Quick Start Guides
Learn more with these free online training courses on the Networking Learning Hub:
  1. Log in to the Meraki dashboard (http://dashboard.meraki.com). If this is your first time, create a new account.
    • Alternatively, use your phone to scan and onboard your devices with the Meraki mobile app (iOS) (Android).
  2. Find the dashboard network to which you plan to add your APs, or create a new network. (under Organization > Configure > Create Network)
    Note: Separate networks must be created for different Meraki device types (MR, MX, MS, etc), unless creating a combined network.
  3. Add your APs to your network. You will need your Meraki order number (found on your invoice if you ordered directly from Meraki; it usually has nine characters) or the serial number of each AP (which looks like Qxxx-xxxx-xxxx and is found on the bottom of the unit). You will also need your Enterprise Cloud license key, which you should have received via email from shipping@meraki.com or your authorized Meraki distributor (which also looks like Qxxx-xxxx-xxxx).
  4. Once an AP is added to a network, the network will self-configure an SSID for ease of use and deployment. It is strongly recommended to review this SSID and make any configuration changes desired prior to connecting the APs to the LAN.
  5. Make any additional configuration changes under the Wireless > Configure section of the dashboard network. Be sure to review the SSIDs, Access Control, and Firewall & Traffic Shaping configuration pages.
  6. Unpack your AP and attach it to power (via adapter or PoE) and a wired connection with internet access.
  7. After powering on, your AP will request an IP by DHCP, reach out to the Meraki cloud through the internet (check the Configuring Firewall Settings to Allow Meraki Cloud-Management Access section for details about the minimum internet access the AP's will need) and download the latest software. This may take up to an hour, depending on the internet connection speed. While upgrading, the AP's power LED will flash blue. Once the AP has checked into the dashboard, the LED will turn green.
    Note: A solid orange light indicates that the device has not checked in with the Meraki cloud yet.
  8. Once the AP is upgraded, ensure that an IP address is assigned to the AP correctly (see below).
  9. You're done!
Quickly Scan and Claim Multiple Devices through the Meraki Mobile App
If you have to claim multiple devices, the quickest way is by scanning their barcode using the Meraki app.
  1. Log in to your Meraki iOS or Android app with your Meraki dashboard account. Create a new account if you do not have one.
  2. Navigate to the correct network through the left-side bar.
  3. Go to the Devices tab from the bottom navigation bar.
  4. Select the + icon on the top right of the screen and pick Scan new device barcode.
  5. Point your phone camera toward the hardware barcode to claim the device.
  6. Enter device information and then select Done. Press Add another to claim a new device.
Process of claiming a device in a network via Meraki app
Getting your Access Point Online
All APs with Ethernet connections to the LAN must be assigned routable IP addresses. These IP addresses can be dynamically assigned via DHCP or statically assigned.
For information on deploying an MR AP in a wireless mesh, please refer to our Mesh Deployment Guide.​
If a firewall is in place, it must allow outgoing connections on particular ports to particular IP addresses to ensure AP connectivity with Meraki cloud-management. The most current list of outbound ports and IP addresses can be found in the dashboard under Help > Firewall info (see below). Wifi 6 access points on firmware version MR 28.1+ will use TCP port 443 to the destination IP range of 209.206.48.0/20 when communicating with Dashboard. All other access points will use TCP port 7734 and UDP port 7351.
Firewall info option under Help
  • Was this article helpful?
