Important note
New feature
  • Adding 5 & 6 GHz radio support for additional countries
Bug fixes
  • AP sends RADIUS traffic out of the primary management interface when the alternate management interface is enabled
  • AutoRF channel auto-updates not occurring on MR20 APs
  • Failure of DNS test results in no connectivity
  • MR36 APs fail to auto-negotiate link with 100Mbps cable
  • L3 Roaming tagging client traffic with non-existent VLAN ID
  • Apple devices can’t connect to APs using SSIDs set for WPA3 and 802.11r (Wi-Fi 5 Wave 2)
  • Reduced throughput on Wi-Fi 6 APs
  • APs experience poor performance after extensive uptime (Wi-Fi 6 APs)
  • In high-capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • Suspected false positive DFS alerts
  • APs fail to receive RadSec certificates
  • APs not broadcasting beacon frames for Site Survey SSID on 6GHz
  • The FastCGI process is unresponsive, which causes issues with affected APs downloading their configuration and returning live stats like current clients, utilization, etc. (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Security fixes
  • Upgraded lighttpd to v1.4.67 (CVE-2022-41556)
Known issues
  • Client balancing rejects clients when the 10th SSID is enabled
MR 30.6 changelog
Important note
Bug fixes
  • AP not returning to original channel after a DFS channel change event occurred (MR45/55)
  • Large mDNS packets can cause loss of wired connectivity (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • User-Name and Calling-Station-Id in different format consuming additional license on ISE (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • UDN ID not properly assigned to clients for "iPSK w/ RADIUS" configuration (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • Incorrect IPSK-EAPOL VSA data for Easy PSK (Wi-Fi 5 Wave 2 APs)
  • Exclude Beidu/GLONASS constellations from GNSS receiver when used for AFC location (Wi-Fi 6E APs)
  • 6 GHz radio not turned off when AFC expires (CW9163E-MR)
  • APs utilizing WPA3 are shown as "Open" in RF Spectrum > Interfering APs UI (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • Clients getting dropped before DHCP lease time expiry during L3 roam and disconnected for more than 30 sec (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • AP failed to change channel (Wi-Fi 6 and Wi-Fi 6E APs)
Enhancement
  • Add 6 GHz support for regulatory domains with new 6 GHz approvals (Wi-Fi 6E APs)
  • Keep 6 GHz radio off for outdoor APs when no configuration provided (CW9163E-MR)
  • Upgrade CiscoSSL from 7.3 to 7.3a
Known issues
  • In high capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • DNS test failure results in no connectivity (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • AMI not sending RADIUS traffic
MR 30.5.1 changelog
Important note
  • While Meraki APs have traditionally relied on UDP port 7351 for cloud communication, and TCP ports 80 and 443 for backup communications, with MR 28+ we are beginning the transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the "Help" > "Firewall Info" page is allowed through any firewalls or security devices that are deployed upstream of your Meraki APs. These requirements have been updated in November of 2022, so it is important that you review them. (Wi-Fi 6 and Wi-Fi 6E APs)
Bug fixes
  • General stability and performance improvements =
Known issues
  • Instability when using iPSK w/ RADIUS (MR36H)
MR 30.5 changelog
Important note
Bug fixes
  • When using VLAN profiles, APs may have failed to associate clients (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • WPA3 OWE AKM suite information was not included in AP beacons (Wi-Fi 5 Wave 2 APs)
  • When using L2 isolation, Windows clients may have experienced connectivity issues (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • When using WPN, DHCP requests did not include option 55 (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
  • In high capacity wireless networks, APs may have experienced instability when the “Band Steering” feature was enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Known issues
  • APs ignore AutoChannel and manual channel changes despite reporting they changed their channel (Wi-Fi 6E APs)
MR 30.4 changelog
Important note
Bug fixes
  • LAN packet capture fix (MR57, MR52)
  • APs stop forwarding RTP traffic (MR45)
Known issues
  • In high capacity wireless networks APs may experience instability when the “Client Balancing” or "Band Steering" feature are enabled
MR 30.3 changelog
Important note
Bug fixes
  • APs reporting other in-network APs as spoofs
Known issues
MR 30.2 changelog
Important note
Bug fixes
  • Various improvements in DFS behavior for outdoor APs
Known issues
  • AKM suite missing w/ OWE (Wi-Fi 5 Wave 2)
MR 30.1 changelog
Important note
New feature
