Security and SD-WAN (MX,Z) Features Directory
Security and SD-WAN firmware features and compatibility information.
Overview
This article describes MX/Z features and their dependencies on MX/Z firmware releases.
Note: All products have a minimum runnable firmware version, and some have a maximum runnable firmware version. Please refer to Product Firmware Version Restrictions for more information.
Refer to the latest sizing guide and principles here.
For API support, please refer to the API documentation
The table below explains the platform differentiation:
Use Case
Co-term Licenses (detailed breakdown)
Subsciption Licenses (MX and Z breakdown)
Security and SD-WAN (multi-WAN, security, wireless, HA, and cellular support)
All MX models (active models
Enterprise, Advanced Security, Secure SD-WAN Plus
Essential, Advantage
Teleworker (single-WAN, basic security, wireless, and cellular support)
All Z models (active models)
Enterprise, Advanced Teleworker
Virtual MX (single-WAN and native-cloud hosting)
All vMX models (active models)
Enterprise
Essential
Note:
Refer to the Cisco Meraki Firmware FAQ documentation to learn about the firmware upgrade process.
Note - The MX19.2 firmware release will be the maximum running build for Z1. These platforms will not run MX 20.1 and above firmware builds. We recommend you stay up to date with all the latest features with the next-generation hardware platforms. Please consult your sales representative for more information on the latest hardware and software releases. Thank you
Generally Available - MX 26.1.X Firmware Features
Feature
Description
Type
Platforms Supported
Minimum Required Dashboard License Type
(co-term; subscription)
VRF VRF (Virtual Routing and Forwarding) lets a single router use multiple virtual routing tables. It separates different network segments, so they can use the same IP addresses without conflicts. This works without needing MPLS or complex setups. New Feature (Early Access) Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
MultiWAN Adding support for 3rd and 4th Active WAN Enhancement
BGP
Expanding attribute support to include outbound well-known and custom communities and increased route integrity with inbound filtering.
Enhancement
IPsec VPN and Meraki VPN exclusions
VPN full-tunnel exclusion now includes source-based and NBAR application-based exclusion definitions.
Enhancement
Client VPN
Client VPN now supports IKEv2 for establishing connections.
Enhancement
NAT Exceptions NAT Exceptions (AKA No NAT) offer the ability to configure NAT exemptions on some or all configured VLANs. This exempts the source IP address of a packet received on the LAN of the WAN appliance from being rewritten as it transverses the WAN uplink. New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
VPN Translations Address translation for VPN traffic. 1:1 subnet translation enables VPN participation for sites with overlapping subnets. For large deployments needing IP space conservation, 1:M NAT translates subnets into a single IP address across the VPN. New Feature
Org-wide Group Policy Introduces a framework in the Meraki Dashboard created to unify and simplify the configuration and management of network and security policies across the platform. Rulesets can be used to define firewall rules and then reuse those across many Policies in an organization. New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
SGT (Group Policy Assignments) Adds support for SGT group policy assignments and enforcement of the group policy settings Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
Megaport vMX Support Support for virtual MX appliance running in the Megaport Environment that serves as a secure Cloud Gateway to your Cloud Environment.  New Feature vMX-S/M/L Enterprise; Essential
vMX Support for KVM and VMware/ESXi Support for virtual MX appliance running on KVM or ESXI that serves as a Secure Gateway and Auto VPN termination point for your SD-WAN Fabric.  New Feature vMX-S/M/L Enterprise; Essential
Cisco Secure Access Introduces Cisco Secure Access integration with the Meraki dashboard. New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
Encrypted Syslog Support for sending Encrypted Syslog messages Enhancement MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L, C8111-G2-MX, C8121-G2-MX, C8455-G2-MX Enterprise; Essential
Recommended Release - MX 19.2.X Firmware Features
Feature
Description
Type
Platforms Supported
Minimum Required License Type
DH15 and DH21 support in IPsec The implementation of Diffie-Hellman Groups 15 and 21 provides a robust enhancement to the security architecture of VPN peers. By leveraging these advanced cryptographic groups, this feature strengthens encryption protocols and ensures a higher level of protection for secure communications.
New Feature
Modem Firmware Version on Dashboard
With the intention of granting users greater transparency and control, this feature enhances visibility and management of cellular devices and modem firmware status.
New Feature
Z4C, MG41/E, MG51/E, MG52/E
IPsec Active-Active Peering, Monitoring, and Statistics
Introducing a native dashboard experience designed for active-active paths for Cisco Secure Access and SSE integrations. This feature encompasses advanced functionalities such as comprehensive tunnel monitoring (including Layer 7 health checks), the ability to establish active-active tunnels, and support for Direct Internet Access (DIA) fail-open functionality, ensuring enhanced resilience and operational efficiency. New Feature
Z4*, Z4C*, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L*
* = Z and vMX-S/M/L platforms support singular WAN uplinks and do not accommodate Active-Active configurations. However, they continue to offer Monitoring and Statistics functionalities.
Generally Available - MX 19.1.X Firmware Features
Feature
Description
Type
Platforms Supported
Catalyst + Meraki SD-WAN Interconnect  (eBGP over IPSec)
Linking Meraki and Catalyst SD-WAN fabrics will streamline operations for customers using MX and Catalyst devices.
New Feature
IPSec SSE tunnel monitoring, redundancy, and DIA
Simplified dashboard experience for failover and failback paths for SSE integrations. This feature includes tunnel monitoring (including L7 endpoints), establishing active and backup tunnels, as well as DIA failopen functionality.
New Feature
Dynamic Protocol Status Page
This page provides status information about configured dynamic routing peers.
New Feature
Cisco XDR Integration
Seamlessly integrate XDR with Meraki to stream telemetry from your MX devices to XDR. Leveraging AI/ML and advanced analytics, XDR processes this telemetry to detect potential threats. You can view and manage detected XDR incidents directly in the Meraki Dashboard.
New Feature
SD-AVC Integration - Smart Application Updates Delivered via the Cloud
With the SD-AVC Cloud integration, customers can effortlessly opt in and take advantage of the latest application signatures. This process occurs seamlessly behind the scenes, without requiring manual intervention or firmware upgrades.
New Feature
Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX250, MX450, MX75, MX85, MX95, MX105, vMX-S/M/L
FedRAMP/GovCloud support
Select Advanced Security license features are now supported in the GovCloud.
New Feature
Advanced Security; Essential
Advanced Security on vMX
Securing workloads in the Cloud with Advanced Security on vMX powered by Cisco Talos.
New Feature
vMX-S/M/L
30-day Complimentary AT&T eSIM try-and-buy
AT&T and Cisco jointly developed an innovative, out-of-the-box experience in these devices by offering a deep integration with AT&T Wireless services to help businesses get started even faster.
New Feature
MG52, MG52E
Enhancements to the local status page
Additional visibility and status on the local status page.
Enhancement
APIs for Local and Split DNS Service
This feature allows administrators to determine which DNS requests are answered by which DNS servers.
New Feature
API for enabling Multicast Forwarding
API support for Multicast forwarding.
Enhancement
APIs for VPN NAT
API support for VPN NAT translations.
Enhancement
APIs for Policy Object
API support for Policy Objects .
Enhancement
Generally Available - MX 18.2.X Firmware Features
Note - The MX18.1 firmware release will be the maximum running build for MX64, MX64W, MX65, MX65W, MX84, MX100, and vMX100 platforms. These platforms will not run MX 18.2 and above firmware builds. We recommend you stay up to date with all the latest features with the next-generation hardware platforms. Please consult your sales representative for more information on the latest hardware and software releases. Thank you
Note - MX75, MX85, MX95, MX105, MX250, and MX450 will have a performance boost (up to 3x with no additional cost) enabled by default in MX 18.2 and above firmware release. For more details, refer to the latest sizing guide and principles here.
Feature
Description
Type
Platforms Supported
Routed Mode eBGP
Alow for eBGP on the WAN with authentication. New visibility added to see status of BGP sessions. New Feature Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L Enterprise; Essential
Mult-WAN (2 Active + 1 Backup)
Introducing two designated WAN ports with one backup WAN port. New Feature MX75, MX85, MX95, MX105 Enterprise; Essential
vMX-L in Azure vMX-L support on Azure for higher performance and scalability. New Feature vMX-L Enterprise; Essential
Cloud Integrations (AWS)
Deploy and manage your vMX via the Meraki dashboard. New Feature vMX-S/M/L Enterprise; Essential
IPv6 Enhancements Additional IPv6 support in RDNSS. Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX250, MX450, MX75, MX85, MX95, MX105, vMX-S/M/L Enterprise; Essential
Auto VPN Enhancements The MX will automatically select new ports to self heal the Auto VPN connection. Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L Enterprise; Essential
AnyConnect Enhancements Introducing SAML and Custom certification support Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L Enterprise; Essential
Firewall Logging Live Tool
The live firewall log will allow network administrators to troubleshoot or test their firewall policies, rulesets and FW decision-making in real-time. New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L Enterprise; Essential
Adaptive Policy Enhancements Added support for SGT transport on WAN (VPNC mode) and static SGT assignment for port, and VLAN.  Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450 Secure SD-WAN Plus; Advantage
Trusted Traffic Exclusions The trusted traffic will be exempt from inspection and a higher throughput can be achieved. New Feature MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450 Advanced Security; Essential
Talos Content Filtering support in Group Policies The Group Policy UI has been updated to show the Content Categories and Threat Categories which are now curated by Cisco Talos Intelligence. New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450 Advanced Security; Essential
VPN Exclusions APIs Update VPN exclusion rules via API Enhancement MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450, vMX-S/M/L Secure SD-WAN Plus; Advantage
SD-Internet powered by NBAR2
Leveraging NBAR2 for Steering traffic to SaaS or public cloud-based applications over the best performing WAN connection at the time the traffic is forwarded. This is not VPN exclusions (smart breakout). New Feature MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450 Secure SD-WAN Plus; Advantage
SD-WAN and SD-Internet APIs API support for VPN Exclusions and SD-Internet Policy New Feature Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX250, MX450, MX75, MX85, MX95, MX105, vMX-S/M/L Enterprise; Essential
WAN Health Enhancements  Introducing speed tests, top contributors to usage, download option to export WAN Health page metrics, and much more. Enhancement Z4, Z4C, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX250, MX450, MX75, MX85, MX95, MX105 Secure SD-WAN Plus; Advantage
Old Stable Release - MX 18.1.X Firmware Features
Feature
Description
Type
Platforms Supported
AutoVPN enhancements
Stability and performance improvements.
Enhancement
Z3, Z3C, MX64, MX64W, MX65, MX65W, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX84, MX100, MX250, MX450, MX75, MX85, MX95, MX105, vMX100, vMX-S/M/L, UMB-SIG
Enterprise
IPsec VPN peering with FQDN
This feature enables customers to use FQDN instead of IP while configuring IPsec VPN peers. Using IP addresses can be tedious because with a dynamic IP address, a customer has to manually modify the IPsec VPN settings on the Site-to-Site VPN page.
New Feature
Enterprise
IPv6 (Second Public Release) Support for AMP, Theat Grid, and other UX enhancements New Feature Z3, Z3C, MX64, MX64W, MX65, MX65W, MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX84, MX100, MX250, MX450, MX75, MX85, MX95, MX105, vMX100, vMX-S/M/L, UMB-SIG, MG51, MG51E Enterprise
VPN full-tunnel exclusion is a feature on the MX whereby the administrator can configure rules to determine exceptions to a full-tunnel VPN configuration. The feature applies to both Auto VPN and IPsec VPN connections.
New Feature
L3 - Enterprise
L7 - Secure SD-WAN Plus
vMX NAT mode
A limited NAT mode capability can be enabled on the vMX in which traffic from the spokes will be NATed to the vMX's IP as it egresses the vMX in to your datacenter.
New Feature
Enterprise
Policy Objects GA
The main advantage of Network Objects comes from the single Network Objects management page. Here, we are able to create/modify/delete Network Objects and Groups. This is highly beneficial to network administrators making adjustments to large firewall rulesets.
Enhancement
Enterprise
Adaptive Policy (Phase 1)
Traditional segmentation is based on subnets, VLANs and ACL rules. The rule sets are limited to the network which it resides in and is not meant to be globally scalable. Adaptive Policy helps address these limitations with micro-segmentation and more. Phase 1 introduces SGT Transport. More details on this can be found in the MX Adaptive Policy Configuration KB
New Feature
Advanced Security
ThousandEyes Agent Onboarding the ThousandEyes Agent to our MX family New Feature MX67, MX67W, MX67C, MX68, MX68W, MX68CW, MX75, MX85, MX95, MX105, MX250, MX450 Secure SD-WAN Plus + (more options being discussed)
Old Stable Release - MX 17.X Firmware Features
Feature
Description
Type
Platforms Supported
IPv6 (First Public Release)
IPv6 is an ongoing cross-product initiative for Meraki as IPv4 addresses are being exhausted and with more hosts such as IoT devices requiring addressing, IPv6 provides a new structure to accommodate a larger number of hosts.
New feature
MX, Z, vMX
Enterprise
NBAR2
Network-Based Application Recognition (NBAR) is an advanced application recognition engine developed by Cisco that utilizes several classification techniques.
Enhancement
MX, Z
Enterprise
Content Filtering Powered by Cisco Talos
This allows the MX’s Content Filtering feature to classify URLs based on web content and threat categories curated by Cisco Talos.
New Feature
MX
Advanced Security
SD-Internet Steering (Top 10 Apps)
Internet traffic policy configuration remains consistent with VPN traffic policy configuration, albeit with different options. There are 2 different SD-Internet policies that can be configured:
  • Custom expression polices
  • Major application polices
New Feature
MX
Secure SD-WAN Plus
Mandatory DHCP
Mandatory DHCP enabled VLANs must request for a DHCP address before gaining access to the network.
New Feature
MX
Enterprise
Enhanced WAN Failover and Failback
Flow failover and failback the instant the primary uplink is deemed reliable.
New Feature
MX
Enterprise
Archive
MX 16.X Firmware Features
Feature
Description
Type
Platforms Supported
Traffic Analytics Classified by NBAR2
New feature
MX, Z
Enterprise
Cisco AnyConnect
Introduces native Cisco AnyConnect support from the Meraki dashboard.
New feature
MX, Z, vMX
Enterprise
SD-WAN over Cellular
With this feature in place the cellular connection that was previously only enabled as backup can be configured as an active uplink in the SD-WAN & traffic shaping page.
New Feature
MX
Enterprise
vMX in GCP
vMX deployment in Google Cloud Platform.
New Feature
vMX
Enterprise
PPPoE support
You may need PPPoE if your ISP requires a username and password to access your DSL connection.
New Feature
MX, Z
Enterprise
Enhanced SNORT
Snort version upgrades.
Enhancement
MX
Advanced Security
SD-Internet Steering (L3)
The function of this feature is to steer customer traffic to SaaS or public cloud-based applications over the best-performing WAN connection at the time the traffic is forwarded.
New Feature
MX
Secure SD-WAN Plus
MX 15.X Firmware Features
    • Was this article helpful?
